Question about SanDisk 1GB microSD Memory Card
Mm8gro1guaca-na i put it in my new phone and canot read it even when i connected to the computer ? and the phone not unmounted it ? it was for 20 days in a paper i put it
Binatone Homesurf 744 - put in micro SD card but nothing will save to it although it says it is there (can unmount it).
Please make sure the capacity of your microSD card is not larger than the maximum card capacity allowed by your device. For example, if the maximum card capacity allowed by your device is 16 GB and your card capacity is 32 GB, your device may not recognize it. And is the "unmount SD card" option grayed out or solid ?
Hope this helps.
Dec 16, 2014 | Cell Phones
Unmountable boot
Hi
You will need to get the original windows disk you was sent.
Put it in the laptop and run the 'RECOVERY CONSOLE'
this should bring up a command line, (command prompt)
Type :
1. fixboot
2. chkdsk /r /f
If they both fail you will either have to put your hard drive on a cradle and write another boot directory to it, or you will have to reformat it.
Mar 30, 2013 | Dell LATITUDE Computers & Internet
Need Manual for Alcatel one touch665
The manual for the Alcatel Simplicity One Touch 665 is available from the product site: http://www.alcatelonetouch.com/products/simplicity/ot-665.html . Click on the Download tab and you will see a drop down menu below Download User Manual. Select your language (and country) and then click Download. The direct link to the English version of the manual is: http://www.alcatelonetouch.com/contents/manual/Onetouch665%20-%20User%20Manual%20-%20English.pdf . The direct link to the English USA version is http://www.alcatelonetouch.com/contents/manual/Onetouch665%20-%20User%20Manual%20-%20English%20US.pdf . You will need Adobe Reader or a similar program to read the file.
I hope this helps.
Sep 21, 2011 | Alcatel Computers & Internet
My sd card is saying blank and unsupported
Is your computer able to read the card with an SD adapter? If so, back up any information on it to the computer. Put card back in phone and go to settings->storage->unmount SD card->then format SD card. Allowing the phone to format the card usually has better results than formatting it in Windows because it's going to use the correct file system type.
Hope this helps
Ray
Mar 02, 2011 | HTC G1
When I connect my htc with google phone to my computer to transfer pictures the phone is not recognizing the connection
You will need to tell the phone to act like an external card reader. By default, when you connect your phone, it will just charge. You need to mount the sd card and your computer will be able to read the contents.
Pull down your notification screen. It should say "Charge only". Press that and it will come up to a screen where you can change the behavior of the USB connection. Select "Disk drive" and your SD card should pop up on your computer.
Remember when you are done, you will need to reverse the above steps to unmount your SD card. It is just like removing a flash drive in Windows. You do this to prevent data loss and corruption.
Good luck.
Oct 15, 2010 | HTC Hero Smartphone
What are the smart MMS/GPRS/3G settings for W705? i keep calling customer servise of smart network but they just keep telling me they will send the settings to my phone. already 1 week now but still i...
my gosh! u have the same situation as mine..my phone is sew705 as well..just this morning i went to smart wireless center to personally have my internet settings activated..because like you did, i called the customer service and they just kept on telling me to wait w/in 24 hours to receive a confirmation settings..but..nothing happened..so at the smart center, yes, i did had my phone settings activated.. kaya lang, kahit na activated na ang 3g/gprs/mms settings ng phone ko.. wala pa ring nagyari!!! everytime i try to connect to the internet, "connection failed" pa rin!! coz there, i found out that their lists of handset aren't updated.. wala pa silang phone settings for sew705.. kaya ang ginamit na settings ay yung sa sew700i..but still, i'm hoping na sana after few days.. eh, ok na yung connection..
so i guess, better go to smart wireless center na rin for immediate results.. and see for yourself.. baka naman maging ok ang sa phone mo... :-)
Mar 08, 2010 | Sony Ericsson Walkman W705 Cell Phone
Canot read after refill
You need to shop online for either a chip resetter or replacement chips. You can't refill Canon inks without a new chip because the chip tells the printer that the ink is empty even when you add more ink.
Jan 19, 2010 | Canon PIXMA iP1600 Printer
Is there a way to repair or replace the magicjack adapter?
Go buy a new one for $40 at Walmart - KEEP YOUR RECEIPT AND PACKAGING!
Wait one week and simply put the damaged MJ back into pack and return it (within 90 days of purchase)- the store gets credit and you get a new jack, phone #, and your year of service begins anew - no one takes a loss - store gets credit and you don't have to mess with MJ's non-existant customer service -
Note: I have done this 2 times as I get VERY POOR QUALITY CONNECTION on MJ and still cannot figure out a way to improve my connection quality- any suggestions??
Apr 10, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Feb 06, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
I can't figure out how to get music from my computer to my new google phone
Before connecting the USB lead you must Un-mount the SD card in the phone. To do this you need to go to settings\sd card &phone storage\ unmount or eject sd card. Once this is done connect the USB lead and your computer should find new mass storage device and label it as an exrternal drive. Simply drag and drop your music into the music folder on the new drive.
Note: When youve finished you need to go back to the phone and mount the drive back on the phone following the same steps I described at the begging.
Hope this helps. Karl
Jan 10, 2009 | HTC G1
SanDisk 1GB microSD Memory Card Logo
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
