Question about HP LaserJet Pro 400 M401DN Laser Printer
Datamax troubleshooting datatagger correctly - HP LaserJet Pro 400 M401DN Laser Printer
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
Tip
How to perform a quick calibration in a Datamax I-class printer
Before to perform a label calibration, check the label and ribbon are installed correctly. Also check the label sensor (the green piece above printhead) is in correct position and clean. To perform, press and hold FEED button and release after 5-6 seconds later. In display you can see CALIBRATION SUCCESS, if not, then do it again. Good Luck. Roberto Martinez.
on Sep 12, 2011 | Datamax I-4208 Thermal Label Printer
I have a datamax I series and I would like to know how to troubleshoot the stepper motor
What type of problem do you have?
Will the printer not feed?
There has been some troubles on early model of the Datamax I class printers that are detailed in a service bullitin on the driver/power supply.
If the printer feeds intermittently, or runs back wards(hunts) it is probably a board failure. I usually replace the board and the motor on exchange with DAtamax if under warranty.
Jan 21, 2011 | Datamax I-4308 Thermal Label Printer
HELLO!! MY EQUIPMENT IS DATAMAX DMX-1-4212 AND TO THE MOMENT TO STAMP THE RIBON WRINKLES AND ORDERS THE IMPRESSION WITH STRIPES
poor tension on the rollers?
try pulling the ribbon during stamping, if this corrects it then you may need a tech to come and reseat some drive gears.
Jun 10, 2010 | Datamax DMX-I-4212 Label Printer
Datamax I-4208 ribbon loading
Follow the arrow symbols stamped on the ribbon spool assy
Sep 24, 2009 | Datamax DMX-I-4212 Label Printer
Position fault error
The Datamax I4308 returns a position fault error if it cannot sense the label gap where its supposed to be, or if the sensor returns a value outside the permitted range. Re-calibrate to correct the error.
Feb 12, 2009 | Datamax I-4308 Thermal Label Printer
DATAMAX PRINTER
Hi
Its worth checking that you are using the latest drivers. You should be able to get these from the Datamax website. Also check the printer set up, gap sensor etc. Also check the media is loaded correctly. Hope this helps. Regards Stu www.labelzone.co.uk
Jun 19, 2008 | Datamax DMX E4203 Printer
Regarding Datamax E-4203 - Won't print
Check to see that the label sensor is over the gap in the label. It is just under the head on the right hand side.
You might also have the unit configured incorectly. If you go to the Datamax site, you can download the printer config program, It is easier to use than trying to push the buttons in the correct order to configure the printer.
Also use at least a 6" long label, and print the config file to see if you are set correctly for gap mode if using die cut stock.
May 16, 2008 | Datamax DMX E4203 Printer
Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
HP LaserJet Pro 400 M401DN Laser Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
