Question about Vehicle Parts & Accessories
1995 jeep comache
How to change a throwout bearing in a 1995 jeep comanche you tube
    New Friend:
  • 17 Answers
I haven't done one on this particular vehical but it looks like a hydraulic clutch to me. Good chance you are going to replace the slave cylander and bearing. I would since you are there. I've had slaves that come with the bearing on it. Just unbolt the slave from the trans and replace
Posted on May 03, 2013
How do I bleed the air out of my clutch system I replaced the clutch master cylinder and it or the slave cylinder doesn't have a bleed screw it's an 1987 jeep comanche
amazing 4 manual boxes then,. ill pick one
like my Comanche.
which engine? mine was the 4L , all show photos for that... only.
i had the 88, and have books on it.
it's old
that 5speed, is French Peugeot. trans. (my 99 was Mitsubishi box)
with a Peugeot, coaxal, (hidden) throwout/bearing and integrated
slave.
my 4wd, took me 10 long hours on stands to pull the trans.
in and out.
yes, that sux.
iv posted this and photos before.
searches can work.
the coax clutch has and extension tube , that passes through the bell grommet and has bleeder tip on that, yes , alien stuff.
26189380-3t1zcnjngeatxnm4yyvjcbdi-2-1.jpgphotos work , no?
all this is online
mitchels.
and alldata.com.
and very rare, this data is,,,,, this old.26189380-3t1zcnjngeatxnm4yyvjcbdi-2-3.jpg
May 09, 2016 | 1987 Jeep Comanche
Jeep wrangle squeals when clutch is pressed.
your throwout bearing is shot, and while your in there you should replace the clutch and pressure plate as the parts are relatively cheap but the process of dropping the transmission is rather involved. im not speculating it is definitely your throwout bearing
Apr 12, 2012 | 2003 Jeep Wrangler
Bad Throwout Bearing? I have a 1994 Jeep Cherokee Sport. Lately when my Jeep gets warmed up it will make a teakettle whistling noise. Note: this is a 5 speed standard transmission. The sound is more...
T.O. bearings usually do not make any contact when your foot is off the clutch pedal.
So it does not sound like a T.O. bearing.
But if it were an intake manifold leak, then it would idle badly.
You should be able to find it.
Listen through a piece of rubber hose, that you move around as a probe.
But if it changes when shifting, it is not likely an intake leak.
If it goes away when the clutch is pushed in, then it is likely the transmission input bearing.
If it is loudest when the clutch is pushed it, it could be the T.O. bearing, or the input shaft pilot bushing in the end of the crankshaft.
May 09, 2011 | 1994 Jeep Cherokee
I have a 1990 jeep wrangler, the throwout bearing in the clutch has gone out for the second time. Is there a way of using the linkage from a new model to eliminate the doughnut hydraulic throwout?
try using a bearing that is in a metal casiing and not a plastic piece of junk that comes in the clutch kit nowdays ,they always end up going wrong where bearing melts the holder ,unless you can fit a thin telecamit tube and a grease nipple so clutch bearing can be greased every few months like on a good old fashioned commercial vehicle
Jan 17, 2011 | 1990 Jeep Wrangler
How to change a front bearing assembly?
remove the tire,remove the brake assembly(should be 2 bolt on the back side), look behind the bearing assembly and there should be 3 bolts(remove those), now you should be ready to remove the bearing assembly note: you probably will need a puller.......good luck!!
Oct 05, 2010 | 1989 Jeep Comanche
Reverse wants to grind forward gears stiff engament
A new clutch is due for this Jeep then
The throwout bearing & pressure plate as well
Jul 12, 2010 | 1995 Jeep Wrangler
Coolent pressurizes and comes out tank by cap this is a1990 comache jeep.I just replaced the cap and that didn't help.
You may be experiencing a pressure feed from a failing head gasket or a faulty thermostat. Try running the engine with the radiator cap off and the coolant level at full and watch for bubbles at the cap opening. If you see a large amount of bubbles this could indicate a possible escape of cylinder pressure. If you do not see any bubbleling than you should possibly change your thermostat.
Apr 15, 2010 | 1990 Jeep Comanche
Swap a manual tranny into my cherokee
I believe it does...don't forget that you need to take the pedal assembly and hydraulic system along with the trans. Unless the clutch is nearly new, I suggest that you replace it and the throwout bearing, and make sure you don't forget the pilot bearing in the rear of the crankshaft. One item I can't remember for sure but make sure the transfer case matches the trans or use the one already on it when you change them over.Same for driveshafts.
Aug 06, 2009 | 1984 Jeep Cherokee
When i start my 1988 jeep comanche the tail light fuse blows
change the amp. of the fuse it should be higher than the former fuse you use.
Mar 07, 2009 | 1988 Jeep Comanche
Vehicle Parts & Accessories Logo
35 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
