Question about Tally Matrix T2280 Printer
Telly genicom printers
I have realised that my telly genicom printer has a problem of picking papers. How can I go about it?
    Sergeant:
  • 390 Answers
What do you mean picking papers. Do you mean feeding the paper, or printing with certain types of paper?
Posted on Aug 10, 2007
SOURCE:
I am not able to take the print from tally
to print anything from telly
go to the page you want to print then hit alt+p
on right side hit the button select printer
set your printer in it
hit enter and accept
now you can print from tally.
Mar 05, 2011 | TallyGenicom 2265+ Matrix Printer
LG 4200A
hi the problem wouldnt be the screen instead your probably right with the video card if the screen was dead it would stay black but with it changing slightly you know the screen is gettin power.
When you press the controll does an led flash on the telly to tell you the controll is working just incase the telly is stuck on an av channel.
If you have got a dvd player hooked upto the telly switch this on with the telly on and see if the telly will work using the dvd player this would rule out the fault being with the ports on the telly not picking up the signal.
If this still dont change anything then it could either be a resistor gone or a couple or it could be what you thought with the video card/controller but their is no way of knowing without testing the resistance at certain points on the board but it deffinately wouldnt be a problem with the screen so it shouldnt cost to much to repair.
It mgith be a case that the telly has overheated and blown a resistor thse can be brought for pennys but locating will be the problem let me know what you want to do and wether you are considering doing the repair yourself if you are you will need schematics to follow off and also multimeter to test resistance at certain points on the board.
Jan 16, 2008 | LG 42LP1D 42 in. LCD HDTV
Message stating check signal cable
Hi there, This could be a few possible issues. What you can try depending on your setup, is 1st to try and connect your ps3 to a different telly using the same cables if possible, like if you had it connected to hd telly with hdmi cable, use this setup on another telly to see if you have the same problem. If it's the same on the 2nd telly then it's the hdmi cable that's the problem, just replace and you should be good to go, but if it works on the 2nd telly then you will have to adjust some settings usually a resolution issue on the 1st telly. You can also try using an analogue cable that came with the ps3 to see if that works. If it was the analogue cable you were using anyway you may need to get a new one, but try on another telly 1st to be sure. It's most likely just a resolution issue but if you have the same problem on 2 tellys it's probably the cable then. Hope this helps
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
I have problem with lipi t6050 printer head allinmnet plese send me how to allin head of the printer
LIPI PRINTER T 6050 PRINTERHEAD PRICE
LOGIC CARD PRICE
REPLACEMENT LOGIC CARD PRICE
RIBBEN CARTRIDEV PRICE
LOGIC CARD MAXIUM REPAIRE PRICE
Dec 18, 2010 | Tally Line Matrix T6050 Printer
I turn on tv. There is sound but no video.
hi, if you have a device plugged into the telly that gives you the picture such as sky or cable then the best thing to do is disconnect this device from the back of your telly then switch the telly and this device off at the mains, then re-fit all the cables making sure they are connected properly then switch it all on.
now check if you have sound also make sure the tells is on the correct input for that decice and also make sure the mute button has not been pressed on the telly remote or on the remote of the device you use to watch telly, if after doing all that it still dont work then the chances are something has blown on the amp in the telly.
make sure you double check all the leads going into the telly to rule out a faulty lead causing you the problems
Jul 13, 2010 | Televison & Video
Video input
Hi the only slight chancer you have of doing this without the remote and this will only work with some tellys is to have the telly switched on then the device you have connected to the video input have this switched off at the wall then with the telly on switch the device on your trying to get the telly to pick up now some tellys will pick up the signal and go to that input channel, if how ever this dont work your going to need to go out and buy an all in 1 remote, these remotes cost next to nothing to buy you can get them off the well known auction site or from your nearest cheap shop such as discount stores that sell goods for next to nothing these remotes will work on all tellys and would solve your problem if the way i told you dont work.
Im sorry their is no easy way to get it to change but without the remote your pretty much stuck unless on the telly you have a button that looks like a square with an arrow running from left to right if you have this button then pressing this wil change the input source for you, if you dont have this then the only option would be an all 4 1 remote.
let me know how you get on or if you need further assistance ok
May 31, 2010 | RCA TruFlat 27F520T 27" TV
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Telly 8108n driver for mac
We have the same problem - we have pulled out of storage an old g4 and are running tiger on it. It is connected to the network so we have to turn it on to print through it. it solves the problem but i am not happy with it.
Sep 29, 2009 | Office Equipment & Supplies
Paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Mar 12, 2008 | TallyGenicom 2280 Matrix Printer
Cleaning rear projection screen
I read in the manual for the Sony KDF 50E3000 that you should use warm soapy water on a clean cloth if you aren't able to remove it with a dry cloth. I find that the microfiber cloths work best.
Feb 11, 2008 | Televison & Video
Tally Matrix T2280 Printer Logo
402 people viewed this question
Top Tally Office Equipment & Supplies Experts
Thomas F. Schneider
Alexey Krenvalk
Alexey Krenvalk
Clive
Clive
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
