Question about Tally T6218 Matrix Printer
CONFIG 1* ERROR CONFIG 1*
    Novelist:
  • 169 Answers
If the printer is showing "CONFIG 1*" this is not an error, this message is simply advising that Menu CONFIGuration 1 is selected hence the * beside the message.
Assuming the settings in CONFIG Menu 1 are correct if you send data to the printer in the correct format it should print.
Posted on May 22, 2013
C++ error is appears
Error "Microsoft Visual C++ Runtime Error..." appears on launch
Problem:
When launching PDF Converter Professional 4, a Visual C++ error may occur which refers to autoupdate.exe.
Cause:
This issue may occur if there is a conflict with the Auto Update tool.
Solution:
In order to resolve this issue, we recommend using either of the following solutions:
Option 1 - Edit the system registry
  1. Click on Start > Run.
  2. Type "regedit".
  3. Navigate to HKEY_CURRENT_USER\Software\ScanSoft\PDF Professional 4.0\Config\
  4. Click on AllowWebUpdateOnInit = 1
  5. Change the 1 to a 0 (zero).
  6. Navigate to HKEY_LOCAL_MACHINE\Software\ScanSoft\PDF Professional 4.0\Config\
  7. Click on AllowWebUpdateOnInit = 1
  8. Change the 1 to a 0 (zero).
Option 2 - Disable automatic updates.
  1. Disconnect the network connections by doing the following:
    1. Click on Start > Control Panel > Network Connections.
    2. Choose each, right-click and chose "Disable".
  2. Try to launch the program.
  3. Disable the automatic update by clicking Help > Nuance on the Web and uncheck the Automatic Web Update entry.
Jul 21, 2011 | Computers & Internet
Tip
How To Fixed Corrupted or Missing \WINDOWS\SYSTEM32\CONFIG
If you get the error:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Enter in the administrator password when requested
  5. cd \windows\system32\config
  6. Depending on which section was corrupted:
    ren software software.bad or ren system system.bad
  7. Depending on which section was corrupted
    copy \windows\repair\system
    copy \windows\repair\software
  8. Take out the CD ROM and type exit
on Sep 20, 2010 | Computers & Internet
Error code 1 - reconfig message
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Feb 08, 2011 | Stairmaster 4400CL Stepper
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
Jan 18, 2010 | Cisco ASA 5505 Firewall
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
May 23, 2009 | Cisco ASA 5510 Anti-X Edition...
Tally6215 "Config 1" Error
The 'Config 1" message on the T6215 is not indicating an error message, this message is simply indicating that Config 1 of the 10 configurations that you can set on the T6125 is loaded.
With the Config 1 message loaded you should still be able to print so long as the printer is ONLINE and does not have any other error lights on.
If the printer is not printing I would recommend printing a configuration page to check the printer is working OK.
To print a configuration page follow these steps;
Put the printer OFFLINE
Press the MENU BUTTON
Press the DOWN ARROW to HELP
Press ENTER
The printer should print a configuration page, if this prints correctly I would recommend checking the settings in particular the Interface and Emulation settings.
I would also recommend checking connectivity between the system and the printer to check the print jobs can get to the printer.
Also check the system to ensure the correct printer driver and printer setup is being chosen.
Mar 26, 2009 | Tally T6215 Matrix Printer
How do I clear a "config 1" error on my tally t6218 printer
Click start>run>type services.msc. The services window will come up and you can right-click on the Print Spooler and then click Restart. This will clear the print queue and hopefully allow you to print. Good Luck. Let me know if you have any questions.
Feb 28, 2009 | Tally T6218 Matrix Printer
I nees to setup Quintum A800 for termination can anyone help me
Command line for termination A800 (Quantum)
Config unit 1# online 1
Config sys# mindn 10
Config sys# maxdn 20
Config pstntg 1# pass 0
Config pstntg 1# cassig 6
Config pstntg 1# super 3
Config pstntg 1# lamp 1 country code (91)
Config pstntg 1# Answerdel 120
Config pstntg 1# lamp 1 9101 01
Config pstntg 1# dis 1 a (ALL - ports)
Config pstntg 1# ena 1 a (ALL – ports)
Config gkadmin allow 1# ip xxx.xxx.xxx.xxx (GW ip + switch-ip)
Config dsp# voice 81 (for g723) voice 68 for (G729)
Config# submit
Local information
Name of this zone Hello
Country selection Canada
Local country code country code (91)
International prefix country code (91)
Hop-off PBX Numbers
91 public
9101 01 public
This configuration for termenation
Nov 20, 2008 | Quintum Tenor A800 (501-0026-00)
Bios setup problem at booting.
Make sure the BIOS Configuration Jumper is in the 'Normal' position (pins 1 and 2) and not in the Config position (pins 2 and 3). It is located near the battery at the corner of the board. The Manual and Config information can be found here.
Mar 14, 2008 | Intel D845GVSR Motherboard
Tally T6218 Matrix Printer Logo
64 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
