Question about Microsoft Windows XP Home Edition
Swopping hard drives
How do I change from C drive (full) to D drive (empty) so that I can use D drive as master? Thank you
  • Microsoft Master
  • 2,878 Answers
You would have to install an OS on D. You should get a dual boot option then just choose which OS you want to boot into.
Posted on May 06, 2013
Windows xp
Another option is to install the OS on D with C removed / disconnected. C will then just become the spare.
May 03, 2013 | Microsoft Windows XP Home Edition
HDD master password
Thank you Jeff S. for your solution of releasing my ext hard drive by merely changing the drive letter assigned to it - simple solution that did the trick immediately like you said. I am so appreciative. I have been looking for 3 days to find the proper solution - tried others that did not work - yours was great. Thank you so much!
Apr 10, 2012 | Western Digital (WD1200BEVS) 120 GB SATA...
I have two hard drives on my computer one is nearly full the other has on a few things on it, but i don't know how to transfer things from the full one to the empty one
Just simply copy any big folders you have on your full drive onto anywhere else on the empty one. Remember to start installing things to the empty one too. Right Click>Copy>Paste onto empty drive.
Start>Computer> You should see your two drives.
Jun 25, 2011 | Computers & Internet
Master/slave settings on sp411c samsung drive please SATA
The SATA hard drive did not have master/slave setting at the hard drive
if you want to make the hard drive as master just connect your hard drive to SATA 1 slot at Motherboard
and id you want to make the hard drive as slave just connect your hard drive to SATA 2 slot at *********** board
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Samsung Computers & Internet
My external hard disk is not working properly. i can see the icon in drivers and printers but there is no folderor icon to open
Please remove the usb cable and try to connect do you see the notification new hardware found if yes just check my computer dose the hard drive shows over there if yes and double click on it dose it open if yes and the hard drive is empty .
then go back right click on the hard drive check properties dose it show the empty and the full graphs if it shows full and dosnt show the drive letter.
then right click on the my computer icon on the desktop go to manage and diskmanage ment check the hard drive over ther dose it show its unformated or un initialized if no dose it have drive letter on it if no then right click on the drive and say change drive letter and assigned one letter like h or g and check in my computer now dose it appair.if still so try changing the usb cable may its defective.
if dosent detect at all could be your hard drive case so you can remove the hard drive from inside the case and connect it directly.in the computer if works backup your data abd return backthe hard drive in the case and if its still in gurentee return it to the service center.
Dec 14, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My local disc C is full and local disc D is empty, why?
Hi
Thank you for your query
The predicament you are in is called hard drive partioning (as long as anther hard drive hasnt been fitted in). Essentially you take one physical hard drive and you break it into 2 virtual drives thus the C and D, this is generally done to allow all system files to reside on the C drive and your personal files on the D drive
Regards
Shauqat
Sep 27, 2010 | ASUS Eee 4G Notebook
2nd hard drive on Dell Dimension 8300 ( both ATA)
setup the original harddrive as master and the new one as slave then the drive that comes up as c will be the master and the others will follow suit and when you install the games just change it in the install
Jul 20, 2009 | Western Digital Caviar SE16 WD5000AAKB -...
Change master to slave
if your hdd still have sticker from factory ( on top the silver side you can see MAXTOR brand) there is small information you can change "jumper" small plastic.
you can find instruction MS(master),SL(slave) or CL(Cable Select) so look at the back oh hard drive you'll find a small plastic (one)..take it out and change like the instruction sticker
Jan 30, 2009 | Maxtor Hard Drive
C memory full
not possible...you'll need to back up that c drive, which is the default for all Windows programs..try a back up drive, or move some of those high density(music and image) files to a back up system
May 25, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Information used- capacity used and available
Re: deleting the files, did you drag the files into the trash bin and then empty it? The files don't actually leave your drive until you 'Empty Trash' on your mac's doc. Hope this helps, not sure about your startup disc problem.
Apr 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Microsoft Windows XP Home Edition Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
