LG 47LW55OT , I bought this TV from the uk but have since moved to perth Western Australia. I can't seem to get my TV to either change to the country I'm in or pick up any digital channels . Is there a solution Thanks
SOURCE: TV losing its channel memory
I had the same problem. I replaced the EEPROM marked U33 (it's a 24C32 in a smd package) and the TV worked fine.
BEFORE replacing the EEPROM you have to go into the Service Menu (hold down VOL- and CH+ on the local command) and take a note of all the values, specially the R,G,B gain and R,G,B bias, in the "standard" picture mode as well as in the "Cold" picture as well as in the "Warm" picture mode.
(if you forgot to do this, here are my default values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
then you put the "Cold" image mode and set again those values, increasing the G bias to about 300 and the B bias to about 310.
then put the "Warm" image mode and set again those values, increasing the R bias to about 300 and the G bias to about 280)
The other values such as brightness, contrast etc, have to be left at 50.
I hope this solution will FixYa!
Posted on Aug 06, 2008
rapanSF
  • 150 Answers
SOURCE: 42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Posted on Nov 17, 2008
  • 3 Answers
SOURCE: reset code for digital tuner
Is the Tv a multi standard Tv?  And as you know most countries around the world are converting to digital Tv. A converter box will likley solve the problem.  Try this web site , ramelectronics.net  also type in , standards converters , in a search box.
Posted on Jul 05, 2009
SOURCE: Unable to tune my LG Electronics Digital TV (Model 37LC2d-ec) to receive digital channels (have tried auto and manual program). TV will only receive basic standard channels. TV bought in Uk - now livi
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
Posted on Jul 22, 2009
  • 7 Answers
SOURCE: technika pro LCD TV/DVD 15.4 HD Digital
if its the model i think it is the lcd15-m3 then go into d.menu (about 6 buttons up from the bottom left) then using the arrows next to the same button go down to the last option which should be setup or settings and press ok.
then go down to instalation (again the last option) and press ok
then down to first time instalation (again last option)
Select yes and press ok, this will bring you up to your original setup page
(menus are the same in most models but almost positive that the model you have is the m3
Posted on Sep 04, 2009
WHICH STATE IN AUSTRALIA IS BELONG 08 PHONE CODE?
08 Central and West Western Australia, South Australia, Northern Territory Perth, Adelaide, Darwin
Apr 18, 2017 | Cell Phones
WHICH IS 08 CODE IN AUSTRALIA
here it is, 08 Central and West Western Australia, South Australia, Northern Territory Perth, Adelaide, Darwin
WHAT IS THE 08 CODE AUSTRALIA STATE
third time, 08 Central and West Western Australia, South Australia, Northern Territory Perth, Adelaide, Darwin
Apr 18, 2017 | The Computers & Internet
We bought a veon tv in NZ and now have moved to Australia. The tvs country is still NZ. How do I change it to Australia.
get the on screen menu up and look for the area transmission format
Australia is PAL
Sep 22, 2016 | Cell Phones
I m in perth western australia looking for asmallmotor for the pump for tiger elec. water heater model pde- d33a where can i buy this part?thank you.
try your local water and irrigation supply retailer as they have access to most pumps used
mostly the pump used in hot water systems is a grundfos brand but any brand of the right size and capacity will do the job
Sep 18, 2016 | Cell Phones
I want to register my Fuji digital camera on line. Have typed in your website but cannot find a simple button to "register Serial No 8WJ66299 Model FFXJ 10SEEC Purchased May 2009 Purchaser: Nancy Gluck 101...
Nancy go to http://www.hanimex.com.au/myfuji/signup.asp
You can also ring them or send the waranty card in. If you bought it in Australia and have the reciept this will be all you need if you have a problem in the future. NB for your protection its not wise put your name and address on web sites as you have here. It best to remove it if can.
Jun 16, 2009 | Fuji FinePix J10 Digital Camera
We have just moved from he uk to perth
I beieve you have a TV standards prolem. According to the chart available at the website below, the UK is PAL I and the Aussies use PAL B/G. So if you bought a TV in Australia and are using the DVD Combo from the UK I think you are out of luck. A reputable TV repair shop would be able to answer further questions about this without charge.
http://www.kropla.com/tv.htm
Nov 27, 2008 | GE 27GT271 TV
Taking TV from UK to Australia
The TV has a setting for Australia in the Digital setup menu, so there shouldn't be a problem.
The mains voltage in Australia is 240V - 50Hz, so you should only need to change the mains lead.
If you decide to go ahead, when you set up the tv:
Switch on tv.
Press and hold "MENU" on the side of the tv.
Menu will appear on-screen.
Continue to hold until menu clears.
Wait.
TV will reset to factory settings, allowing you to re-tune the tv.
Jan 08, 2008 | Philips 37PF5521D 37 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
