Question about Viking B36TII-SS island trim for 36" ranges and rangetops
T36TII Please help! I loved my Viking up until today. I need this trim piece and Viking Cooperate told me too bad!
The Viking gas stove - 6 burner - clicks constantly -- it won't stop. it has done this for years and usually goes off after a while but now it wont stop clicking. The burner that is not even on click.
The problem is one(or more) of the 6 switches that turn on the spark when that burner is turned on is shorted and stays closed (on) all the time.To determine which one it is the front face has to be removed,with THE POWER OFF a meter set to low ohms rating is used to check each switch by removing the wires to it and see which one has continunity (ZERO OHMS) when its off and that switch that slips on the burner valve shaft is the bad switch(s) and needs to be replaced to keep it from sparking all the time.
Please note though, in a perfectly working cooktop all burners spaks at the same time and only the only one that has the gas flowing to it will ignite,that part is normal.
I hope this helps you to repair your cooktop,
Gene
Aug 08, 2011 | Viking Professional VGRT362-4G 36 in. Gas...
HAVE A VIKING MODEL NUMBER VGRT360 THEE IGNITER ARE STILL TRYING TO LIGHT AFTER BURNER IS LIT.
Hi ghughes7,
Moisture or water is shorting out your ignitors. Please follow my below Tip on repairing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 05, 2011 | Viking VGRT360-6B 36 in. Gas Cooktop
I am very upset with my Viking Cooktop. It hasn't worked right since we purchased it 5 years ago. The same recurring problem has ruined my cookware and I don't understand how such a well rated cooktop...
Sorry to read about your problem, I hope this helps you out.
the issue is a bad gas regulator... some chance you have lp gas unit instead of a natural gas.
plus you have a defective switch for one of your ignition handles
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
How to assemble microfiber sectional couch
I need help assembling a microfiber section couch. I had the chaise on the left side (when looking at it from the front) of the couch and would like to move it to the right side of the couch. I can't figure out where to put the back pieces of the couch to fit right. PLZ HELP
Mar 09, 2010 | Viking Cooktops
Two of the 6 knobs on my gas cooktop are stuck and will not depress or turn.
Pull the knobs off
Spray some WD40 or release oil on the shafts , wrap a piece of tissue around them first to alow the stuff to soak in
Give it a couple of houts then get a pair of pliers and gently lift them up and down until the come free
If need be apply some more WD40 as you do that
Oct 20, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Viking Burners keep on clicking! Anoying!
The causes to the clicking is that the ignitors could be wet, dirty (with grease caked on them or cleaning products or a bad spark module). The ignitors are the little white things on the side of each burner with a metal piece on top. If they are wet (let them dry out for 20 - 30 min on a high flame, if dirty sand the metal piece on top with sand paper or nail file. And if it is the spark module and u are technical, order one from the parts department for Viking. You will need ur model and serial # then find out if it is located under the burners or the rear of the range. There are several wires going to the spark module. Best way is to disconnect one by one and connecting it to the new box until all wires are switched from old to new module. Remember to unplug the unit before doing this because you may get shocked. Also if it is a sealed burner system that means that the burner bowls cannot be lifted from the range and water cannot seap under the burners then you could just change all 4 or six burner bases. Viking has adapted them throughout the many complaints and they are better now. Typical cost is: $350 - $400 if spark module is under burners, in rear = $500 - $600. Burner bases = 400 - 600 depending on number of burners and if it is with a venturi or screws. Good luck.
Aug 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking pro 6 burner cooktop igniter won't stop clicking after lighting on two of the burners
Do not attempt if your stovetop is hot, you will get burned!!
This is an easy fix, the problem is your burners aren't lined up properly. Remove the iron grates (what your pots rest on) and the burner cap (the round black top on the burner) and finally the burner base (the round golden colored piece resting on the stainless stovetop). If you flip the base over you will see that it is keyed, meaning there is a grove that fits the indentation on the stove top. When you replace the base make sure to line the grove up with the indentation. If it's not flush with the stove top, slowly twist the round burner base until it falls into place. That's it!
Jul 09, 2009 | Viking Cooktops
Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Jun 03, 2008 | Cooktops
Viking B36TII-SS island trim for 36" ranges and rangetops Logo
253 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
