Question about Radio Communications
Greetings looking for my IC737A the front plastic covering the frequency meterThank you.
    Master:
  • 623 Answers
Icom parts center should have the parts in stock check their website.
Posted on Nov 05, 2013
Need to remove front panel located under the filter cover
Press around the panel edges while pulling back. There are probably plastic clip locks that need to be depressed to unlock. Flex carefully, taking care not to break the plastic cover.
May 13, 2015 | Samsung AW1293L Air Conditioner
Gas isn't working.
The most common cause is a safety switch called an Inertia sensor. It has a reset button and is usually located behind either front kick panels or behind a plastic cover in the cargo area.
There is a frequency which makes the switch disengage the power to the fuel pump. Sometimes this happens with slamming of a door or cargo lid. Once you find the part, just press the button down to reset.
You might want to look at pictures of the part online at autoparts stores.
Apr 18, 2013 | 2004 Ford Freestar
Bought new toner cartridge. Cannot figure out how to remove it from the printer. The 1 & 1/4 Hi X 9 inch door does not provide any handle or way to pull it out. Help. Bought new in Feb 2011
The drum and toner can become stuck in the machine if the develop joint link is not attached properly.
1. Open the front cover.
2. Remove the drum and toner.
- If you are able to remove the drum and toner, the issue is resolved.
- If you are unable to remove the drum and toner, continue to the next step.
3. Looking into the interior of the machine, there should be a plastic latch (develop joint link) on the left side of the machine that is connected to the front cover (connector), an inch left of the manual feed slot. This plastic latch is usually not the same color as the front and side cover.
- If the develop joint link (plastic latch) is there but not connected to the connector on the front cover, continue to STEP 4.
- If the develop joint link (plastic latch) or the connector on the front cover is broken, go to STEP 5.
4. Pull the end of the develop joint link (plastic latch) towards the connector on the front cover. If the develop joint link (plastic latch) pulls out, pull it gently to the left of the connector and then push it over the connector, securing it firmly onto the connector. Remove the drum and toner.
- If you are unable to remove the drum and toner or secure the develop joint link (plastic latch) onto the connector, continue to the next step.
5. Pull the end of the develop joint link (plastic latch) towards the connector on the front cover. Keep the latch pulled out and remove the drum and toner.
Aug 31, 2011 | Brother HL 2270DW Laser Printer
Greetings, Our camera's film advancer lever is flopping around and appears to be unscrewed part way. We tried to screw it on, but no luck. Please help!
Use a #00 crosspoint (philips) screwdriver on the bottom of the wind lever and remove the screw, this will allow the black plastic cover to come off the handle. There is a straight slot screw that needs tightened up to hold the handle tight, note that it is a LEFT handed screw. Replace the black plastic cover.
May 02, 2011 | Vivitar V3800N 35mm SLR Camera
Top enter collar of a whirlpool washer was pulled lose.
Greetings,
they have plastic tabs that lock it to the side of the outer tub. Its possible the front cover needs to be removed to gain access to the tub. The console needs to be removed and flipped up and two spring clamps hold the front cover on and there are one in each corner....now, you can actually remove the whole front off of the frame and work on the whole washer easy...Bruce Denton
Jan 23, 2011 | Whirlpool LSR5132PQ Top Load Washer
Compressor won't run- light turns on and fan runs.
Greetings.,
Since,I do not have a model number. I will go with most popular..remove the panel that covers the compressor. Please make sure its unplugged from power and remove the little plastic cover that goes over relay..(some do not have cover) being careful to notice how the relay comes off. remove relay and shake it. if you hear a rattle ..its bad...This is not always the case, but for the most part it is....NOTE:::if this is a G/E refrigerator...the compressor is off during defrost, but condenser fan runs and freezer fan is off as well...if so, find defrost timer and advance until compressor comes on..most located under front refrig kickplate or by thermostat(cold contol)
Jan 11, 2011 | Refrigerators
Ibstalled new Evaporator fan motor and it doesn't seem to have power getting to it . model PLHS269ZDB2
Greetings,
The first thing to be sure of is you do have voltage at the motor...once your sure of this. I would advise you to check for a broken wire at every connection block..I have also seen this happen before. The defrost board controls the evaporator motor as well as, the compressor and lights etc..Its located in the fresh food side. The top left has a plastic cover that runs to back of refrig..There are two screws that secure this to the cabinet and two small dimples that go into a retainer at the front of it..Remove screws and slide the housing towards the right side..it will pop out. then you can look at the board and see if showing any burn spots...Its possible to be bad, but look ok////Bruce Denton
Dec 01, 2010 | Frigidaire Refrigerators
Location of Front Blower Resistor on 99 Suburban K1500
MAIN BLOWER , MOTOR RESISTOR IS THE PLUG RIGHT BY THE BLOWER MOTOR. IF LAYING ON YOUR BACK LOOK UP AT BLOWER MOTOR IT THE PLUG TOWARDS THE FRONT SET ABOUT ONE INCH AWAY. PULL TWO 9/32 BOLTS OUT IT WILL PULL DOWN. THANKS
Feb 15, 2010 | 1999 Chevrolet Suburban
Hi,I fitted a brand new motor in my car and would like to reset analogue odometer on my 1997 toyota conquest. Can u please assist?
Did you already take a look by the plastic in front of the meters if there is or are screws? There should be some way to take that part of the dash of. then with some tweezers, after removing the plastic, you can carefully turn the dials. to your desired number.btw, turn them with the clock, not against the clock.
hope you'll find the screws and get it open.
greetings........Gilbert.
Mar 04, 2009 | 1997 Toyota Camry
How do Iopen the case of an HPvs17x monitor?
The Capacitors on the power board are usually the reason for failure of an LCD. If you open the HP VS17 ( I can provide an exhaustive step by step If I have to) remove the five screws for the power board ( larger of the two boards) and look for an area where there are 4 caps (see pic). Look for exploded, popped up, bulging, or leaking caps and replace with the same or slightly higher tolerances. The one I replaced last night were (2x )1000uf25-50volt and (2x) 470uf25-50volt. Check the rest of the board for similar issues and replace as needed.
Jan 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Radio Communications Logo
21 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
