Question about Raypak Pool & Spa
Error code cfh
Unit will not light. It says to clean the filter, but the filter is clean.
    Champion:
  • 305 Answers
Cfh is not an error code. it stands for "call for heat". back wash the pool filter. check continuity of pressure switch to ensure it is closing at proper pressure. jump pressure switch and if heater fires, there lies your problem
Posted on Mar 10, 2014
2 Suggested Answers
  • 44 Answers
SOURCE: I have a five year
CFH means "Call For Heat", and SPK is "Spark". It sounds like you are running out of gas.Propane tanks need to have 30% in the tank for a heater to run correctly,and after they are filled you must bleed the air out of the line.If you have Natural gas,the gas line may be too small to supply enough gas to keep it running. NOTE...gas pressure MUST be checked with the heater running.
Posted on Sep 28, 2010
Why do I get CFH but then no SPK?
CFH = Call For Heat
SPK = Ignitor is Sparking - attempting to ignite raw fuel
In a lot of cases, Pressure Switch opens up, CFH , is cancelled and therefor no ignition sequence.
try cleaning filter really good. If cartridge, may be time for an overnight soak.
May 21, 2015 | Raypak RP2100 DIGITAL POOL HEATER R265
Fault/error code GI/O
the error code you are getting is GVO. means gas valve open or stuck open. replace the gas valve
Aug 29, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
Dehumidifier Duracraft E1 error code on led display and red power light flashing. No action from unit.
HI.Error code 1 usually informs us that the filter needs cleaning.This might be needed qwhen the unit runs for 740 hours or more.So you need to manually clean the filter by removing firsst the cover then .you have to unscrew.remov e the filter located at the backmost part of the a/c unit.You can actually apply pressurized water to removed debris or apply detergent to soften hard debris.Thank you for choosing fixya.
Jul 29, 2011 | Heating & Cooling
What is CFH
CFH stands for "Call For Heat"
CFH means "Call for heat" and SPK means "Spark". They are status codes, not fault codes.
It basically means that the heater is turning on the heat mode and spark should appear shortly after the CFH code appears. At this point the heater should be igniting and the heater heating up.
If you are having a fault issue with the heater, please let us know if there is anything else that we can do for you!
Dec 16, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
I have model # p-m267a-nc-c it comes on I git error cfh then after a while i git hl2 and it wont heat after that. HELP Please TKS
"CFH" is Call for heat. That means your heater is trying to fire (not an error code). "HL2" is an error code which stands for "High limit #2". This error means the water in the heat exchanger is too hot,and the heater shuts itself down to prevent damage. Most common causes are poor water flow .Make sure the correct pump is running,and you have at least 10psi on the filter gauge. also be sure that the bypass valve is at least 1/2 way closed.The Bypass valve is located on the return line after the filter just passed the first tee.
Oct 12, 2010 | Rheem 266K to 399K BTU Swimming Pool...
I have a five year old Raypak 207A on my 500 gal spa. When I turn the unit on, the display shows: PV 1, then CFH, then SPK, then the burner ignites, then CFH again, then it displays the flame icon and...
Sep 28, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Pool & Spa Logo
173 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
