Question about ZTE Warp
BOOST MOBILE ZTE WARP
Have problems with it turning off when on a call and when on a game or texting
    Problem Solver:
  • 16 Answers
It should be a software bug, do a reset and it should work fine. Go to
  • press Menu Key > Settings > Privacy > Factory data reset > Reset phone(Don't check Erase SD Card)> Erase everything. The phone will reboot automaticallyBut remember all the data on ur phone will be lost. If this does not work please contact the manufacturer and check if you are eligible to claim for a warranty repair service.
Posted on May 08, 2013
Geekman
  • 32281 Answers
SOURCE: What's your problem?i got a problem with the battery of my zte warp..how can i keep it charged at less one day?..it takes 2 hour to stay uncharged
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Posted on Feb 10, 2012
  • 268 Answers
SOURCE: Can't receive calls on my ZTE warp
somthing wrong with your settings.
restart your cellphone,
Posted on Jan 18, 2012
ubnawkshiski
  • 10 Answers
SOURCE: zte warp got wet
When this happens, immediately remove the battery. Let the phone dry (it may take several hours) before you put the battery back in and try to turn it on. If it is only water, and you act quickly enough, your phone may be okay.
Posted on Oct 22, 2012
mobil master
  • 14641 Answers
SOURCE: my zte warp sequent text just keeps sending but never actually sends the text
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Posted on Oct 31, 2012
  • 5 Answers
SOURCE: zte warp shut off and wont turn back on or charge
Try to perform the following steps it may wrk to solve your issue:
  • 1.Power off the phone.
    2.Press and hold Vol+ key and Power key simultaneously for about 10 seconds until the some option appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.
    3.Use Vol+ key and Vol- key to move the cursor to "wipe cache partition" and press camera key to confirm it.
    4.After 5 seconds, the cursor will be on "reboot system now" again and press camera key to confirm it. The phone will reboot automatically.
    If this doesn't wrk then try to change the battery and check.
Posted on Apr 10, 2013
I want to unlock my zte warp elite from boost mobile and use verizon as my carrier!How do i do this?
Contact Boost and they can unlock it, some small fee is often charged, it is not free in most cases no matter where you go.
Jan 11, 2017 | ZTE Cell Phones
Where is the digitizer located on the zte warp elite
this is a layer just below the glass.
The digitizer is the key component in touch functionality
Zte warp elite lcd disaseembly
Oct 06, 2016 | Boost Mobile ZTE Warp Sequent Touchscreen...
Why is it that my boostmobile zte warp is plugged in and says that it is charging but it automatically says that it is not charging anymore?
Hi sarah, i think there is some problem with the charger or the battery, i suggest you to try with different battery and charger and if you facing same issue still than you can contact the manufacturer they will help you with it.
May 08, 2013 | ZTE N860 Warp Used Boost Mobile Touch Text...
Cant use touchscreen on my zte warp sequent phone
well you mean the screen is frozen up or not responsive to your touch? if so do a Hard reset and that will fix the issue the issue ,before doing it pull out the SD card.
May 06, 2013 | Boost Mobile ZTE Warp Sequent Touchscreen...
Changing the text input
You can go to message option>compose message>tap on three line menu key>you will get the option of android input!! :) Good Luck :)
Feb 11, 2013 | ZTE Warp Android N860 Smartphone With Car...
How to change my android zte n860 text input
It is quite simple go to option messages - settings - text input on mode on :)))
When i plug my charger into my phone my phone wont charge
Looks like you already ask this before.
the problem might be on your charger. try to test with other charger.
if still happen, you can make a USB charger jumper.
call your phone manufacturer if the problem still can't be solved
Nov 15, 2012 | ZTE N860 Warp Used Boost Mobile Touch Text...
Dont know how to use new boostmobile zte warp
letsdance,
Boostmobile,com
They can answer your question.
Jul 22, 2012 | Boost Mobile ZTE Warp Smartphone w/ 4.3"...
How do i put a sims card in a ZTE warp?
You don't
The ZTE Warp is a CDMA devices available on Boost Mobile. CDMA networks do not use SIM cards. They are locked down to one specific carrier in order to ensure a close ecosystem at least as far as the carriers are concerned
May 24, 2012 | ZTE Warp
ZTE Warp Logo
291 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
