Question about Scuba Diving & Snorkeling
Octopus Are octopus endangered
Octopus box what do I need to use it
If I'm reading this right you have an octopus which is a second emergency regulator for your buddy if he is in trouble. Where the original regulator hooks to the valve that goes on your tank ther should be a blank with a screw in it . This is where the octopus screws in . You will have a rubber o ring in side. Put it on the end of the threads from the octopus hose and insert it into the hole the screw once occupied.. The screw is just there to fill the blanks hole and can be thrown out.
Apr 13, 2018 | Scuba Diving & Snorkeling
What is spanish octopus?
That is the octopus caught off the coast of Spain (you did know that Spain has a lot of water along its coast).
Feb 27, 2015 | Cell Phones
Please let me know 5 endangered wildlife species in India.
India is one of those countries in the world that is blessed with various species of wildlife. But there are some species that are endangered. Top 5 endangered are given below-
a) One-horned rhinoceros,
b) Snow leopards,
c) Bengal tiger,
d) Asiatic lion &
e) Elephants.
http://thebitbot.com/travel/2013/05/top-10-endangered-wildlife-species-in-india/
Nov 21, 2013 | Pets - Others
My octopus leaks from the head (not the hose). Could it be an internal problem?
A rebuild or simple adjustment can make it stop leaking if it is coming out of mouth piece if it is leaking from anywhere but mouthpiece or hose connection it needs service.
Mar 26, 2012 | Oceanic Swivel Octopus, Scuba Diving...
Genesis "S.K.O." Octopus GS060 The above product is constantly leaking, not much but pretty much all the time, it does help depending how I position it but that should not really be the answer, It has been...
Hello, there are a few things that may have happened. Often octos pick up sand and grit when they get dragged on the bottom. Try a good vigorous shake in fresh water. After that your moving into badly seated diaphram, split diaphram or slight hole, badly adjusted spring etc etc etc. Would recommend that perhaps you get it serviced. Especially important if you have been using Nitrox. Hope that helps
Jul 17, 2010 | Genesis Scuba Regulator Octopus S.K.O....
Not Animal Emergency!!! Endangered Island!!!!!!!
Hi.
Please tell us more on the problem. We are not able to see the rest of the comments. All I can tell you is that there are not cheats for Endangered Island on DS.
Here a Forum on this game: Planet Rescue Endangered Island Forum (DS)
May 25, 2010 | Ubi Soft Entertainment Planet Rescue...
How do I make the connections with the main valve, I am buying a new octopus not yet assembled,
If I understand your question properly, all you need to do is remove one low pressure plug from the first stage regulator, then screw the hose end in from the new octopus.
Feb 04, 2010 | Aeris A1 Octo
Scuba Tank Setup Question
Ideally, you should have someone who is certified in regulator servicing to do this for you. Otherwise, you may be endangering your life.
Dec 01, 2008 | Aeris A1 Octo
What side does the octopus go on? left or right?
The reason to have it on the right is because that is "standard". I dive with a long hose (7') and an octo around my neck on a 22" hose. So long as you explain it to anybody you dive with and talk about your plan for air sharing in advance, it shouldn't be an issue.
Scuba Diving & Snorkeling Logo
79 people viewed this question
Top Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
