Question about Cuisinart DTC-975 Coffee Maker
2nd time using this brand new machine and it won't brew.
2nd time using it, and it won't brew. We press "ON" and a couple minutes later (2 maybe...), there are 4 long beeps and it shuts off. Our coffee maker came brand new, but with no instructions. It worked perfectly Day ONE. Please help. Thank you.
  • 3 more comments
  • chrisinos Dec 28, 2007
    erroneous00..
    I have the same problem...have you found solution>>>
    unit "off"..even if pressed "on"
    But pressing in any combination...prog, hr. min. auto...led will turn on...press.."ON"...starts brewing...then about 3-10 seconds shuts off...re do the same process again,,,and again, and again..until the whole coffee is brewed.
    Do I need to change the complete LED Board? or etc.
    thanks
    Chris
    Hawaii
  • tnelsons May 19, 2008
    has anyone come up with a solution to this? if so please, please pop me an email scaleman@mts.net
  • Anonymous Oct 19, 2008
    coffee will not brew, it beeps a few seconds after the on button is pushed.
  • jamesward791 Nov 10, 2008
    Has anyone found a solution to this problem? Thanks, Jim
  • Anonymous Feb 14, 2009
    Press on and about 30 secons later 4 long beeps like coffee done. Pump never turned on. Thought try the vinegar cleaning routine but pump does not start.
Unplugging didn't work. Mine died just after the 3 yr warranty expired. $100 for a new one so $33/yr for coffee is still pretty cheap...
Posted on Jul 05, 2010
Try unplugging the unit for 1 1/2 hours to reset the electronics...I just called them and that was their advice...we shall see..worth a try
Posted on Aug 16, 2008
SOURCE:
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Brew lit, but "not ready" lit solid "not flashing" fix
There are 4 steps to fix this:
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Aug 10, 2009 | Keurig B60 Coffee Maker
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
How to clean the coffee maker & set warmer
In order:
1 and 2) Clean the coffeemaker by puring in 1/3 caraffe vinegar, and 2/3 caraffe water. Either use the self-clean light or brew it as if it were regular coffee - just press the on button and then press the self-clean button, and it will begin.
3)
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing. For example, if you set
the ASO for 40 minutes and 25 minutes have
already elapsed, the Grind & Brew™ will shut
off automatically after 15 minutes (40 minutes
minus the 25 elapsed equals 15 minutes).
-Tha Mp3 Doctor
Mar 27, 2009 | Cuisinart Coffee Makers & Espresso...
How do I pre brew
I got one of these for xmas, and I was able to program the pre-brew option.
First, turn off the machine.
On the front of the machine, there is series of 5 buttons. (From left to right, they are: Small Coffee, Large Coffee, Pre-ground Coffee, Hot water and Descaling.)
While holding down the 1st (Small coffee) and 4th (Hot water) buttons, turn on the power.
Wait 3-5 seconds before releasing these two buttons. You machine is now ready for programming.
Below the 5 buttons are 4 small lights. If the second light from the left is red, the machine is already programmed to pre-brew. If the light is not red, do the following:
Press the Coffee button (2nd button from the left) once and the second light from the left should glow red. This turns on pre-brewing. (Pressing the Coffee button again will turn off both the light and the pre-brew option.)
Now turn off the power for at least 5 seconds. The next time you turn the machine on, it should pre-brew the coffee.
The process worked great for me the first time, but when I wanted to program the machine to not pre-brew, I had to go through this process a couple of times. Not sure why, though. :-)
Kathy
Jan 13, 2009 | Saeco Incanto Classic Espresso Machine
Cuisinart DTC-975 Coffee Maker Logo
747 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Norman Worley
Damn Skippy
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
