Troubleshoot ptac units - Heating & Cooling
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
If this is a heat pump unit, the defrost thermostat may be stuck closed
Dec 17, 2013 | Heating & Cooling
Old PTAC unit blowing directly on bed. How can I deflect or reroute air towards the ceiling?
Get a folding partition wall to direct the air around the bed. Aside from moving the ptac unit, that's about all I can come up with since you don't want to restrict the airflow with any close quarters diverter.
Dec 02, 2013 | Heating & Cooling
Ihave 50 ge ptac units that only the middle of evap.is getting cold
short of gas. Check for leak and arrest it. Then vacum and do gas charging.
Aug 18, 2012 | GE Zoneline In Wall Ptac Unit Air...
Finding a less expensive cover for my ptac unit
These units are changed out quite often. You should be able to find you a cover on line. Try any ac parts web site. Russ You will need model number of unit.
Jul 23, 2009 | Amana PTH123B25AM Air Conditioner
Charging a ptac
Either or, they both are the same ends but different routes..
Sep 08, 2008 | Amana PTH123B25AJ Heat Pump Air...
TRANE PTAC
You need to replace your control board, but if you are can repair it by your self you can change the relay that supply the fan and condenser.
Nov 15, 2007 | Heating & Cooling
Heating & Cooling Logo
251 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
