Sewing Machines Logo
Elizabeth Keller Posted on May 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Feed Dogs wont move fabric on a Viking Prisma 990
The feed dogs on my viking Prisma 990 will move up and down but wont advance the fabric back, the stitch length is set and the button for dropping the feed dogs is not engaged. So they will only move up and down in place. It worked one day and I went to sew on it the next morning and this problem happened.
Debbi's Sewing Machine Repair
Level 3:
  • Sewing Machines Master 7,365 Answers
  • Posted on May 04, 2013
Level 3:
Answers
7365
Questions
Helped
1744240
Points
19451
The feed dogs need to be checked, they may need some type of adjustment.
1 Related Answer
  • 7365 Answers
  • Posted on Apr 12, 2012
SOURCE: Settings with stippling foot for Viking Emerald
try youtube & ehow
are you using the correct needle & thread for the fabric
1helpful
My viking 940 prisma feed dogs only go up and down and won't feed fabric through?
The machine does not feed the fabric The stitch length is too short. Press the + button. The feed dog may be lowered. Raise it by pressing the feed dog button. See page 9. The presser foot pressure is disengaged. See page 9. The feed dog is full of dust and dirt. Clean with the brush.
http://www.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Viking-940-Prisma-x-pdf.PDF?ext=.pdf
http://www.husqvarnaviking.com/SiteFiles/ClientSite/13/13decadb-ece8-4cd2-a779-f571ae08edad.pdf
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Feed dogs not pushing fabric through
Remove the needle plate and make sure there is no lint obstructing the feed dogs. If they are clear, it is usually the feed dog step motor gone bad. You should have your machine serviced by an authorized Husqvarna Viking dealer. You can find your nearest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Viking emerald 116 sewing machine will not feed fabric
Look at the feed dogs (the serrated metal strips on either side of the hole the needle goes down thru). If they aren't moving when you turn the handwheel or not protruding above the sewing surface (needle plate) then 1 of 2 things has likely occurred.
#1 - your machine is equipped with at feed-dog drop selector (drops the dogs down for free-motion sewing) that you have activated (intentionally or not) or
#2 - you have enough lint debris accumlated under the sewing surface to stop the dogs from coming up properly or move all together.
Have the machine professionally serviced. A good servicing will resolve 60% of the problems that sewing machines incur. You should have the machine serviced at least every 100 hrs of sewing, more often if you use cheap thead, cheap fabric or metallic threads. All of these leave a lot of debris inside the machine.
3helpful
I need to know how to lower the feed dogs on my Huskystar Viking E10
There is a switch on machine to raise feed dogs up/down. Remove any extension table to locate it because many of these options are located in the back of machine & hidden by table! Jimmy :)
1helpful
Feeding device (with "teeth") does not come up
Reengage the feed dogs by pushing the feed dog button AND manually turning the flywheel towards you through one stitch sequence, you should see them moving back above the needle plate after a stitch has been made.
1helpful
Have Viking 990 and feed dogs not working. Local repair man kept for over a month and then said it was the circuit board and that Viking no longer making circuit board for 990-- or, that machine can't be...
Is it that the feed dogs won't go up and down, or that you can't adjust the stitch length? If the feed dogs won't go up and down after you have released the feed dog button and cycled the handwheel one revolution, than there is a mechanical adjustment needed. I the stitch length can't be ajdusted, that It's either a circuit board of a step motor problem. The repair shop should be able to tell you that they swaped the feed motor with the zig zag motor to test this issue.
1helpful
Feed Dogs do not feed the fabric to sew or embroidery
You have probably inadvertantly lowered the feed dogs. Find the lever for this machine and turn it to re engage the feed dogs....
1helpful
I have a Husqvarna Viking Emerald 183. I can't get it to feed fabric. The footer will move back and forth, but not up and down. So it's making stitches, but will only feed if I manually pull the fabric...
Do you have the feed dogs dropped? Check the feed dog and also the pressure on the presser foot. This knob is located at the left on the top of the machine. The normal setting is 4.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
