Question about HEWLETT-PACKARD HP Mini-Notebook 110-3135dx Netbook
Troubleshooter wizard not working
"An error has occurred. Troubleshooter wizard can't continue." error message everytime i troubleshoot. how to fix it.
  • shahirahbah May 04, 2013
    Window troubleshooter Wizard can help to identify and fix common window problem. My problem is my window 7 troubleshooter is not working properly. It will give an error message "An error has occurred. Troubleshooter Wizard can't continue" Need to know what is the cause and how to fix it.
  • HEWLETT-PACKARD Master
  • 5,660 Answers
"Troubleshooter wizard?"
How about you just stating what the problem is..........
I won't go into detail, about what I think of the "Troubleshooting Wizard" (It would be negative thoughts, trust me...)
Post back in a Comment
Regards,
joecoolvette
Posted on May 04, 2013
Speakers aren't working No Sound.Screen says"An error occured while troubleshooting.An unexpected error has occurred.The troubleshooting wizard can't continue.
The first thing should be to check if you have the right audio drivers installed (if you have any). If its something more complicated we will need more details like the name of the motherboard, processor, service pack installed and so on. Is it fresh installed Windows or did it just randomly stopped working?
with regards
daliz
Sep 30, 2017 | Computers & Internet
Tip
Resolving Software Compatibility Issues
The Software Compatibility Troubleshooter
Most applications designed for Windows 7 and earlier versions work automatically on Windows 8.1 and newer. However, when an older program fails to work properly on your current OS-for example, it runs slowly or not at all-you should attempt to resolve the problem by using the Program Compatibility troubleshooter, which runs the software while simulating the behavior of an earlier version of Windows. Often this relatively simple process can resolve the problem and allow the program to run. You can open the troubleshooting tool by following these steps:
1. Open the Control Panel.
2. Under System and Security, click Find and fix problems.
3. Within the Troubleshooting screen, click Run programs made for previous versions of Windows
4. On the Program Compatibility Troubleshooter screen, click Next.
5. Select the program that is having problems, and then click Next.
6. Once Windows has modified the settings, click the Try recommended settings to run the application using the recommended compatibility settings option.
7. Click Test the program.
8. Once the program opens, you should evaluate to see if the problems still occur. 9. Close the program and return to the troubleshooting wizard. Click Next.
10. Choose one of the following three options, or click Cancel to abort the process: a. Yes, save these settings for this program b. No, try again using different settings c. No, report the problem to Microsoft and check online for a solution
11. If the program behaved correctly, you should click Yes. The troubleshooting is complete. Click Close to close the troubleshooter.
If the Try recommended settings do not work, you should rerun the Program Compatibility Troubleshooter; but this time, select the Troubleshoot program option. Follow the wizard again and work through a number of scenarios, such as •The program expects to run on a previous OS, such as Windows 8, 7, Vista SP2, or XP SP3. •The program needs additional permissions to run, such as an administrator. •The program needs a different display environment, such as reducing the resolution or DPI scaling. The wizard also offers a combination of these scenarios. Frustratingly, the wizard does not allow you to go backward-if you make an incorrect selection, you need to cancel and rerun the wizard. In addition to the troubleshooter, you can also configure compatibility settings directly on the application by using the Compatibility tab found in the application's properties. 1. Locate the application executable or the application's shortcut within File Explorer (from the Start screen, right-click the application tile and select Open file location). 2. Right-click the application executable or the application's shortcut, and then click Properties. 3. On the Compatibility tab, select the settings you want to modify and click OK. 4. Rerun the application. Determine if the fix worked. Using the compatibility setting directly on the application allows you to configure additional settings; for example, you could do the following: •Reduce the display •Force the application to run in a 640 × 480 screen resolution •Apply the application fixes to all users on the computer You can also launch the Program Compatibility Troubleshooter from within the Compatibility tab.
DPI Scaling If you are using a Surface or Ultrabook, you may notice that these new devices have extremely high screen resolutions. By default, Windows scales the screen to magnify the size of text and other items on the screen so that they appear larger and are easier to view. You can modify this by launching the display utility directly by typing dpiscaling.exe in the Start screen, or it can be run from the Control Panel by performing the following steps:
2. Click Appearance and Personalization.
3. Within the Display section, click Make text and other items larger or smaller.
4. On the Display screen, change the size setting as required, and then click Apply.
on Apr 11, 2017 | Microsoft Computers & Internet
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
Why can't I install download of Magix Movie Edit Pro 14 in Windows 7
You try try the compatibility wizard in Windows 7 to see if you can install Magix Move Edit Pro 14 in compatibility mode for Windows Vista.
To run the Program Compatibility troubleshooter
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
  • You can also open the Program Compatibility troubleshooter by right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility.
Feb 27, 2014 | Computers & Internet
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Rpc server is unavailable when installing printer
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Apr 27, 2017 | Office Equipment & Supplies
Error code 0x803C010A preventing troubleshooter from starting on windows 7
You have a virus or malware infestation. Bring it to a computer shop that specializes in virus/malware removal for a set price.
Jun 01, 2012 | Acer Aspire Z5600 Touch Screen Computer
Everytime this message :" an
try to login with different ids it it works it means you are blocked by site admin wait until unblock your id it happens when any user locked by ip or range of ips
Aug 19, 2011 | nexon.net
2GB Sansa e250 won't connect to my PC
Hello!!!
Try connecting it to different USB!!
Nov 02, 2008 | SanDisk Sansa Clip MP3 Player
After I download a song from the internet and try to sync it to my sansa mp3 player it gets on the mp3 player but won't play? It says continue your subscription to sync
Feb 09, 2008 | SanDisk Sansa e200 MP3 Player
HEWLETT-PACKARD HP Mini-Notebook 110-3135dx Netbook Logo
152 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
