Question about Vehicle Parts & Accessories
Noisy engine What causes the ticking on my 2002 dodge Dakota. Oil was like tar and I drained it all out and changed it. A little better but still noisy and it is noisier the more I press the gas.
  • Vehicle Part... Master
  • 16,174 Answers
You should take one quart of oil out and put in 1 qt of diesel fuel and run it for 15 minutes. Drain it all out and change the oil filter. Put new oil and filter back in. It is hard to tell if the noise is from the valve lifters or the crank. If it is valves, you may be able to adjust them if they are not hydraulic.
Posted on May 06, 2013
  • cgamezsatx May 27, 2013
    Did that but noise is still there seems that It may be a little less but still noisy.
  • Brad Brown May 27, 2013
    It could come down to excess wear now. As long as there is just a slight ticking sound it should be ok.
2002 dodge intrepid gets to operating temp oil light comes on tep gets high runs rough and dies no ticks runs smooth until it reaches operating temp
put an engine flush in first . run the engine on tick over .till oil is hot then drain it. do an oil and filter change may have a build up of carbon in the engine .the flush should deal with that .use 20/40 oil .
Dec 21, 2013 | 1997 Dodge Intrepid
2001 dodge dakota, tar smell from heater
may be a bad catalylic converter
Jan 30, 2013 | Dodge Cars & Trucks
A/C condenser drain clogged, water leak with the 2002 Dodge Dakota
guys at the oil change places keep a box of long heavy pipe cleaners on hand to unplug those. have it done next time you do an oil change.
Aug 04, 2011 | Dodge Dakota Cars & Trucks
Makes like a ticking or light knocking noise at start up, whether it's hot or cold outside. I usually let the truck idle for a while and it goes away.
Usually a sign of needing an oil change. My Dodge Dakota does the same thing, when I change the oil it goes away. Every couple of oil changes I use kerosene to clean out the gunk, just put kerosene in place of the oil, let the motor run for a minute then drain, replace the oil filter, and fill with oil, then you're good to go.
Mar 30, 2011 | Dodge Ram 1500 Cars & Trucks
I have a 1998 dodge dakota sport. i start it and it runs fine after about 5 to 10 mins the oil presser goes from normale to 0 and it starts ticking i just got it and the oil is very thin. what could be the...
the oil pump strainer could be stoped up drain oil put carb clean in oil pan let set for 6 to 8 hour then drain fill with oil run for a hour then change oil and filter again to make shur there ir no more carb cleaner in motor .
Feb 08, 2011 | 1998 Dodge Dakota
Got 55k on a 2004 Dodge Dakota any scheduled service for 60k....like belts transmission etc?
The 60K service on this vehicle requires the following....
Change engine oil and engine oil filter. X X X X X Change rear axle fluid. X X Change front axle fluid (4X4). X X Inspect brake linings. X X Inspect engine air cleaner filter, replace if necessary. X Replace spark plugs. X Inspect PCV valve, replace as necessary.* X Inspect auto tension drive belt and replace if required. X Drain and refill transfer case (4X4). X Drain and refill automatic tranmission fluid, change filter and adjust bands (3.7L). X Drain and refill automatic tranmission fluid and change main sump filter (4.7L).
Oct 13, 2010 | 2004 Dodge Dakota
Ticking in engine after oil change
this ticking problem is probably your hydraulic lifters, when the oil is drained they also drained and they sometimes take a while to bleed so they may be noisy... the noise should be coming from the top of the engine...
I would just check that you put in the right oil aswell just incase, if the oil was to thin it may be a little noisy.. its definately a good idea to make sure the right oil was put in (e.g. 40w-50) < this is the viscosity of the oil and to find out just ask someone in you auto parts store what oil a 92 geo storm should take...
but if the noise goes away after a drive then it was just the lifters and is not a big prob
Feb 11, 2010 | 1992 Geo Storm
Low psi and knock at start up 2002 dodge dakata 125,000 miles, check engine light on
sounds like you have failed rod or crank bearing, this is causing the loss of oil pressure.
Nov 09, 2009 | 2002 Dodge Dakota Club Cab
2001 Dodge Dakota 3.9L oil pressure
The pickup tube is a bad design in these engines, I have fixed several with the same problem, you can weld on a GM screen move it 1/4 of a inch away from the pan or add 1 inch to the bottom of the pan, (use a high volume pump) the problem is the screen is too close and too small and will pick up any sludge off the bottom. also it's great to make a access plate on the bottom of the pan using a Volkswagen Bug oil cover plate, it can be removed with bolts after a oil drain to clean the screen without the hassle of removing the whole oil pan by lifting the engine on these trucks. Good Luck
Feb 20, 2009 | 2001 Dodge Dakota
Knocking under valve cover on cold starts
Is there any smoke when you first start it? what is happening is the valve seals are probably worn and letting the oil seep past them. when your engine is first started it has no oil or very little oil at the top of the engine, thus causing the knocking noise. could be more but this is a most likely answer. oh and is you haven't changed your oil every 3,000 miles you had beeter start doing it.... answer knocking sounds usually come from bottom of engine try a better quality and correct viscosity oil
Nov 17, 2008 | Hyundai Motor 2002 Elantra
Vehicle Parts & Accessories Logo
108 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
