Why does stereo amp cut out at higher volume
I recently bought a Technics mini hifi system (SC-CH900) with a SU-CH900 amp and SB-ch900 speakers. The power cuts out when playing music at higher volumes. The higher the volume, the sooner it cuts out. There is an "E" displayed on the main amp display after the power cuts out. The power does not cut out when I disconnect the speakers ( I've checked the polarity of the speaker wires) or when I use headphones. In a TechInfo sheet that I found for the amp there are some instructions for remedying the problem, so I assume it is common. 1. Defective fan motor - replace the fan motor. 2. A faulty detector circuit - Mount a capacitor across both ends of the fan motor. 3. Smoothing capacitor (C571) used in fault detector circuit of output IC is possibly dry joint - resolder the capacitor. The fan works - it goes on and off depending on the volume. I assume this is normal behaviour. The fan doesn't seem to be on too long when the power cuts out. I can't really tell if there is a dry joint in the C571 capacitor without dismantling more.
  • Audio Player... Master
  • 5,113 Answers
You seem to have the answers to your question. I would just resolder the connections anyway without checking. If it solves the problem you have saved yourself a lot of money. If it doesn't follow the other steps in order of cheapness!
Posted on May 20, 2013
johex
  • 75 Answers
SOURCE: my sc-ch900 cuts out after a minutes playing. Is
did u play it real loud? if not, probably not. in most over load problems the system shuts down pretty fast. it will not take minutes if it has an over load protection. it is pretty hard to tell exactly what is wrong with that kind of sophisticated systems unless we take a look inside. it is probably bad power supply within the system. like i always suggest, if warranty covers-replace it. otherwise u have to get it fixed.
Posted on Mar 12, 2010
megatronix
  • 57 Answers
SOURCE: Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Posted on Jan 21, 2008
SOURCE: amp cuts out
The fan is ageing and putting noise on the protect line. Replace it or put a 100 uf cap across the fan at the plug. Beware polarity is marked wrong on p.c.b.
Posted on Feb 23, 2008
marsrover
  • 682 Answers
SOURCE: sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Posted on Mar 15, 2008
marsrover
  • 682 Answers
SOURCE: AMPLIFIER SU-CH900 CUT OFF
it goes to protection mode because it draws too much current from high bass.
Posted on Jul 28, 2008
Door won't open of Technics SL-CH900
Hi Robert,
probably the cd tray belt (a tiny black rubber belt that connect the tray rack with motor gear) is broken, check this by opening the player, if torn you need to buy a new spare and replace it.
May 30, 2016 | Technics Audio Players & Recorders
Searching for technics amplifier SU-CH900 or SU-CH700 i want to buy it ...i m from spain
Not a good brand to buy its low end. However thats an old model so you would have to keep looking on Ebay for something like that.
Apr 06, 2015 | Technics Audio Players & Recorders
Technics SU-CH900 turn off when the volume up ....
That's usually caused by incorrect loading (eg: 2 ohms on a 4 ohm circuit) or failed components in the power supply or final amplifier stages.
Mar 09, 2015 | Technics Audio Players & Recorders
I have a technics hifi su-ch900 everytime I play a cd or cassette or have the tuner the sound cuts out when its slightly loud, on low volume its fine. I have checked the cables and they are correctly...
I found a link to a CH900 that switched off completely.
If you are not a technician, please don't open the amplifier.
But I think it will be a simple repair. It is not the same problem, but it looks a little simelar.
http://www.electronicspoint.com/technics-su-ch900-switching-off-t53309.html
Also found a service manual, but not complete. Still here is the link
http://elektrotanya.com/technics_su-ch900.pdf/download.html
Oct 30, 2013 | Audio Players & Recorders
I have just bought a technics sc-dv290 hi-fi off of my cousin and found out the mid range and the tweeters have blown does anyone know where i could get replacent tweeters and mid-range speakers for it if...
As you probably know, these are the individual model numbers:
SC-DV290 the base unit
SB-DV290 speaker set
Front SB-DV290
Center SB-PC95
Surround SB-PS95
I'd scour Google or eBay for any or all of those models. Orphan speakers appear periodically.
Feb 10, 2011 | Technics SC-DV290 System
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
My sc-ch900 cuts out after a minutes playing. Is
Mar 12, 2010 | Technics Audio Players & Recorders
Jul 24, 2008 | Audio Players & Recorders
Technics hi-fi ribbon that links up from tape player to amplifier and so on is no good and i need to get another one. Can you tell me were i can get one from and if so what price am i looking at? Model No....
You can go to www.ued.net and go to the online ordering and click on the model number then enter the model # it will give you a list. Most of them just say connector. So you might want to go to the contact link and give them your model # and tell them what your looking for and let them research it for you . It may not be available due to the age . Good luck
Mar 01, 2008 | Audio Players & Recorders
281 people viewed this question
 Grubhead
Grubhead
