Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
Kenwood krx 891
How do you set the presets for the radio?
Custom programing the radio
To set Radio options, press submenu in Radio
mode.
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
Jun 28, 2010 | SanDisk Sansa e250 MP3 Player
How do I set the clock and preset radio stations on a Pioneer fhp800bt Premier?
Usually, you need to have key on and radio off. press and hold function button till u see settings menu. Set radio stations by press and hold preset # while on station till beep or display blinks.
May 07, 2009 | Car Audio & Video
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Zenith Z212G radio, Need preset modification instructions
Zenith Z212G radio, preset modification instructions
  1. Display desired station
  2. Press Memo Set button to make "Memo" flash on display
  3. Select desired preset number
  4. Press Memo Set button to save
Apr 12, 2009 | Zenith Z115S Clock Radio
Need operating manual for Zenith Model Z253W radio
1. Tune the radio to the frequency you want to preset, using the "Tuning/Set" buttons.
2. Press "Time Set" button to enter set mode. Note it says "Preset" below this button, because it is used to set both time set and presets.
3. Select the preset number you want, using the "Preset" buttons.
4. Press "Time Set" button again to exit set mode.
5. Repeat the above process for each preset.
Nov 15, 2008 | Zenith Audio Players & Recorders
Set Radio Station Presets
Try just holding the button of choice down. In my Audi, when I had a factory head unit, to set for example, preset 2, I'd just tune to the station I wanted to program, and then hold down the number 2 preset button until the display stopped blinking. It was then preset.
Oct 09, 2008 | 2001 BMW Z3
How to pre set satitions
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
Phil20124
Jul 16, 2008 | Sony Walkman SRF-HM33 AM/FM Radio
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Setting preset stations
Hi Gil, not sure what you mean by RE-setting presets but I assume your using a dock of some kind, and in that case you simply tune to the station you desire then hold down the preset number you'd like to set it to. It will overwrite the previous setting. hope that helps.
Feb 22, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Sep 11, 2007 | Timex (T307S) Clock Radio
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
