Question about DeLonghi Coffee Makers & Espresso Machines
Hi I have two Delonghi esam5500 machines. the first just displays heating up, then general alarm. The second produces normal coffee but then on hot water or cappuccino demand it displays heating up and then goes back to coffee ready. So far trying to get the first machine up and running, I have swapped the mainboard, pump, water heater and front solenoid as well as the ntc on the heater. None of this has made the blind bit of difference apart from getting me frustrated!! Has anyone got any suggestions as I am out of ideas!! Thanks
5 Suggested Answers
  • 1618 Answers
SOURCE: My machine has stopped producing hot water.
Either your coffee boiler elements are damaged or the thermostats on there are damaged or tripped, use an ohms meter to check element and thermostats.
Posted on May 20, 2010
  • 17 Answers
SOURCE: delonghi coffee machine service providers in india
please contact Mr. Prashant Suthar, India,
Posted on Sep 20, 2010
  • 4 Answers
SOURCE: DeLonghi Perfecta ESAM5500 when trying to make a
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Posted on Feb 08, 2011
SOURCE: Unable to remove the infuser
Hopefully you've solved the problem by now, if not:
I had the same issue and assumed that 'Turning the appliance off' ment turning the main switch off behind the unit. This is not the case. Just turn off the unit using the button on the top left of the facier panel. I then found that the pressing in of the 2 red button allowed the infuser to slide out easily.
I am house sitting and do not know where Delonghi Perfecta Cap. machine's grounds container is located? indicator says to empty now...
Hello, Jean -
Delonghi makes a number of different cappuccino machines. If you had stated the model number of the machine, I probably could have found you the manual for the homeowner's machine online.
I found a user's manual for the Delonghi ESAM5500. The manual has an illustration which shows where the grounds container for that machine is located. If the homeowner's cappuccino machine is not an ESAM5500, the grounds container for their machine may be in a similar location.
This is the link to the user manual for the Delonghi ESAM5500:
It is a PDF document, so you will need Adobe Reader software (free).
Page 17 of the manual talks about how to clean the machine, including cleaning the grounds container. In the instructions part A9 (which is illustrated on Page 3 of the manual) is identified as the grounds container.
Just to be sure, if you can contact the homeowners, do so and ask them where the manual for their cappuccino machine manual is located, so you can refer to it and so that you do not accidentally damage the machine.
Best wishes.
Feb 09, 2018 | DeLonghi Coffee Makers & Espresso Machines
Delonghi Perfecta milk frother not heating.
My friend your problem is that the frother heat is foulty
Mar 18, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
General warning coming up in heating cycle.Not working at all.
For DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Team says:
1. General Alarms should be taken care by authorised delonghi technician only. Please do not try to fix yourself as it is related to safety.
2. This error occures due to loose wirings, opened water circuit, failure of heating elements and last failure of PC board repalcement.
3. Please contact your nearest Delonghi authorised dealer for technical support.
4. You can claim the warranty if recently purchased through . If you are in India then contact us at
Nov 03, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Can not make cappucciono, keep saying heating up.
Found the water heating element was open circuit. Replaced with a genuine spare and all was good.
Oct 14, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Locating manual as coffee machine is unable to select appropriate grounding for coffee
There seem to be a number of different sub-models of the ESAM5500 line of superautomatic coffee makers.
You can see a list of all of the user manuals for these sub-models here:
Good Luck!
Dec 28, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Coffee Makers & Espresso Machines Logo
62 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
