Citizen c32604hd b
TV JUST HAS BLACK SCREEN WILL NOT POWER UP
Have an old Citizen ST760 handheld tv. What powers it. How do I get it going again?
Hello -
See this YouTube video about the Citizen ST760 TV: https://www.youtube.com/watch?v=F5V_GGB3vqA
The person talking on the video mentions batteries powering the TV. From the video, it looks like the opening to the battery compartment is on the right side (when looking at the TV screen.) Also, if you are in the USA, even with battery power, you will not be able to pick up any TV stations with the hand-held TV because it has analog TV reception and there are no TV stations broadcasting analog in the USA.
Dec 16, 2017 | Citizen Televison & Video
I have a Citizen flat screen TV model LT 2010. I just want to use my Jumbo Universal Remote Control but I dont have the codes. can you give me the codes for TV so that I can control my Flat...
here are some tv codes that you may find for your citizen tv model.the list are 002, 112, 319, 402, 407, 502, 512, 701, 805, 906. aside from those code click this universal remote control which have tv codes it might have compatible to your unit.make sure the remote control was properly set up so that the tv unit must recognized the codes. good luck i hope it will help you.
Jun 04, 2011 | Televison & Video
I have a Citizen C802DVD, that is dead, no power at all, what can be the problem? thanks for your help.
Instructions
    • 1. Press the power button on the TV and not the remote control. It is possible the remote control's batteries are dead. If the TV does turn on, you know you need to replace the remote's batteries.
    • 2 . Disconnect the power cable from the TV, then insert it into a different electrical outlet. On occasion outlets are damaged, and do not provide a power current. If this is the case, changing the electrical outlet connection corrects the problem.
    • 3 . Switch the television's input to a different connection. It may be possible you have the wrong input selected, causing the TV to give off a black screen.
    • 4 . Connect a different source device (such as a DVD player or cable receiver) to the television. If the source equipment is damaged, you will not receive an image from the hardware. If the TV still does not display an image, there is an electrical shortage in the interior of the TV. To see if there is any way to fix this issue, you need to take it into a local TV repair shop.
Feb 02, 2011 | Vizio 42 in. LCD TV
Citizen TV model #JCTV3072
This is a very obscure set as there is nothing online about it! If the picture is rolling, that means it is an old tube set? Old technology, and not really worth trying to to do anything with it. Televisions never have an internal aerial. One the most basic table top with a 6" screen there is a pair of extending antennae and a coaxial cable socket.
I have edited your question to remove 'Hi There' and put in the television details in case any other of the Experts have come across this set.
Citizen TV JCTV3072 Google Search
Feb 18, 2018 | Citizen Televison & Video
U-Verse remote for Digital Lifestyle
I use my Directv remote to change the channel. What you have to do is go the your direct tv remote go to setup then go to remote then look for tv brand Citizen then follow the direction the menu tells you to do. It works fine. You can use Tv Brand Citizen, Concerto, Luxman They work with any u-verse remote 4 digit code 0056 5 digit code 10056
Aug 13, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Citizen house tv that has a 'lock' logo on screen
The TV has been 'Locked'. To unlock it press the DISP button for 4 seconds. Since you have a universal remote and there is no way to determine which button is the DISP button try holding each button on the universal remote for 4 seconds until, hopefully, you find the correct one.
Mar 10, 2008 | Televison & Video
Tv problem
shut off the close caption, the caption is is in text mode and needs to be changed to CC1. the remote may have a cc button on it push it until cc is off.
Feb 27, 2008 | Televison & Video
Set color on my LCD TV/monitor
i have a lg lcd.
and it colour scheme is very high
please give me suggestion for his colour setting
Oct 26, 2007 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
