Question about Samsung RF267AEBP
How do I remove the ice maker?
Where are the screws or fasteners to remove the ice maker?
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 34 Answers
It is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out.
How do I remove the ice maker? - z
Ice maker assembly upside down on bench.
Posted on Dec 24, 2013
How do i remove my spacesaver coffee maker from my rv
Is it fastened at the top?
If not it could be glued down on the surface so it does not move.
If the microwave is fastened below it, they could have fastened the coffee maker first and then the microwave below it. Remove the microwave and have a look when it is removed.
Aug 22, 2017 | In Microwave Ovens
How to replace ice maker and start up
  • Connect the wiring harness of the new ice maker to the wiring connection point, which is positioned behind the electrical access panel;
  • Fix the ice maker in place with two mounting screws and an L bracket;
  • Position the water tube into the water inlet hole and fasten it tight;
  • Put the Styrofoam insulation over the fill tube.
Jun 02, 2015 | Norcold Inc Norcold 1201LRIMSS...
How do I remove the ice maker from the refrigerator?
Hello there,
To be able to remove the ice maker from the refrigerator, please follow the steps below:
  1. Unplug the refrigerator ffrom the power outlet,
  2. Open the door and unscrew the screws that mount the ice maker, there are basically 2 screws, for some model, there is a screw under the mounting that is holding the ice maker in place, but make sure you do not loosen the screws completely,
  3. Lift the ice maker up from the screws mounting it and pull it out from the rear of the refrigertor,
  4. You will have to squeeze the tab on the wire connector in order to remove it from the refrigerator wire harness.
  5. Then you can remove the ice maker.
That is how to remove the ice maker from the amana refrigerator.
All the best. Elect_Comp
Sep 20, 2011 | Amana AFF2534FE Bottom Freezer French...
Ice maker is over filling
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Thanks
Aug 12, 2009 | Whirlpool Refrigerators
Ice Maker Overfills With Water
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Frigdaire side by side ice maker is a block of ice
Hi, You can remove the ice maker by removing the two screws on the top that fasten to the wall and most models have a screw on the under side.
Did you have to turn the water source off to stop the water from going into the ice maker? Sometimes a cube will not release and block the ice maker from turning.
Please let me know if I can assist you further.
Vic
May 29, 2009 | Frigidaire FSC23F7D Side by Side...
Ice Maker is not working on my Whirlpool Gold Refrigerator
I removed six screws from the ice maker to pull it out of the refrigerator.  Their are four screws holding the ice maker in place and two screws on the ice maker door.  Had problems getting the electrical harness disconnected.  Used hot water to removed the ice cubes that were struck in the ice tray.  Poured all remaining water into a bucket and re-installed ice maker.  As of now, the ice maker is making ice !
Apr 08, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Ice Maker does not work
My husband repaired our ice maker after our repairman failed to show to replace the entire unit. He removed the front panel and then the next panel fastened by 2 screws. A white plastic piece can be seen as the ice exits the unit, which is poorly designed and literally gets stuck to the left. He slid the piece to the right and vuala! It works. He is looking for a rubber piece or something that will keep the piece pushed to the right, as it seems due to the poor design that this type of malfunction will happen again... good luck!
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool side by side ice in door, Ice maker not dispensing ice
You should replace the entire icemaker. It will cost about 100 dollars and takes about 15 minutes. The 3 fastener screws and one wiring harness.
Nov 08, 2008 | Whirlpool GS6SHEXNL Side by Side...
Replacing the ice maker mechanism on a GE side by side
  1. Unplug the refrigerator.
  2. Remove the icemaker's front cover by unscrewing or prying it off as needed
  3. Remove the ice bin, shelves, and vertical partition.
  4. Remove remaining screws, disconnect the icemaker wires from the harness connector or socket, and remove the unit from the freezer.
  5. Remove the back access panel and any fasteners that hold the inlet valve to the refrigerator.
Jul 06, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Samsung RF267AEBP Logo
551 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
