Watches Logo
Anonymous Posted on May 03, 2013
Watchminder 3 watch is frozen and I can't reset
Watch is frozen, will not reset or change modes
you will need to press the reset or a/c button located usually near the battery well with a pin and a magnifying glass
3helpful
I received my suunto t3d black watch yesterday and accidentally set the contrast too high and it saved. I've tried everything but can't seem to find the setting to fix it. I've even removed the...
To reset contrast on the sunnuto t3d hold down all 4 corner buttons at once, this will place the watch in sleep mode. Wait a few seconds and press any button to wake the watch back up. This will allow you to run through the inital set up just like when you got your watch, alot of your info will be saved so you can just quickly confirm them with the mode button. I also set my contrast too high, I have reset it to 3 and found it much easier to read in all lighting.
Aug 13, 2011 • Watches
3helpful
2answers
My nixon lowdown watch screen says ROM FAIL and i have only had it for 3 days how do i fix it ?
Hi You don't fix it. Hopefully you mean it's only 3 days old from being new and you can take back to the shop for refund/replacement.
ROM - stands for Read Only Memory and is basically the chip that all the software and information is stored on. This runs the watch and it's this that has failed. You could try reseting the watch by removing the battery and then replacing it.
11helpful
3answers
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
6helpful
The display is frozen and I can't get the watch to reset. I was beginning exercising and it is frozen on this screen.
If there are no reactions to any buttons, reset the
wrist unit by pressing all the buttons
simultaneously for two seconds. All other settings
except time and date will be saved.
manual is here
6helpful
2answers
Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
28helpful
4answers
Configuring time, date etc for my O.T.S watch
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
Hour and second hands on my Casio Wave Ceptor watch appear to have frozen
They ususally say leave it alone for about 3-4 minutes and it goes back to time keeping mode. Or - you have "turned it off" a feature to conserve the battery while it sits in you drawer.
Manuals can be downloaded from Casio at
http://world.casio.com/wat/download/en/manual/
Dec 29, 2007 • Watches
4helpful
3answers
Frozen Display
The reset will always solve the issue. It may have been due to Electromagnetic Interference or Static Electricity.
You can press and hold ALL buttons at the same time for 10-15 seconds. After that, simply reset the time/date. All saved information will be stored.
If you are still having a problem feel free to contact Polar Customer Support @ www.polarusa.com.
Hope this helps.
Chris @ Polar USA
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
