Question about Pioneer AVH-P4400BH
HD radio stations are not coming in clear
I can only get a couple of stations to come in clear. There are HD stations programmed, but they don't come in. Even the seek option does not bring up HD stations clearly. Is there maybe some setting missing?
    Sergeant:
  • 182 Answers
See if there is a local/distant selector on your unit. It will make it so your radio will only let you find very strong stations, also check your antenna connection to make sure it is pushed all the way into the connector and is clean of corrosion or anything that could keep it from making good contact inside of the connection, you can use steel wool or scotchbrite pads on the surfaces to ensure a good connection.
Posted on May 05, 2013
PROGRAMING RADIO STATIONS\
In the recent Pioneer models there is a function called BSM, in which it automatically programs all the radio stations, give it a try!
Nov 15, 2013 | Pioneer FH-P404
2002 Sebring. Too much static on radio
Check your antenna with a test antenna sometimes the cable will fill with water or maybe it's just disconnected
Aug 01, 2012 | 2002 Chrysler Sebring
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
Put radio in car lost memory but when i go to tune it in it goes fast past all stations how do i make it go slow to find stations
First things first. Did you connect your antenna? Does your radio need an HD Radio accessory? Check your owners manual. I went through similar issue. Antenna was hooked up, but radio stations were flying by when searching. Come to find out I needed an HD Radio Accessory. Let me know how this works out for you.
Sep 19, 2009 | Kenwood Car Audio & Video
FM Radio doesn't work
it may be that the fm detector has failed or possibly a tank(tunning coil)
Aug 31, 2008 | RCA RS2664 Shelf System
Programing the radio stations
You just press the program button on the front of it. It's next to the Stereo/Mono button!
Jul 04, 2008 | Sony MHC-RX66 Shelf System
Pioneer AVH-P4400BH Logo
66 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
