Question about Motorola Mobility RAZR V3c Cellular Phone
Volume Control Problem
Hi, the volume style is always in vibrate and ring style on the display screen,unable to set the volume and also not allowing to perform any action on the phone for example unable to open phone book ,unable to do a call.Please help ASAP as i am unable to use the phone.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 128 Answers
Thr problem is with the ribbob (flex cable).it mist be replaced.take it to qualify technician because is not easy job
Posted on Aug 09, 2007
SOURCE:
Jitterbug flip won't ring. I've checked the volume and it's set at maximum What is the Jingle, I've tried both ways, no help. Exasperated, donna
Page 30 of manual at the link shown suggests a way to silence the Jitterbug.
http://www.specsserver.com/CACHE/FREOWQFWSXOG.PDF
Quoting from Page 30:
To adjust the ringer volume:
1.
Be sure the phone is open and on.
2.
Press the
Up/Down
volume button
on the outside of the phone below the
display window. Press each time you want
to advance to the next choice.
These choices will appear on the screen:
- Ringer Volume Ring Max
- Ringer Volume High
- Ringer Volume Med
- Ringer Volume Low
- Ringer Volume Silent
3.
When you're satisfied with the setting,
release the volume button.
Your Jitterbug may ring and vibrate
to alert you to incoming calls. The
ringer and keypad can be silenced
by pressing the volume button
Down
until
"Silent"
appears on the screen. Your
Jitterbug will now only vibrate to alert you
to incoming calls (This can come in handy
at a movie, a library, or any other location
where a ringer may be a distraction.
May 09, 2018 | Cell Phones
I have no ringing sound on phone, i have gone to settings, ringtones & sounds, the ringer is on, vibrate is on, when i get a call it vibrates but those not ring. is there a ringing volume somewhere?
Welcome to FixYa!
Volume up your phone using the Volume Key on the left side of your phone.
  • A volume bar will appear on the screen.
  • Press the Volume Key until you reach the desired volume level.
  • Tap the ICON on the right to switch between VIBRATE and RING.
  • Make sure that it is in the RING mode.
Thank you for using FixYa.
Have a great day.
Jas247
Jun 04, 2011 | HTC 7 Mozart Cell Phone
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
My motorola pebl phone will not ring
Hii
can u plz chk and tell me if ur profile is set into vibrate mode? and regarding keys, u can set the key tone volume to zero.
if ur a new user here is wht u hav to do
> MENU > RING STYLES > Change it to LOUD or VIBRATE and RING
Regards
Hope it helps u
Sep 11, 2009 | Motorola Cell Phones
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Cannot get Ringtones!
Go to settings, - Ring Styles, - select style - change it to loud, go to detail of loud and select ring volume and increase it to 7.
Jan 09, 2009 | Motorola Mobility RAZR V3
Motorola w377
Like most of the W377, this one's very odd. The only way I know how to do this is to switch off all Key tones. Key volume is part of the Ring Style menu, so:
>Settings
>Ring Style
>Ring Detail
>Change
> On the Detail menu use the 4 way selector arrows to cursor down to Key Volume
>Change
>0
>Ok
>Back out
NB The Ring Style settings for ALL ring parameters (Ring Volume, Line 1, Text Msgs, Voicemail, Alarm, and Key Volume) change whenever you select a different Ring Style, so you can set up one ringtone in Loud Ring but get a different one for Soft Ring, a different one for Vibrate and Ring, a different one for Vibrate then Ring, etc.
For the sake of sanity (and to avoid the alarm waking me up with a loud blast of Bach when I wanted a quiet 'Ding') I have set the same ringtones etc in all of the above profiles.
BTW whenever you can't find a menu you need, try pressing the black round button (OPEN MENU) in the middle of the 4 way selector arrows - it opens submenus that can't be accessed any other way.
Hope this helps.
Jan 02, 2009 | Motorola Mobility W377 Met Silver/Pink...
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
Motorola Mobility RAZR V3c Cellular Phone Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
