Question about Toshiba Satellite Computers & Internet
Computer hang automatically restart
I change my hdd due to it was damaged when i start to open after 2min. it will hang up or sometimes it is restarting automatically. what is the problem of my laptop?
  • Toshiba Master
  • 7,627 Answers
What OS did you put on the new HDD?
Posted on May 03, 2013
SOURCE: Web cam problem
Try installing the below hotfix
http://support.microsoft.com/hotfix/KBHotfix.aspx?kbnum=931812&kbln=en-us
Posted on Jun 02, 2008
  • 18 Answers
SOURCE: backlight
If you are running windows, you might have to re-install your operating system, if that doesn't work, you might be having a bad system board and or memory.
Posted on Jun 10, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Windows Vista crash/hang in Dell Inspirion 1525
Disable the turbo memroy driver and see if it will let you go onlin, if so download the driver or updated driver (if any), then unistall and reinstall it. If it won't allow you to do this, then try a system repair with your recovery or operating system disc.
Posted on Jul 23, 2008
hokuwho
  • 306 Answers
SOURCE: Webcam not found
I have found that if the webcam software has a program that automatically starts its own OEM program then you have to open that program and find the settings for turning it off or on. Two programs will not want to share a webcam.
Posted on Oct 14, 2008
  • 1170 Answers
SOURCE: Qosmio G35-AV600 boot problems
You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
Thank You, Arjun
Posted on Apr 01, 2009
My Intel D915GAG mobo works OK with one PATA HDD. But when I try to connect a SATA HDD mobo behaves strangely: sometimes it hangs up sometimes windows (in PATA master) won't start What I...
Intel D 925 has sata 1 controller , therefor your sata 2 or 3 drive can be malfuncton with this old controller , pls connect the jumper to sata 1 speed limit position in your hard drive near the data connector
Sep 25, 2017 | Intel D915GAV Motherboard
My pc is hanging due to hardware problems as i have already sought out the problems of software by formatting it ,& refreshed by all conditions.please suggest me for my this solution please?
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start all programs accessories system tools system imformation you will see all of your computers imformation from there another way of doing this
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer if you see something running that you don
Apr 26, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have HCL Beanstalk Desktop, Monitor - Samsung Syncmaster 794MG. I don't have a ups. I get frequent powercuts in here resulting in interrupted shutdown of the computer. Sometimes while playing a game...
You seem to have a corrupt display card. Is it on board or do you have a separate graphics card installed in your PC. Either way on restart graphics processor is not turning on. What does the Power and HDD indicator on the PC show during boot up. You could also have damaged the Hard Disk because of your abrupt shutdowns. You can open the side cover and try disconnecting the HDD power (Yellow, Black & Red ) cable and IDE ( 40 pin flat ribbon wire ) cable and try restarting. If your monitor starts up and shows BIOS page you have a faulty HDD. Also see if the processor fan is a working when you start the PC. If not you have a failed mother board. Are you getting the boot up RAM beep. If not before you do any of the above mentioned things Just pull out the RAM ( with PC unplugged ) and reinsert into the slot. It might get your PC working after all
Mar 08, 2011 | MSI Computers & Internet
Booting problem, blue screen comes with so many words and automatically restarts. not entering into normal mode
The blue screen is BSOD(Blue Screen Of Death). this happens due to some technical problem in HDD or due to bad sectors in memory. Its time to change the HDD, backup important data and files before its too late.
Nov 10, 2010 | Dell Inspiron 1525 Notebook
How do I know if the HD is damaged? I suspected HD failure due to the following? computer won't start. It says, "invalid Boot.INF file." And then, it say "press Ctrl+Alt+Del to restart". What could it be?...
It is probably BOOT.INI. However, might be anything from a virus to manual mistake, altho this file should be hidden.
HDD Regenerator: http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Regenerator.shtml free trial will help you check the HDD.
Nov 12, 2009 | HP Pavilion 533c (P9939AR#ABA) PC Desktop
After fdisk and format of hdd install of os freezes after 2min. when it says windos is starting, tried differant versions of windows does the same thing!!!! Please help!!!!!!
PXE media failure means the system is trying to boot via Network card not your hard drive. When you performed fdisk then formatted the disk, you might have not selected an active or logical partitioning to support the OS. Run the PSA diagnostics by holding the Fn button before turning on your computer. If it gives you an error, it means your HDD has gone bad and needs to be replaced. If it freezes during the the loading of files during the installation, it means that your RAMs are bad because the windows loader dumps all the information to the RAM chips. If it does hang during the installation of files, two points of failure are to be looked upon, the RAMs and the HDD. I recommend you reset the BIOS to the factory settings as to reset the boot priority so it does boot to HDD first, not to any of the bootable drives available on your computer.
May 15, 2009 | Dell Inspiron E1405 Notebook
My motorola l6i getting hang and restarting offen
i hav a motorola L6i set of 2006...some time...it becomes struck or hang...i hav given it for service many times..thay changed thier key pad,bubble pad etc...they told me to change it and buy a new one...i hav spent more than 500 rs for repairing it...still it automatically sometimes get hang...is it worth to keep it...or buy a new one???or d problem can b solved??
Apr 04, 2009 | Motorola Mobility L6I Cellular Phone
Computers & Internet Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
