Question about Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
I need the connector Cable From J5 to J7 UIA 2417573 01 (Back Electronic Board) of the 241836001Thanks.Esteban Mosquera,
How can i Recover Deleted Messages from Samsung Galaxy J5?
You can have a try of data recovery methods, I think that is a good choice for data recovery. Anyway, if you really want the deleted data back, you should try every possible method. Those recovery tools can also have the possibility torecover deleted data I think,
Recover Deleted SMS from Samsung Galaxy
May 08, 2017 | Samsung Cell Phones
Getting an E61 error, I have replaced circuit board, replaced power outlet, checked breaker and checked for any visual damage to wiring/connections. Not sure what else it could be.
E61
Heater Relay failure
Heater relay stuck open or closed; Wiring defective
Check for short circuit across heater relay(s) (RL5, RL6, RL7) or L1 applied to heater relay output(s) (J5-2, J7-1, J7-3) with cycle stopped. Check for open circuit between L1 and heater relay connection(s) (J5-1, J5-3, J7-2). If no wiring problems are found, replace Electronic Control Board and retest.
Apr 04, 2015 | Dryers
When i power on my cannon 4412 printer it provide e202-0002 message
When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies: ( 1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
(2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
(3) Replace the Contact Sensor.
(4) Replace the Main Controller Board.
Apr 04, 2015 | Cannon Office Equipment & Supplies
Shows hE code, does not cool down
possible Heater Relay failure
Apr 02, 2015 | Samsung DV337 Electric Dryer
Hello... I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called Frigidaire. They said it was likely a shorted wire and put me in contac
http://www.manualslib.com/manual/417069/Frigidaire-Fase7073lw.html
you can read the error code E61 here
it says its a heater control relay or the heater element is duff
its prob corroded and worn out and needs replaced
"Check for short circuit across heater relay(s) (RL5, RL6, RL7)
If no wiring problems are found, replace Electronic Control Board and retest"
you can download the schematics etc also in the same manual
i think you need a tech too look at the heater now you know whats up
Dec 20, 2014 | Frigidaire Dryers
RM2451 works on gas not on electricity
bad board check heater element first
Dec 03, 2013 | Dometic RM2452 Refrigerator
Ewf1087 showing E62 and door locked
wait for 5-10 min. after turn off coz delay came from the pcb board,if not working anyway, i think the prob is in the door lock (defective)
Sep 05, 2012 | Electrolux EW1000i Front Load Washer
Elevation Will NOT go down after the elevation calibration
Unplug unit and remove motor shroud if you are savvy with a multi meter then try these trouble shooting procedure:
Perform and elevation calibration again, On the display, can you see numbers counting down and up and the treadmill is going up and down? If yes then the unit will proceed to work, if no when power is on, check on the lower board, on connector J5, do we have 5V DC between pin 1 & 3? If yes During Calibration, J5, between Pin 5 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 4 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 2 & 3, on the lower board, do we have DC voltage varying from 1.15 to 3.00? If any of the above is no then then the lower board will need replacing if all is yes then elevation motor needs replacing.
Jul 31, 2010 | RTO Bodyguard T200 Treadmill
Lexmark T630 has a 933 error. I have replaced the
933 - Mirror Motor - Locks/Lost Hsync* (*Horizontal Sync) Have you gone through this exercise yet: These errors usually indicate a failure in the HYSNC signal to the printhead. Check the continuity of the cables connected to J5 and J4 on the system board. If incorrect, replace the defective cable. The voltage at J4-1 measures approximately +5 V dc. If incorrect, replace the system board. The voltage at J5-7 measures approximately +24 V dc. If incorrect, replace the system board. If correct, replace the printhead assembly. Don
Apr 30, 2009 | Lexmark T632 Laser Printer
Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
14 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
