Question about Dell Dimension 4600 PC Desktop
Can't Install windows xp home edition sp3 on Dimension 4600
I have a Dell Dimension 4600i, I've installed windows 2000 on it then i wanted windows xp back so installed windows xp home edition sp1. But it gives me entity errors on kernel32.dll whenever i try to install a program like chrome or jdk(java) so i borrowed my friend's xp3 disk and tried installing it on my pc. After the cd extracts files to the hard drive it restarted, then i worked fine until the 34 minutes remaining mark. It when in to a black screen and my monitor switches from analog to digital and back to find a signal, I don't know what to do anymore.... My pc is kind of changed. My fan broke and I was too lazy to buy a old dell fan from ebay so I got a regular fan, same speed same size then got two pin connectors then unplugged the floppy, connected the fan port with the floppy power port then it worked, just so the motherboard wont overheat. Also i got rid of the old ram and replaced it with ddr 1 cl3 1gb ram and two ddr 1 cl3 250mb ram. I'm pretty sure the ram has nothing to do with it but the fan gets me worried..
  • 1 more comment
  • June wi May 04, 2013
    Please I'm in a hurry..........
  • Brian Sullivan
    Brian Sullivan May 05, 2013
    Thanks for getting back windows can be a pain have do you have automatic updates turned on or tried running automatic up dates
  • June wi May 06, 2013
    Yeah, but it is fixed now thanks
  • Dell Master
  • 27,725 Answers
Lets start at the ram always place the largest ram module closest the CPU central processing unit.
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
if you need more help with this post a reply
Posted on May 04, 2013
Testimonial: "So, Like you said, I have replaced the RAM but that did not work, so I have been thinking and I thought it would be either the fan or the graphics card. So I first tried installing win xp sp3 and like usual, it would go black screen on 34 min mark. So I took a look at the computer and shut it down. I noticed that the motherboard has a intel graphics card on it. So I unplugged the DVI from the Graphics card, got a vga cable and plugged that into the mother board. And when I started the pc, the windows installed fine, it worked! So the graphics card was the problem. But the graphics are fine after I installed the drivers and it works perfectly. Thanks you for helping. "
  • June wi May 05, 2013
    Thank You so much, the RAM was placed right but the thing is my computer is dusty, so I will clean it. also my hdd says i ATA, my friend tells me ATA is PATA like it's the one before SATA I don't know if this has to do with the problem. But I currrently tried running linux Ubuntu on this pc and it works fine, but the only problem is that when I install the graphics driver the screen goes black. So I'm thinking if it is the graphics card, like when windows configures it it fails........ But thank you any ways. http://ubuntuforums.org/showthread.php?t...
4 Suggested Answers
SOURCE: FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
Optiplex 150 I get a message error loading operating system
can somebody help out there?
Posted on Jan 06, 2009
wipdhuls
  • 133 Answers
SOURCE: dell dimension L800CXE
Hello Wademyd,
It seems that the installation CD that you have is not a bootable CD.. must be old one.
Please down load the boot disk for windows from http://www.bootdisk.com or follow the Microsoft article link given below:
http://support.microsoft.com/?kbid=310994
Do not be intimidated by the article, although it looks big but there is very little that you need to do, rest of it is general instructions like where can you order a new CD from etc...
OR
Simple solution is to borrow Bootable Windows XP installation disk and install it using the serial Key that has been given to you.
Please let me know if that helps and please rate the solution if it helped you.. it will not cost you anything but will make a difference for me :)
All the best and kindly let me know in case you need any further assistance.
Regards,
Srinivas
Posted on Jun 11, 2009
SOURCE: Deleting old SP1 partition on dell 2400
Sound like you have two versions of the operating system out there. Not sure what your question is. If you want to remove the old version you should have done that while you were doing the installation. That would have been easy by just telling the system to do it for you.
Now you will probably need some type of partitioning software and i'm not sure if you just delete it if it will cause problems when you try to boot because windows knows it's out there.
If I were you, I would just reinstall windows and clean the disk of everything. It shows you what it finds out there as far as operating systems, so just delete them both, then do a quick NTFS format of the drive and reinstall windows.
Posted on May 14, 2012
Windows xp cd with sp3 installation
In BIOS change the boot order such that CD/DVD comes first. You will also need to make sure your hard drive runs in IDE mode since Windows XP doesn't support sata drives by default. FYI XP is going end of life early 2014.
May 20, 2013 | Microsoft Windows XP Home Edition
DELL DIMENSION DVD ROM CODE 10
please install dvd driver cd and software
May 07, 2012 | Dell Computers & Internet
I need to install a memory card and want to know how to remove the side cover on the pc desktop
ehjh
If you go to this link it will show you how to open the side panel on your Dimension 4600.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/cvrop.htm#1138085
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 30, 2010 | Dell Dimension 4600 PC Desktop
Dell dimension 3000 series won,t install drivers and utilities cd after fresh install of windows xp sp2
Hello
Run the windows update again to win sp3.
Sp3 has most of the drivers in the dowload.IF not you should be able to install utilities after you get win xp sp3
Apr 12, 2010 | Dell Dimension 3000 PC Desktop
How do i open my Dell dimensions 4600 to install
Just lay it over on its right hand side, there a button on the top and the bottom, press these both at once and lift. It will just hinge up and give you plenty of access. When closing just make sure its lined up and it simply clicks back into place. Cheers from Scott
Feb 19, 2010 | Dell Dimension 4600 PC Desktop
How do I restart a Dell Dimension 4600 PC Desktop
Hello gabeymybabey,
If the computer is using Windows XP, do the following to restart the system:
•Click the Start button
•Click Turn Off Computer.
•Cick Restart
The computer will restart after the shutdown process finishes.
Also, here's is a link to the Dell 4600 Series user guide:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/index.htm
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 31, 2010 | Dell Dimension 4600 PC Desktop
Ethernet controller driver
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
Driver problems
JPWatson, This link will take you to the drivers for your Dimension 4600 with Windows XP: http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&SystemID=DIM_P4_4600&os=WW1&osl=EN As far as the PC showing you already have a connection I would ignore that for now. Just download the appropriate drivers from this Dell page including the network interface card drivers and install them first. After you have rebooted and verified that the hardware devices are working correctly then start troubleshooting your Internet connection if it is still necessary. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 21, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
151 people viewed this question
Alun Cox
