Question about Sport & Outdoor - Others
2000 Great Basin
How to fix Great Basin 13' x 10 screen arbor tent, having a hard time putting up the tent .
  • 4 Answers
Thanks When you're ready to step up to the world's finest <A HREF="http://detectorsforgold.com/gold/category/metal-detectors-gold">metal detectors</a>, you're ready for Bounty Hunter. And get set to dig deep. Not into your pocket, but into the ground. That's because genuine<A HREF="http://detectorsforgold.com/gold/bounty-hunter-tracker-iv-metal-detector.html">bounty hunter tracker iv</a> can pick out virtually any metal object from any terrain - yet even with all their features, they are surprisingly affordable.
Posted on Jul 02, 2013
How to assemble wenzel tents
Contact Wenzel at
Toll Free: 866-98.WENZEL (866-989-3693) or 718-534-0720
Fax: 718-497-2168
Mar 04, 2015 | Wenzel Great Basin 9 - person Tent
Set up lakefield 10MAN TENT 2000 FRAME
Sorry I'm very late to the party, but I was just looking for the instructions for my own Lakefield 2000 tent which my bro borrowed some time ago. It's a great family tent - but not that straightforward to pitch. Eventually the instructions turned up, so I'm posting them for some other poor soul who's really stuck!61ec3342-f228-41d3-895c-127c2c5ffe3b.jpg
Jan 17, 2013 | Sport & Outdoor - Others
Can I use a grill under my tent?
Absolutely not, the smoke from a grill will damage the fabric of the tent. All grills must be far enough away from the tent so that no smoke is allowed to enter the tent. The tent is made of very flammable fabrics so there is a great risk of causing a fire while grilling under a tent, just put the grill outside it will be more pleasant to stay inside not smoky tent.
Jul 31, 2012 | Camping, Backpacking & Hiking
How do i put up an americana arbor screen house. I lost the instructions
the top pole go in the order 123, the outer box is 454, and the big poles are the legs
Aug 13, 2011 | Texsport Big Sky Room Family 01327 Tent
Hi, we have a AMMCO 7750 brake lathe, the problem is runout in the ARBOR we have replaced the arbor but still have the same result. We are unsure of hat is causing this so any help or advise would be...
First off--your model Ammco is their "El-Cheapo" model.
Yeah, they work, when they work that is.
I doubt that your problem lies within the spindle bearings. But it could-- I suggest that you tug on the spindle to see if you get any back and forth end-play, or up and down play.... if so, you are screwed. This machine is not worth the effort, money and time fix this problem.
As for the arbor...
This model uses the same arbor that the better 3000, 4000, 4100, 7000 and 7100 models.
Every time you replace an arbor (new or used) you have to...
A. Lap the arbor into the spindle using lapping compound (just like lapping valves in a cylinder head) The lapping compound is then cleaned out of the spindle and off the arbor, then...
B. You then have to check the "runout" with a dial indicator. These are obtained cheaply at Harbor Freight FYI. With the dial indicator mounted (magnetically) on the twin-cutter check the arbor run-out. The runout (two inches from the spindle) should be no more than 1 1/2 thousandths. One thousandth or under is optimal. Any reading over 8 thousandths cannot be straightened.
C. If the run out exceeds 1 1/2 thousandths, you have to then straighten the arbor.
To straighten the arbor you will again need the dial-indicator and a heavy copper hammer....
With a wrench on the end of the draw bar (far right on the end of the drum gearbox), rotate the machine (counter clockwise) until you find the high spot on the arbor (carefully watching the dial-indicator).
Remove the dial indicator and give the arbor a whack with the hammer (not too hard if this is your first time) when the high spot is directly straight up.
Install the dial-indicator and check the run-out again.
Sometimes you will get it on the first whack--sometimes you will have to go through an ordeal until you get the arbor in spec.
And remember--sometimes you can bust the arbor completely off on the first whack. They are hardened and allegedly tempered, but some are more hard than others. If it breaks off--tough luck. You need to get another arbor.
I have personally straightened arbors more than 30 thousandths out (once)... and I don't want to repeat that ordeal. Sometimes arbors cannot be straightened (bent in strange ways) and cannot be straightened.
When loosening a rotor, do not allow the work to dump onto the arbor. This is the main reason they go out of whack.
Buy Sell Used Brake Lathes Brake Lathe Parts
Jun 29, 2010 | Ammco Combination Disc/Drum Brake Lathe
We need instructions for a Thermos pop up tent. we bought at a yardsale with no instructs.
Is it the tent with the plastic staves? If so, just put them together and insert the rounded end into the equivalent hole on the bottom of the tent. Sit the tent upright with the doors open. Reach into the top of the tent and push/pull the chrome lever at the top until it locks into position. Sometimes you have to wiggle it around a little to get it to lock. When it does lock, you will know it because the tent is rigid. This is a great tent. We have used one for over 40 years! When you want to disassemble it, just pull down on the chrome lever at the top of the tent and reverse the procedure.
Oct 12, 2009 | Sport & Outdoor - Others
Ripped outwell tent
log onto http://www.imagescotland.com/scottishmountaingear-home.asp
this is outwell's recommended repairer!
Good luck
ps. putting the pins in is very tricky - needs strength and patience!
Jul 30, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Where can i get assembly instructions for great outdoor tent
You can get instructions for Great outdoor tents if their not too old from Great Outdoors Hastings
Dec 22, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Sport & Outdoor - Others Logo
455 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
