Polar Lift Fittness 9500HR
Need to install battery. Ware do I look..
  • 7,627 Answers
Perhaps this User Manual will help: http://www.sportsmith.net/images/product_support%5Clifefitness%5CBikes%5CConsumer%20Bikes%20Only%5CC-Series%5CC9_C9i%5CC9_C9i%20Bike%20Manuals%5COperation%5Cm05100k63a011%20%20C9i_C7i%20Bike%20Operation%20Manual.pdf
Posted on May 03, 2013
We have Lifefitness 9500HR Treadmill. I am getting a Bad Controller Error. We have two 9500HR models. I swapped out Controller, with working 9500HR and still get Error. Keeps going into Notify Maintenance....
I would suggest swapping the consoles to see if the problem follows. If this does not help you figure it out, you are more than likely looking at a wiring issue.
Sep 23, 2013 | Life Fitness Exercise & Fitness
9500HR Elliptical console does not light-up
Please proceed according with the steps mentioned1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Sincerely- G-d bless you
ernesto cuadra
managua,nicaragua
Dec 15, 2011 | Exercise & Fitness
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
Professional battery installation, doesn't turn on, is there a power on button? Or do I need to take it back and have them try again?
There are only a few Authorized Polar Service Centers. If you did not take it to one of these (which provide a 90 day warranty) they may have broken something or put in the wrong battery.
Polar and other HRM's are mini computers and actually quite delicate inside, they are not normal watches and while many watch repair places profess to be able to fix them, more often than not they cause a new problem. They are also repressurized with a special machine to keep them watertight, your watch is most certainly not watertight anymore and will eventually cause yoiu problems.
Too answer your question, no power on switch, if the battery install was good you would see a display. Take the watch back to the shop, and if they can not fix it, send it to Polar and then have the shop reimburse you for the repair. Polar will be happy to send them a detailed and Itemized account of what they had to fix.
Dec 03, 2010 | Polar FT40 Heart Rate Monitor Watch
How do I change the treadmill band on a 9500hr commercial treadmill?
Step one: remove the screws to calibrate allens belt in the opposite direction clockwise allens wrench 5 / 16 "
Step two: remove the screws above the deck allens wrench 5 / 32 "
Step three: with a flat screwdriver to lift the lever of the Idler belt and remove the drive belt motor pulley. be careful
Step four: remove the rollers carefully.
Step five: Remove the deck
Step Six: Remove the philips screw that holds the spray nozzle
Step seven: now carefully remove the belt.
to install belt now repeat these steps from back to front Once installed you must calibrate or belt slack to avoid turning the screws slide the meaning allens counterclockwise you can start with a speed 1.5Mph and increasing to 4.5Mph any questions send me an E-mail to cardiotech_me@hotmail.com
Aug 25, 2010 | Life Fitness 9500HR Next Generation...
Polar speed censor not working can I replace battery
The S410 watch is not designed to pick up a bike speed censor.
Detach the sensor from your bicycle.
1. Open the sensor by removing the two small screws, counter-clockwise, with a small screwdriver.
2. Lift the case off carefully. Hold the sensor cover upwards so that the PCBA (printed circuit board assembled) stays in the case.
3. Remove the PCBA carefully.
4. Press the battery holder gently. Release a hook of the holder from the opposite side of the PCBA and lift the holder upwards. Remove the old battery.
5. Insert a new battery with the plus (+) side facing up and press the battery housing gently so that it is attached to the PCBA at all corners.
6. Put the PCBA back into place. Attach the magnet by rotating it around the spoke before putting the metal cover on the magnet. Install the magnet at the same level as the sensor. The magnet must be facing the speed sensor. Or Attach the screw magnet to a spoke at the same level as the sensor. The magnet must be facing the speed sensor. Fine-tune the positioning of both the magnet and the sensor so that the magnet passes the sensor closely but does not touch it. The maximum distance between
the speed sensor and the spoke magnet should be 0.2"/ 5 mm. Once positioned correctly, tighten the cable ties securely and cut off any excess cable tie ends.
note: when you take apart and put back together the seal will no longer be watertight as these are pressure sealed.
Apr 19, 2010 | Polar S410 Heart Rate Monitor
How to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Nov 25, 2009 | Polar F4 Heart Rate Monitor Watch
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
Mar 12, 2009 | Life Fitness 9500HR Next Generation...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
