Question about Saniflo & Saniplus& Macerator Pump
While removing the capacitor from the motor inside the pump unit on my SaniPro XR the
Dielectric oil leaked out of the motor. Not sure if the seal is broken. Can the seals & oil be replaced ?
  • Saniflo Master
  • 17,326 Answers
Replace it, the parts are not for resale
Posted on May 13, 2013
  • 51 Answers
SOURCE: Motor will not start, if I spin the blades it will run
if the motor starts when you spin it find the capictor and replace it
Posted on Aug 10, 2009
jeff_drakesr
  • 155 Answers
SOURCE: sanipro xr massirato the problem is the pump is
You must remove the lid to gain access to the blades. Make sure you unplug the unit first. When reinstalling the lid place a little soap water around the gasket to help with the seal. thanks for using FIXYA. Jeff
Posted on Apr 07, 2010
  • 115 Answers
SOURCE: Sanipro xr is less than 6 months old been working
Water pressure makes the unit kick on and off. Somehow water is draining back into the pump casing, check the flapper on the check valve inside the discharge elbow, it may not be closing properly or may be obstructed allowing waste water to drain back into the pump. Also check the flapper on the flush valve inside the toilet tank (water closet) the flapper may be leaking water into the bowl and from the bowl into the pump casing sitting behind. As far as making a loud noise, there could be a blockage on the drain pipe, blade or impeller. The discharge pipe may be loose, not clamped against the wall and is rattling against the wall when in use.
Posted on Jan 11, 2011
  • 115 Answers
SOURCE: sanipro xr pumps for 15 mins then wont start up
Definitely there is a problem with the pressure chamber, it may need to be replaced. The pressure chamber is were all the electrical components are sitted and is what turns the unit on and off. You can always order parts throught Saniflo's technical dept. 800-571-8191
packrat1948
  • 528 Answers
SOURCE: i have a sanipro xr its not making the sound it
The pump in the lift chamber has quit working. Check the power to it and if that's not the problem then you will have to get into where the pump is to see if the float is hung up. I know it's a nasty job but someone has to do it.
Posted on Jan 30, 2011
The pump is leaking some gray fluid
Gray fluid is usually indicative of old oil with water mixed into it. First you have to determine if the fluid is coming out of the motor or pressure pump. Then change the oil in that, or both, and then watch the condition of the oil when you use the washer. With new oil, it won't turn gray but will get a milky coloration to it. There shouldn't be any way for water to get into the motor oil short of the engine being sprayed directly with high pressure water. If water is getting into the pump oil you'll have to check the seals inside the pump.
Feb 14, 2013 | Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600...
Sanipro xr is less than 6 months old been working fine but has recently become rather noisy. Sometimes goes off in the middle of the night for no reason.
Jan 08, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanipro continuously runs,however, not pumping waste away and waste water has filled toilet bowl. Any suggestions
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
Dec 23, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Kenmore 253.78989801. Refrigerator stop cooling, then freezer gradually lost temperature. Melted ice buildup on coils by removing panel in freezer. Restored power. Fan in freezer works, I can hear...
If freezer is not cooling then the chance of frost forming is also out of question. So we need to start of by checking on the prrimary component, the compressor. Make sure the speed of the motor is humming welll or check the motor capacitor. Use a clamp tester to measure the current factor to see the load. If the pumping is low then check for gas pressure in the unit. If not you will need to check why the gas leaked check the leak with compressed air pumped in and monitored.for leak.
Only then recharge gas and seal.
Test the motor before gas filling to confirm the performance.
Sep 16, 2010 | Kenmore 74173 / 74170 Top Freezer...
Xr 200 fork problem
no air required. the air valve on top is to release pressure after heavy pumping. ie motorcross... check seals. you can run a feala gauge inside seal to clean dirt out or replace if worn. put in correct amount of oil an off you go....
Jun 30, 2010 | 2002 Honda XR 200
Sanipro xr massirato the problem is the pump is not pumping on makes a stuck sound, how do we clear out the massrator?.
Mar 11, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Need to put in new bearing, it is really starting
Bearing on new motor failed for some reason, Make sure the new one will last, check that all shields and water deflecters are in place and that pump seal is not leaking. New motor bearings should be sealed but water has a bad habit of getting into anytging we try to keep dry.
I recomend replacement of pump seal whenever pump is opened and impeller is removed, cheep insurance. Take your time and make sure everything is clean as it goes back together, don't lubricate the pump seal faces, the ceramic faces are designed to be self lubricating and anything (even fingerprint oils) on them can cause a leak.
Aug 01, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Little giant submersible water pump (model 5-mspr) is low on oil...what type of oil should I use to top up the oil level???
You can use a dielectric oil available at most motor repair shops. It is of the utmost importance to make sure the cord seal is in good condition and well sealed
Apr 22, 2009 | Pool & Spa
Saniflo & Saniplus& Macerator Pump  Logo
664 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
