Hi. I have a candy elise washing machine model no.
Hi. I have a candy elise washing machine model no. Go w465 D it suddenly stopped in the middle of washing. The machine still have power but when I wanted to start its not working. Please advice.
  • Layla Alansari Oct 28, 2017
    Go w485 D it suddenly stopped in the middle of washing. The machine still have power but when I wanted to start its not working. Please advice.
dazmaraz
  • 67 Answers
SOURCE: Buttons on CE124 candy eclypsa not working
the on/off switch sounds faulty they can get hot and jam, with the button stuck in you cant open the door, the switch will have to be replaced
Posted on Jun 25, 2007
  • 1294 Answers
SOURCE: Hotpoint WD420 - Stuck in wash cycle
Suggestion: Plug off the wall first. Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Check out user's manual. Good luck. Also check if your inlet into the machine is not clogged.
Posted on Oct 01, 2007
  • 1294 Answers
SOURCE: Gorenje WA1541 Washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Posted on Jan 24, 2008
  • 46 Answers
SOURCE: CNW136 Dryer not working !!
lift the lid with the power off and reset the safety stat. look for a and little red button on the metal heater duct on the top of the machine
Posted on Feb 07, 2008
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
Why does my candy grand o washing machie say 08 and stop working
If the code actually is E08, there is a problem with the motor speed sensor. The motor may be rotating at high speed for a few seconds, slowing down, and stopping or there may be no rotation at all.
Feb 24, 2017 | Candy Washing Machines
Hi, I have a Candy Grand comfort which has just stopped working. the power is there lights on but when I turn the dial it clicks as if to start but nothing happens. Thanks in advance.
Could be the door interlock or simply there is no water entering the machine. Check water supply and also the vales inside the machine . the solenoids should buzz nd hum a little if they are energised but could still be blocked ???
Dec 18, 2016 | Candy Washing Machines
My candy go w475 washing machines stop working, the stop buton flashing all the time, colse the door but still flashing any help plz
clean the filter empty the machine at the drain filter !!!
check for rubbish in the pump viens {power OFF}
kirby grips clothes wires coins etc
perhaps you dont have the manual how to keep it clean
http://www.manualsdir.com/manuals/242947/candy-go-w475-s.html
Dec 04, 2014 | Candy Washing Machines
Surr squeels
Hi Elise,
power amplifire problem.
please go for the repair.
regards,
nuwan
Jan 16, 2014 | Harman Kardon Audio Players & Recorders
Would you know why a washing machine stop in the
How much soap are you using? These newer models only use a small amount of water. You go adding a ton of detergent and that washer is gonna worry itself to death trying to get rid of excessive suds.
Jul 06, 2010 | Westinghouse Washing Machines
Candy grand o not spinning when loaded
Kindly replace the motor to solve your problem
May 17, 2010 | Washing Machines
Jan 08, 2008 | Candy CNW136 Front Load Washer/Dryer
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
337 people viewed this question
Top Washing Machines Experts
