SmartRG SR350N Yesterday When I went on the my routers IP: 192.168.1.1/admin it ask me to log in. so I typed admin for password and admin for username. But today when I try to get in it just keep asking me to log in over and over again no matter how much times I tried to type admin for username and password. Do you think that I have changed the password for my router? If,yes please teach/help me to find out my Router password. If,no can you tell me whats the problem with my router server? Thanks in advance, Hiroto
5 Suggested Answers
  • 556 Answers
SOURCE: i cant access my router(EDIMAX BROADBAND ROUTER)
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
BR-6104 / 6104W / 6104P
Then
If I forget my password, what can I do?
I hope this helps.
Posted on Dec 06, 2007
sk8er1707
  • 58 Answers
SOURCE: I have a Westell router through Verizon. My
sometimes the default gateway is not always 192.168.1.1 sometimes it is actualy your ip adress for example 192.168.0.1 but that won't always work so go to command prompt and type 'ipconfig" and press enter first try your ip and then try the default gateway... for any more help please pm me for any more help...
Posted on Jun 06, 2009
  • 2567 Answers
SOURCE: when i type in the router network ip address
Type "user" for the username instead of "admin" & leave the password blank. This should work.
Here is a link to a list of the D-Link default passwords:
http://www.default-password.info/d-link/
Posted on Oct 27, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Bought a new computer and trying to install my
The Dynex manual for this router says the default address of the the router is 192.168.1.1 and both the username and password should be admin. If you are connecting to 192.168.0.1, you might be reaching some other router connected to your network, or the Dynex settings have been changed. You can restore default factory setiings by resetting the router. Use a straightened-out paper clip to press the recessed RESET button on the rear panel. Hold it until the System LED flashes three times, then release the button. The router will reboot and factory default settings will be back.
Posted on Nov 28, 2010
Testimonial: "I reset it and it didn't quite work out for me right away but after powering down a few things and restarting it worked just fine. Thank you very much"
Smart rg sr300n
I wouldn't worry about that message from the OS, but if you can't actually log into it. You should have been supplied with a user id/password combo from your ISP. They should be able to walk you through this easier than getting a description on here. Here is the manual that should relate to yours. http://setuprouter.com/router/smartrg/sr350n/login.htm
May 23, 2014 | Computers & Internet
HOW TO PORT FORWARD ON SR350N ROUTER?
first, configure a static IP address on your computer.
second, setup a static IP address for Windows 7, Windows 8 http://setuprouter.com/router/smartrg/sr350n/ip-address.htm
third, login To The SR350N
last, Navigate to the Port Forwarding section
and make some changes i recommend according to experts 1-855-383-7238 .
Mar 10, 2014 | Computers & Internet
Reseting passwords for Smart RG SR350N router
I found the IP address, I've tried all, admin password n all that jazz.
tried the IPS all listed in my ipconfig and still the same results. Please, before I reset my office's internet, will the IPs Ive collected work on the resetted router?
Jul 07, 2013 | Computers & Internet
I forgot my password can not log on to my wireless network any suggestions?
If you are talking about your router then you can reset the router there will be a button on the back that you push and hold for 5 sec then follow the steps below
To open the set up page of the router of the router , one of your computer should be able to go online through the router.
It could be a wired computer or wireless computer.
If it is a wireless computer then make sure that the computer is connected to your own wireless network.
Do not change any wireless settings on the router using a wireless computer.
OK ! Now you have a computer online through the router and you want to open the set up page of the router.
First step is check the IP address of the computer.
Check the IP address and the Default gateway on the computer.
For Windows XP
START ==> RUN ==> type in cmd in the RUN box==> click OK or Hit ENTER . You will see a black window that is a command prompt . In the black window type in " ipconfig " ==> and Hit ENTER on your key board .
For Windows Vista and Windows 7
click on START ==> type in cmd in the start search box ==> enter ==> you will see the black window. Type in " ipconfig "you will see a lot of information. Try to find out the local area connection IPv4 address .
Note down the Default gateway number.
For MAC OS
Click APPLE icon in the right top corner of the computer. Go to System Preferences ==> go to Network ==> you will find the option Built in Ethernet or Airport whichever is connected. If you go to that you will find the Ip address and router Address.
The default gateway is the IP address of your router.
This IP address of the router will be used to open the set up page of the router
Now you got the IP address of the router.Open the Internet Browser ( Internet Explorer, Firefox, Safari )
In the Address bar of the browser Type the IP address of the router.
Do not type http:// or www just type in the IP address only.
It will ask you for the user name and the password of the router.
This is the User name and the password of the router and NOT the wireless password. On a wireless router, there are 2 passwords. One is to access the router and the other one is for the wireless network.
For most of the routers the default password will be " admin " . for some routers the default password is " password ". For Linksys router the default password is admin and no user name.
Jan 13, 2011 | Computers & Internet
How do i set the password for my router
log in to the router from a web browser by typing its IP address into the browsers address bar (default IP address should be 192.168.1.1) this will prompt you for a username and password (default usernames may be admin, user, or no user name i.e. blank, default passwords may be admin or password) once logged in you can change the routers password from the 'security' tab.
May 24, 2010 | Linksys Wireless-G Broadband Router
Want to password protect the router
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Dec 28, 2009 | Linksys WRT160N Wireless Router
Can't get it configured
Try to reset the router using a paper clip, then try to re-log in to the router with the IP address, If you are still unable to log in , try log as admin as the username and password as admin or admin on the username and password is password.
May 26, 2009 | Buffalo Technology AirStation G54...
Set up
No u don't leave it blank the password IS blank so u just type in admin for the user name and then type in BLANK for your password then after than u can change your password but he username remains then same.
Nov 29, 2007 | Dynex DX-E401 Router
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
