Question about HP Computers & Internet
Windows 8 hp laptop logs off constantly
HP ProBook 4520, I recently upgraded to windows 8 (which works well) however, it will sign me off as a user after 15 seconds of inactivity. I have checked every setting i can find and nothing works
  • HP Master
  • 7,627 Answers
Open the Power Options in Control Panel, select High Performance, select Change Plan settings, set Display time, change Sleep and Hibernate to Never, select Change Advanced Power settings, scroll through each one and set to your preference. This may help: http://www.youtube.com/watch?v=8rydgB_9EOQ
Posted on May 04, 2013
  • 120 Answers
SOURCE: cant log on forgot user account password for hp pavilion zd8000
Oh, you must be an Administrator, right? If there is another Administrator account on the PC, it can restore your password through User Account Settings -> Manage Another Account.
If not, I have a complex way. First, restart the PC. When it shows the HP logo when booting up, press the button for Setup (it is shown at the bottom of the screen, and it is F8 on my HP tx2001au).
Now, don't get scared by what appears. It looks a bit complex, but it is very simple and easy.
Navigate using the keyboard. Press the right button to move to the Security section. Here, press Enter on the Administrator Password option. Now enter and confirm a new password and you're done.
See the bottom of the screen for the button for 'Quit Saving Changes' and the computer will reboot. Now, I guess you can enter the new password.
If this doesn't work, see online for ways to reset a password in Vista. There are some softwares to burn to a CD and use.
If it is an XP, I guess there is nothing to do. Just press Ctrl+Alt+Del on the logon screen to see the classic logon screen. Type in the username 'Administrator' without quotation marks and the password blank. Press Enter and enjoy.
Posted on Nov 27, 2008
SOURCE: I recently upgraded my laptop (hp dv8000) to
wait for the service pack to come. it will help.
Posted on Nov 06, 2009
Testimonial: "thanks for the info"
jgroves705
  • 536 Answers
SOURCE: b and n keys not working on HP Probook 4520.
Until you can get the keyboard of the laptop replaced, you can buy a USB to AT keyboard adapter and hook a desktop keyboard to your system. Also a USB keyboard would work just fine directly plugged-in to one of the USB ports.
Most likely the fix will be to replace the keyboard, which is usually very easy to remove on laptops, but until you can get it fixed, you'll be able to use the system with the regular AT keyboard.
If you want to try to replace the keyboard yourself, I believe I've found it on the HP web site (you will need to confirm that it is the correct keyboard by contacting HP)
Posted on Dec 28, 2010
  • 1196 Answers
SOURCE: i forgot my login user
This is only possible is you are using Windows XP. If your operating system is windows Xp, follow the steps below:
  1. Turn on your laptop and allow it get to the stage where is will ask for user/log password
  2. Press Ctrl + Alt + Del your keyboard.
  3. A user name and password prompt will pop up.
  4. On the user name type in "administrator
  5. On the password, type in "administrator"
  6. and you windows will open, go to control panel from there to change the password.
That's all. In other words, the user name and password is administrator.
But in the case of windows Vista, you will have to re-run windows operating system, because vista security is very tight and it is difficult to break into its password..
Posted on Sep 13, 2011
bronk50
  • 27725 Answers
SOURCE: hp probook 4510s wireless isn't working
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
to create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you
have if dont need any of them you can disable or remove them
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
hope it helps
Posted on Jul 17, 2012
How to remove bios password in hp probook 4520
This i what i did:
hold windows key+arrow up & arrow down + power
when the screen comes let go, hit F10 rapidly
click on security factory defaults or something like that
and reboot - password is gone!
It may work on other models too?
Dec 18, 2013 | HEWLETT-PACKARD ProBook 4520s
I can't see my lan
You have to do more than just download a driver. You also have to INSTALL the driver. Is this an HP Probook 6550b Notebook PC? What is the Operating System? (Windows XP? Windows Vista? Windows 7?) Post back in a Comment. Regards, joecoolvette
May 15, 2012 | HEWLETT-PACKARD HP ProBook 6550b Notebook
My HP ProBook 6440b inbuilt camera is not functioning at all. Actually, it was downgraded to Windows XP from Windows 7 .I tried to download and installed the webcam drivers. Still it is not working. But,...
It is possible that the camera only runs on Windows 7. Re-upgrade to Windows 7. It is much better than XP anyway, and your computer is more than powerful enough to handle it.
May 02, 2011 | HP ProBook 6440b Notebook
I need a manual for hp probook 4520
As far as I can tell your HP Probook is a laptop and note a printer
If you go to hp.com and click on the support link enter your model in and what Operating System you have you will see a link to download the manual from there.
Apr 03, 2011 | HP Office Equipment & Supplies
Hi sir, i buy an hp probook 4520s new piece ,but it is tha main problem is down side is over heating i cannot placed on my lap for long time what i do? and it has no windows in down side for air...
mine 4520s is core i5. it also gets hot just below the touch pad but the upper surface remains cool. i think this problem is with all the probook's series. better learn to live with it
Jan 18, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
B and n keys not working on HP Probook 4520. Can't sign on to computer because need b for part of password.
Dec 28, 2010 | HEWLETT-PACKARD ProBook 4520s
Computers & Internet Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
