Question about Nintendo Wii Original Wireless Remote Controller White
Wii operations manual
When pressing any button all four lights at the bottom come on and no buttons work.
Heeeeeeeeeeeeeeeeeelp
Posted on Jul 07, 2013
3 Suggested Answers
cene765
  • 787 Answers
SOURCE: my wii remote doesn't work!!!
Do you play with the second controller before? If you not the second controller must "bind" to the console. Open the cover in front of the Wii and press the red button there and then press the red button on the controller.
Posted on Sep 28, 2009
  • 5 Answers
SOURCE: My disks are not playing.
i am having this same problem.... found this bit of info, hope it helps.
The most common reason for the Wii not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
Posted on Jan 04, 2011
Four blue flashing lights
Have you synched it, i personally have never used the balance board, but there should be a sync button. At the bottom, push this while your wii or wii u is on.
Apr 17, 2014 | Nintendo Wii Fit for Wii
Tip
Syncing your Wii-mote to your Nintendo Wii
So you just bought a new Nintendo Wii Remote Controller but when you click the power button the four blue lights at the bottom just blink huh? Well that just means your Remote needs to be synchronized to your Wii.
Here are simple step by step instructions to do so.
1) Turn on your Nintendo Wii.
2) Open the door on the front of your Wii covering the SD card slot and the SYNC button.
3) Open the battery compartment on the back of your Wii-Remote Controller.
4) Press the red SYNC button on your Wii.
5) Press the little red SYNC button on your Wii-Mote.
6) Wait until a solid blue LED light comes on on one of the four lights at the bottom.
7) If it doesn't work the first time, try again.
Your Wii-Mote should now be synchronized.
on Dec 21, 2009 | Nintendo Wii Remote Controller
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
Wii remotes are not responding to anything. batteries have been changed and lights are flashing but
You need to synchronize them to your Wii. First turn on your Wii. Open the battery compartment on the back of your Wii-mote and the front SD Card door on the front of your Wii. There is a little round red SYNC button on the back of your Wii-mote and a red SYNC button on your Wii in that door. Press the button on the remote and then on the Wii and it should sync. If it doesn't work at first try again. You know it is synched when one of the four LED lights at the bottom of the Wii-mote is solid.
Dec 26, 2009 | Nintendo Wii Console
Wii is comming on but when it says press a button nothing happens new controls aren't working or sensor bar isn't picking it up what to do
You probably need to synchronize your Wii-Motes to your system. When you press buttons on your controllers do the four LED lights flash at the bottom? This is a clear indication. Your Wii needs to be turned on. You need to open the little door on the front of your Wii where the SD card slot is. Under the slot there is a little red SYNC button. Then open the battery compartment on the backs of your remotes. There is another little red SYNC button here. Press the button on the remotes and then while they're flashing on the Wii and it should sync. If it doesn't work the first time try again.
Dec 22, 2009 | Nintendo Wii Console
The wii remote is not linking with the tv so cant use it
You probably need to synchronize your Wii-Motes to your system. When you press buttons on your controllers do the four LED lights flash at the bottom? This is a clear indication. Your Wii needs to be turned on. You need to open the little door on the front of your Wii where the SD card slot is. Under the slot there is a little red SYNC button. Then open the battery compartment on the backs of your remotes. There is another little red SYNC button here. Press the button on the remotes and then while they're flashing on the Wii and it should sync. If it doesn't work the first time try again. Good luck!
Nov 23, 2009 | Nintendo Wii Remote Controller
Wi console comes on but wi remote not working
You probably need to synchronize your Wii-Motes to your system. When you press buttons on your controllers do the four LED lights flash at the bottom? If so this is the problem. To do this, your Wii needs to be turned on. You need to open the little door on the front of your Wii where the SD card slot is. Under the slot there is a little red SYNC button. Then open the battery compartment on the backs of your remotes. There is another little red SYNC button here. Press the button on the remotes and then while they're flashing on the Wii and it should sync. If it doesn't work the first time try again.
Nov 15, 2009 | Nintendo Wi-Fi USB Connector for DS/ Wii
My wii remote doesn't work!!!
Sep 26, 2009 | Nintendo Harvest Moon: Magical Melody for ...
Cant add a controller
I had the same problem and called Nintendo support. They had us unplug the wii console for 30 seconds, plug it back in and start the system back up. BEFORE pressing the A button on the health and safety screen, we needed to take the battery cover off of one remote, press the red sync button, then quickly press the sync button on the front of the wii console (in the front - you have to open the flap). Once the single blue light was on at the bottom of the remote, do the same with the other remote (press the sync button on it and then on the wii console). Then the second blue light should be lit on the second remote. Hope that helps!
Nov 29, 2008 | Nintendo Mario Kart (Wii) for Wii
Nintendo wii controller
Did you try pressing 1 and 2 and the same time over and over again on the Wii controller settings when you press home button?
Jun 21, 2008 | Nintendo Wii Console
Nintendo Wii Original Wireless Remote Controller White Logo
37 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
