Question about Husqvarna Models 61-66, 266, 268, 272
Chainsaw starts but will not tick over - Husqvarna Models 61-66, 266, 268, 272
  • Husqvarna Master
  • 1,807 Answers
Does the engine tick over if the chain brake is off...? If so, check the clutch springs.
If it doesn't tick over when the chain brake is off, try advancing the tick over screw.
Posted on May 03, 2013
Chainsaw want idle why?
Try adjusting the idle 5crew on the carb. Its usually marked with an [ I ]
To get it just right, make sure your chain brake is off, screw in the idle 5crew, the saw will rev and the chain will start to turn. Now back the idle off until the chain stops moving and the engine is ticking over nicely.
May 04, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the factory settings on a craftsman 2.3 chainsaw and to adjust carburetor
tighten the two air screws to just tight then slacken them to one and a half turns start the engine and adjust the low screw until tick over then open the throttle to full and adjust the high screw if it cuts out take the high screw to one turn and try that then adjust from there
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Sthil ms 441 chainsaw runs aradically
More info needed for better diagnosis. More than likely a carb issue.
Coes it start and run on tick over.? Is it bogging down under load.?
Feb 25, 2013 | Stihl MS441 20"
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
My makita rbc420e starts ok ticks over but will not rev I think it's a fuel problem
take off the muffler and try it if ok open the muffler and clean off the screen
May 08, 2012 | Garden
I need help to start relatively unused McCulloch MS40E chainsaw'California'
I also have the same saw and yes it wont start, well some times it dose but wont tick over. Such a pain.............
Nov 10, 2011 | Garden
My Ryobi 4545 Chainsaw started but would not tick over. Now won't start at all.
Check your anti kick back bar across the top. If you bumped it forward will not start.
Aug 27, 2011 | Ryobi Garden
What should the H, L, and T settings be on on a husqvarna 51 chainsaw?
the "H" is the high rev setting the "L" is the low or tick over setting and there set up when the engine is hot and running,,,first the high rev ste up tweek the screw till the engine is running at full revs then tweek the low revv till the engine will stay ticking over,,,
Nov 28, 2010 | Husqvarna Garden
How to adjust a mcculloch 610 chainsaw carberator
there are two screws on the card of youy chainsaw one is the slow running jet the other is the full throttle jet start up saw run it till its hot adjust slow running jet first till saw ticks over ok then adjust fast running jet till you have full throttle,, start with both screw turned in to one and a half turns then adjust from there
Mar 28, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Husky viprating on tick over and now wont start
I think you are saying it sputters but won't run. Once it attempts to fire open the choke or it may flood. My 359 start:
Cold: pull out choke control, pull starter (usually twice) while listening for attempt to start. Once it fires push choke control in and
continue pulling (usually once more).
Warm: pull out choke control (sets fast idle), push choke control in, pull starter.
Page 19 of my manual.
Lou
Once flooded these are a bear to start.
Aug 25, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Models 61-66, 266, 268, 272 Logo
71 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
