Question about Microwave Ovens
Vibration power plate - Microwave Ovens
  • Microwave Ovens Master
  • 9,047 Answers
Please post a new help request here on FixYa and include the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc. and detailed symptoms and when they occur.
Posted on May 04, 2013
AEG MCD2664E-m - plate not turning
There is no separate fuse only for turntable motor. Usually there is two fuse, one in High Voltage section (instead fuse could be HV protect diode) and another one for 220 V (light, turntable motor, fun motor, display....). If light work normally then is turtable motor faulty.
Dado
Mar 21, 2014 | AEG MCD2664EM 60cm Built In Microwave &...
Center will not rotate
The glass plate is driven by a motor underneath. Power may not be getting to the motor or the motor may have failed
Jan 17, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
Emc38905x Does not start. Select microwave, then power then time press start & nothing happens. Need to toggle the power to reset & ok for afew days then fails again
I have an ELECTROLUX MICROWAVE (Model : EK23CBS4) purchased in January-12 from Pune. During usage glass plate got automatically cracked. when i called up service centre they said glass plate is not covered under warranty. When I verified the warranty book there is no as such things are mentioned. Most of the customer having the same problem glass plate getting cracked automatically. So I will suggest do not purchase any of the product Microwave Oven of ELECTROLUX. This is our responsibility avoid any product to purchase of ELECTROLUX.
Thanks, Mritunjay Kumar Cell# - 9922385632
Nov 06, 2011 | Electrolux E30MO65GSS Convection Microwave...
The glass plate inside will not rotate
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 01, 2011 | Thermador MBES Microwave Oven
When the door is closed it makes a buzzing noise, the micro still works and the noise goes away when turned on and used
Is it possible that the other noise produced when using the oven are only covering up the buzz?
I think your microwave has two power supplies; one that supplies the low voltages for the display and control, the other for the magnetron. The first supply may be a standard line frequency unit using an iron-core transformer and if these are cheaply made, the laminations can vibrate and cause a 'buzz.' Better transformers are 'potted' so that the laminations are glued together with epoxy and can't vibrate. On later units, the magnetron voltage is produced by a 'switched mode' power supply that uses solid ferrite instead of iron and never vibrate.
If it was my unit, I would take it far enough apart to run a couple of beads of epoxy glue across the laminated transformer to kill the resonance.
Nov 15, 2009 | GE Profile Spacemaker 1.8 Cu. Ft....
Loud noise like tray vibrating. does not cook.
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # orr your data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker II makes horrible loud vibration noise
If the vibration is there with the magnetron off, using only the timer section with power set to 0%, then the cooling fan likely has a bad (sleeve) bearing and needs to be replaced.
If the vibration occurs only when the maggie is running (heating water for example) then the noise is probably from loose laminations in the power transformer due to sloppy manufacturing. You can quiet the beast if you remove the back panel and pour about a teaspoon of epoxy glue across the laminations of the transformer. Normally, when transformers are made, the final step is to dip the whole thing into a type of lacquer that seeps into the laminations and keeps them from resonating at line or some related frequency.
I would expect the problem to be caused by the fan(s), especially if this is a unit that also has range hood function too.
If you are in the US, check Johnstone Supply for a store in your area. They are wholesalers to the service trade but I have never been turned down when buying appliance parts there and the savings can be as high as 60%.
Nov 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Glass plate not spinning anymore
yes it can be fixed , it is probably the motor that spins it or the circut that controls it
Oct 08, 2008 | Goldstar Microwave Ovens
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave the plate not turning
remove power. turn it upside down. remove access cover and determine if there is a mechanical obstruction...could even be belt driven with a broken belt.
Oct 19, 2007 | Microwave Ovens
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
