My laptop Hp touchsmart t2 1035 when i turn it on tow lines horizontally apear in the screen then i discovered if i heat the screen with hair dryer and restart it will disapear but i should do this every time
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
There might be something behind the screen?
Posted on May 03, 2013
epr1977
  • 46 Answers
SOURCE: black screen with horizontal green lines
Hello yoyoxide.
from my experience can be something related with the video card. I recommend you the followig (Hardware diagnostics):
-Look for one of the discs that came with your computer, it should say (Drivers & utilities).
-Boot from the CD. If you don't know how to do it do the following:
1.Insert the Drivers&Utilities Disk.
2.Restart teh computer.
3. When you get the Dell logo, press F12
4.Select Boot from CD/CDRW-DVD (something like that).
-You will get a prompt to run the diagnosics.
-Just follow the wizard
-I recommend you to run diagnostics for everything.
-You will see if you have any problems with your hardware.
It seems that you have a pretty new laptop, so probably it's under warranty.
Posted on Jun 28, 2008
SOURCE: a horizontal (2mm wide gray line) appears along my screen steady.
try plugging into an external monitor.. if the screen looks ok then it is most likely the laptop LCD screen is bad.. had the same thing on a HP laptop .. replaced the screen and all was well again with the world...
Posted on Dec 24, 2008
belloso2
  • 71 Answers
SOURCE: my hp pavilion dv600 freezes then lines show up help?
Try this: see if you can find an external monitor, use a VGA cable to hook to monitor...tell me if the lines are still showing on the external monitor...
let me know.
Posted on Apr 10, 2009
  • 479 Answers
SOURCE: HP laptop screen problems
This might be an issue with OS itself or display drivers.Once try to reinstall the display drivers.
Posted on Dec 08, 2009
  • 111 Answers
SOURCE: white thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Posted on Feb 18, 2010
No video
Sounds like crappy solder on th gpu. Basically, you need to take a hair dryer to the GPU and reseat it. HP had this problem on a bunch of older DV models. Without knowing your model, I can't post specific instructions.
Supplies needed:
Thermal paste, I recommendArctic Silver as it has better heat transfer properties
Hair dryer
wooden spoon
Strip the chassis to the motherboard, pull the heatsink from the GPU and set the board on a heat resistant surface. Clean all old thermal paste from the GPU. Heat up the GPU with your hair dryer while using the wooden spoon to press down on it.. When you see the solder turn shiny, turn off the dryer. Continue to press down on the GPU until the solder changes back to a dull color. Let everything cool down before reassembly. During reassembly, make sure to clean the old thermal paste off the heatsink and reapply a fresh layer. Reassemble your laptop, and turn it on to see if the fix worked.
I know at one point there was a bad batch of solder that made its way onto assorted motherboards, so this fix may work for the same issue on many laptops. Good luck!
Dec 28, 2013 | Samsung N150 Netbook
I have horizontal lines on my LG ED 500 laptop
I just want to double check, the horizontal line that you have on your screen, is it big as hair line or almost?
Please let me know once you read this.
Jun 15, 2011 | LG E500 Express Dual Series Notebook PC
The problem started when I was watching a tv show and my laptop shuts down, then I tried to turn on again, and I couldn't. When I press the power button to turn on the laptop, the keyboard lights come on...
Dear Friend,
HP Pavillions are not good... Buy a new Laptop that dosnt use Nvidia graphics card.
The problem resides in the graphics card Heating up to madness.
If you know how to open your Laptop, Dissassemble it and remove the processor. Heat up the Graphics card with a hair blower for 5 to 10 minutes. put the hair dryer about 1 cm distant to the graphics card.
After that - let it cool and make sure you put back everything correctly, screw it up and Voila...
Your laptop is new again..
Nov 25, 2010 | HP Pavilion Dv6910us Notebook
Touchsmart tx2z Screen Flickers and Freezes
it seems the touch part is off center because when i touch the screen it reacts one finger over
Jul 09, 2010 | HP TouchSmart tx2z
Partial Screen Black-out on Bootup
Hi, it may be happening due loose wire of laptop screen or any other hardware issue, you can't do it by own either you go at local repair center or call remote tech support provider.
Cheers
John
For any Tech Query, Dial: +1 (844) 355-5111 (toll-free)
Apr 17, 2017 | HP Pavilion dv6000z Notebook
The lightning bolt on my hp touchsmart tx2 flashes
that means your laptop has no power so your battery is dead which would explain why it shut down on you, and that means its not charging so it would either be the adapter or the port on your laptop
Feb 27, 2010 | HP TouchSmart tx2z
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
