Question about PEAK Pkcojn 12 Volt 9 Can Cooler / Warmer
Power cord looking for a power cord for this unit that plugs into the car cigerete lighter.
Where is the fuse for the cigerate lighter in the 2001 monte carlo
passenger side panel of the dash, the cover should have number for locations of fuses and what circuit they are for, if you don't find your problem there look for the fuse panel under the hood
Sep 14, 2014 | 2001 Chevrolet Monte Carlo
I have a 1989 cobra 29 Ltd classic cb. It got water spilt on it sitting on my tabble so I took the covers off and took a heat gun to it and dried it. I also disconnected the internal speaker and left it...
# 1 you should never dry out a radio with a heat gun.#2 the reverse polarity diode is what is blowing out. take that wire you fixed and toss it.go to Rad Shak or a truck stop and buy a power cord with a lighter plug attached. .Then have someone you can trust replace d23. hook up your coax then your cord turn it on and you are good to go.
Aug 01, 2013 | Radio Communications
Air cond fan and cruise control and cigerete lighter not working
Go to this site and see if the owners manual is available for what ever you have, you gave no model or year to look this up.
Aug 18, 2012 | Chevrolet Malibu Cars & Trucks
Whistler 1730 keeps blowing fuses. no other problems with cigarette lighter plug
Is the lighter socket fuse blowing or the fuse in the unit's power cord? Have you tried another power cord from a Friends radar detector? If it doesn't blow that power cord's fuse, then your power cord is bad. If it does blow the fuse in the other power cord, there could be something wrong with the unit. Contact Whistler at info@whistlergroup.com
Jun 15, 2011 | DE-1730 Radar Detector
No cigeret lighter cant plug anything in.Where is fuse box, in what section of the car is it located
THERE ARE TWO FUSE BOXES, ONE UNDERNEATH THE HOOD AND ONE ON THE DRIVERS SIDE UNDERNEATH THE STEERING WHEEL AREA YOU HAVE TO GET IN THE FLOOR BOARD AND LOOK UP AND THERE SHOULD BE A COVER WITH A FEW SCREWS AND YOU HAVE TO UNSCREW THEM AND THE FUSE BOX SHOULD BE LOCATED UNDER THERE.
Dec 20, 2010 | 2005 Cadillac CTS
LIGHTER SOCKET NO LONGER CHARGES MY PHONE. NO LIGHT IS TELLING ME NO POWER
check the fuse for the lighter and accessories if not blown check the wiring with test light if have power you may need a new cigerete socket
Sep 25, 2010 | 2000 Dodge Caravan
I DO NOT HAVE THE POWER CHARGING CORDS... ONLY THEAIN PART OF THE LIGHT/INFLATOR . WHAT POWER SUPPLY CLORD IS USED?
On the side of the unit is a small black flap that covers two prongs that you can plug a standard 110-120 volt extension cord into which will charge the unit. There are 3 read lights and 1 green lights on the top that lets you know when it is fully charged. The 12 volt charging cord is basically a cord that has 2 cigarette lighter plugs. One plugs into the unit and the other plugs into a power port/cigarette lighter plug.
Jul 16, 2010 | Vector 1 Million Power Series Spotlight &...
Garmin street pilot 330 charging problem
Linda,
You need to check the fuse for both the car's cigar lighter AND the one in the GPS power plug (that goes into the cigar lighter outlet). Both must be good for the GPS to charge and power up.
I don't know if your friends cord worked in you car - or hers - so you're going to have to find out if it is the cord fuse or the car fuse. Since her cord worked on your GPS, start by using HER CORD connected to YOUR GPS in both cars. If it works in her car, but not in yours, check & replace your car's cigar lighter fuse. If or when it works in both cars, disconnect her cable and connect your cable to your GPS again. Connect into your cigar lighter. If it works, you're done. If it doesn't work, disassemble the plug at the end of the GPS cord (cigar lighter end) and check and replace the fuse if blown. You should be good to go at this point.
Please rate this reply if found to be helpful - good luck!
Jul 07, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 12 volt power cord
Could be the cord or your car plug. Does it fit snug? I have a 1996 Acura TL and the way the cigarette lighter is designed, I have to give it a bit of pressure so it makes good contact. try your unit in another vehicle and see if that solves the problem. If so, it's your car's cigarette lighter connection.
Jul 21, 2008 | Garmin nuvi 200W GPS Receiver
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
PEAK Pkcojn 12 Volt 9 Can Cooler / Warmer Logo
29 people viewed this question
Top PEAK Electronics - Others Experts
Don Numinen
Don Numinen
Jerry Kramer
Jerry Kramer
KeCa
KeCa
Are you a PEAK Electronics - Other Expert? Answer questions, earn points and help others
