Question about Brother Fax Print Ctdg Intellifax 900/950/ 980/1500M
Brother Error Codes 81
Old machine. Always worked. changed paper from letter to Legal. Then error code 81 and machine will not copy or fax
jackboy
  • 2985 Answers
SOURCE: Paper jam
The various parts that open up to allow access are monitored by a micro switch. Switch the machine off and open all the access points locate the switch and make sure it is freely working and the connections are all in place. Then come back
Posted on Jun 06, 2007
checkitright
  • 1362 Answers
SOURCE: error code fax
check this link and go to error codes/fax error
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Posted on Nov 27, 2007
bowdo
  • 78 Answers
SOURCE: brother fax machine intellifax 2600
Fuser or overheat error it will probably be followed by a 77. Menu, mode and 0 quickly in that order will give access to user maintenace mode (lights will flash once your into the mode). Hit 91 to reset the machine. If this doesn't work you have a major problem with your fuser unit and it will need to be replaced. DO NOT DO THE ABOVE PROCEDURE MORE THAN ONCE AS YOU WILL START TO MELT STUFF IF THERE IS A MAJOR PROBLEM.
Posted on Feb 07, 2008
alvinbga
  • 130 Answers
SOURCE: Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
Posted on Jun 11, 2008
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
I have a Brother Intellifax 1250, getting error 81... Other than older than dirt and throw away, can anyone tell me what that error code is?
Well the scanner is gone there is no parts . Brother dose not support that old of unit any more. (sorry) spend some money and get you a new unit. They were a good machine in there day.
Jul 21, 2010 | Brother IntelliFAX 1250M Fax
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Everytime I receive a fax, the first page prints out then I get a "Check paper size" error
Sounds like you have the paper size in the tray set incorrectly. For example, it may be set to legal, but you have letter size in the tray. This would cause that message to display. Check your setup options for the paper setting.
Jul 14, 2009 | Brother IntelliFAX 4100 Laser Fax
Com error
Two simple Solutions to the annoying COM.E-2 error problem on a Sharp FAX machine:
Get rid of your DIGITAL FAX line and go back to an old ANALOG phone line.
OR
Buy yourself a Canon, Rico, or Brother FAX machine.
(SHARP doesn't even have a list of their own error codes: Just like the place Dilbert works at, in the comic strip.)
This fix is Guaranteed to work.
Apr 01, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Redued size of legal contracts on receiving fax sent to
HELLO! THE PROBLEM IS NOY ON YOUR END, THE MACHINE AT THE OTHER END HAS TO BE SET UO FOR LEGAL PAGES.SOME PEOPLE HAVE TRAY FOR LEGAL AND ONE FOR LETTER, THEN THE MACHINE WILL CHOOSE IT AUTOMATICLY. GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFax-4100e Fax
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Reload paper error
Listen for the paper tray is popping up when you push it in.
Remove the paper tray completly and look for paper in the cavity.
Jun 24, 2008 | Brother MFC-8220 Fax
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
Brother Fax Print Ctdg Intellifax 900/950/ 980/1500M Logo
20 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
