Question about Garden
Toro 20058 adjust self-propel drive - Garden
  • 147 Answers
SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
Posted on Nov 06, 2008
SOURCE: toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Posted on Mar 18, 2009
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
SOURCE: self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Posted on Aug 29, 2009
SOURCE: toro 6.5 GTS does not self propel
The self propel part does not work on my Toro 6.5 GTS. How to fix?
Posted on Jun 20, 2010
My toro walk behind self propelled blade disengages how do I adjust it
No adjustment, ensure no obstruction on drive end of cable, replace cable, probably stretched over time.
Jun 17, 2012 | Toro Power Lawn Mower
My toro self propelled isn't self propelling
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Aug 08, 2009 | Garden
6.5 toro walk behind self propell b&s engine. self propel does not work
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
Aug 05, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro commercial self propelled, engine stops when I engage the self propelled. I t runs until then. What can I do to solve this problem?
Regularly check the wheel-drive belt on a self-propelled mower for wear and tightness .... "Affected engines may run rough, stall or bog down under load,"
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 20016 self propel
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
