Question about Mitsubishi XD435U-G Bulb/Lamp
Replaced bulb and still too dark - what can I do next?
    Champion:
  • Mitsubishi Expert
  • 225 Answers
It only specs at 2500 lumens (good in a dark room) how ever it may be possible to take it apart and clean it. Here is a video of a similar model but its not the same. http://www.youtube.com/watch?v=xah9IW0OC_U
Posted on Dec 19, 2013
Why after i replaced the bulb the picture is still dark?
Are you sure you put the right bulb in ? These need a P22H 120 watt bulb. You CANNOT use an E22H--it has the wrong optical angle. it will work--but WILL be dark.
May 02, 2014 | Hitachi 50V710 50" Rear Projection...
Left portion of the screen is dark replaced the bulb but still dark
Hard to tell from the photo..but it looks mechanical. I would turn it off..pull the wall plug.
...Pull every source connection.rec onnect Check the bulb holder and make sure the bulb is set straight.
Power up and check the zoom
Power up and re start,
Mar 21, 2014 | Televison & Video
I have the KDF-50E2000 Sony I have replaced the bulb and I have a solid green light which isnt blinking though could the replacement bulb be the issue
So you do have a picture? Albeit dark blue? Then its the source and/or video connection that is probably the problem
Mar 18, 2014 | Sony KDF-50E2000 50" HDTV
Dark spot
These bulbs are very sensitive to contamination. When installing a bulb, do not touch it with your fingers, as this will leave your natural oils on it and that will become a hot spot and burn out the lamp.
Use a clean piece of toilet tissue when installing the new lamp to eliminate the above.
Jan 11, 2014 | Sharp XR-10X Multimedia Projector
I have jvc replaced bulb but picture is still very dark if not bulb then whay would cause the dark picture not bright or vibrant
Problem could be in the Light Engine and it may need to be replaced. which is also known as the optical Engine PN# TSCOP7A-SAA
Oct 08, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
I have an NEC '19 Multisync LCD 1920nx monitor. The display went blank and will not come back on. There's power going to it. It just doesn't display and image. How do i fix this?....thanks
the inverter or the lcd bulb may be out. inverters are cheap, bulbs are not. is the screen dark like its off or glowing black? if its dark like the bulb is off, next, look closely and see if you can make out a faint image on the dark screen, if so, it is likely the inverter.
Aug 05, 2010 | Mitsubishi Computers & Internet
My Toshiba 52" goes dark. what can I do to fix it.Tried to ajust the brightness but still stays dark.
U replaced the bulb yet on this tv?U used this tv alot at lest two years or more?The bulb life span it over,bulb have limitted life span.
Apr 20, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
TV screen is dark
If the picture is dark then I suspect a bad lamp if you just replaced it...
Nov 20, 2009 | RCA Televison & Video
Dark picture on lg dlp tv
Did you use a generic replacement? Many TVs have a dark picture after replacing the original lamp with a generic. The other issue I've encountered are TVs that have been exposed to cigarette smoke will develop a dark, discolored picture over a relatively short time.
michtech
Feb 19, 2009 | Samsung HL-R5668W 56" HDTV
Mitsubishi XD435U-G Bulb/Lamp Logo
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
