Question about Home
How do I fix holes in my fake granite floors?
  • 5,089 Answers
Copy following link for possible solution:
http://waterheatertimer.org/How-to-repair-cracks-in-tile-and-grout.html
Add a comment
Posted on May 04, 2013
Our Kohler Fairfax kitchen faucet 12176 has a difficult spout swing from side to side that I thought would get easier over time. It is installed on granite and when I use hot water is very difficult to...
was the base installed under the faucet..is there a single hole in granite...faucets usually come with a long base to cover the holes in sink..or with one round ring for granite installation..which the faucet should be mounted on..
Nov 22, 2010 | Kohler Fairfax Single Control Lavatory...
Mounting my dishwasher to granite counter tops. Granite Grabbers last about a week before they loosen up
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Oct 21, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
PROPER WAY TO COMPLETE KNOCK OUT HOLES FOR FAUCET
yes you need 1 1/8 in hole saw,for granite.Also need a squirt bottle to keep the bit wet,try to google ,DIY they might have a video on this .
Apr 12, 2010 | Swanstone KSDB-3120 Compact Double Bowl...
Grainite floor has chipped
the best filler is epoxy,your best bet is to go to a marble and granite fabricating company,they will sell you the resin and they will tint it the right color, so all you have to do is add the hardener and fill where needed,they would probably charge you 5 to 10 dollars,this would save you from buying the epoxy resin,hardener,and the green tint, most of these shops that install granite have people there that will tell you how to apply it to your tiles.good luck
Jul 12, 2009 | Stone TOP ONLY: 21 in Black Granite Vanity...
Wrong product on granite surface
Contact the company on the bottle! I would also talk to the store manager there as well. The manufacture will give you the correct steps in removing the product. You could also contact an installer and get some ideas as what can be done to either fix it or remove it. Either way, be careful. Most people don't realize that granite can be damaged.
Mar 30, 2009 | Stone TOP ONLY: 21 in Black Granite Vanity...
Granite installation didn't get flush with slide-in range
suspect your contractor didn't allow for the tiled floor. the range legs are usually adjustable up and down. have you checked this?
Sep 04, 2008 | Cooktops
Home Logo
52 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
