Question about Moen & One Handle Tub & Shower Faucet
Moen single shower handle won't come off even after set screw is removed
I am trying to remove the handle and face plate off of a Moen single handle shower faucet. I have removed the set screw from the handle, but I cannot get it to come off. I don't want to damage it because I will be reusing it once I tile the shower enclosure. Are there any secrets I am missing?
Wow the post says can't get handle off even after set screw is removed and the advice given is, it's an Allen screw, duh he got it out but the handle is stuck. Pull off the handle there are limiters behind it, his problem is the handle genius not water temp.
Posted on Mar 05, 2016
  • 40 Answers
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
Posted on May 18, 2013
  • 659 Answers
SOURCE: how do I remove the single faucet handle to replace it.
There is a set screw in the handle, it can either be a hex screw or it can be a philips head screw depending on which faucet you have. If you have a clear decrative handle then there is a cap that you remove and the screw is behind it. Once you remove it you can remove the other trim.
Posted on Mar 22, 2009
snap101
  • 117 Answers
SOURCE: Can't remove the handle on Moen shower handle... Seriously!!!
heat it up with a torch, or just break it off, you can call moen at that point and kindly tell them that your handle broke and you need a new handle and cartridge. or you can get a drill and drill the allen screw out, they are such a pain i usually break them when i can get them out and get parts for it then
Posted on Aug 04, 2009
  • 297 Answers
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Posted on Jul 24, 2009
meBNme
  • 334 Answers
SOURCE: My handle is loose but I cannot find a tool that
It would be an allen wrench. Any typical multi sized wrench should have the proper sized allen wrench.
The holes can often become filled with grime so be sure to seat the wrench properly to prevent stripping.
Posted on Aug 25, 2009
  • 4340 Answers
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
Posted on Sep 18, 2010
How do I remove the handle on Moen 2352 single handle shower
There is a allen screw under the handle some times covered by a red and blue plastic plug. Removing the allen screw allows the handle to be removed. Hope this helps.
Bob
Jul 04, 2014 | Moen 2352 Chateau Single-Handle Shower...
Can't remove valve on moen TL2377 shower faucet. I removed the handle by removing the screw. There is a chrome cup that I believe is a decorative cover over the valve stem. That is stuck and I don't want...
Take the round cover plate off and it will make getting that part off easier. You will be able to use a screw driver to help in removing it.
Be gentle and good luck
Apr 05, 2011 | Moen TL2377 Chrome Castleby Single Handle...
The moen adler tub/shower faucet came with a piping fixture that the hot and cold water come through and redirects water to the shower head. anyways, I have already replaced the tile in front of this. It...
They make face plates to cover up removal of faucets in tile. They are chrome and will fit any 6" single handle faucet cover plate.
They are used to cover up tile for removal of 8" spread faucets so you have a little room to move if you have to cut valve out and replace.
Lowes started carrying them and a plumbing supply house should have them if not email me and I will try to get you a address to get one if this will help you out.
They are about $15- $20 for it. Lowes carry them in NC .
Jun 11, 2010 | Home
The shower control valve for my moen 2995 faucet is stuck in the shower position. how do i remove it?
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Sep 27, 2009 | Moen 2995 Chateau Three Handle Tub and...
Leaking hot water from delta single handle facuet
I have to assume you've unscrewed the face plate, not removed it, because you can't do that without taking the handle off. Delta handle usually come off by unscrewing an allen (set) screw just under the handle itself. Sometimes these are covered by a plastic plug.
Occasionally, even after you've completely removed the set screw, the handle still won't come off. Wiggling and pulling for a few minutes will generally get it off. If not, then a hacksaw, new handle and new cartridge are the answer.
If the allen screw is stripped and that's why it won't ome off, see above.
Good Luck.
Aug 26, 2009 | Delta & Single Handle Shower Faucet
How do I remove the single faucet handle to replace it.
Mar 22, 2009 | Moen & One Handle Tub & Shower Faucet
Moen single handle shower faucet, contstanly drips
Moen single handle - push pull has a screw beneath the handle cover plate. The Moen single lever handle has an allen wrench screw located under the curve of the handle. Once either one of these screws are removed, the handle should come off easily.
Once the handle is off, the water must be turned off and then you can remove the cartridge. Some cartridges are difficult to remove and may require a special tool. Most new cartridge packages have information on them to explain how to remove the cartridge.
Mar 12, 2009 | Home
Single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen & One Handle Tub & Shower Faucet  Logo
647 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
