Question about Gateway 504GR PC Desktop
Enter password unlock system - Gateway 504GR PC Desktop
  • Gateway Master
  • 27,725 Answers
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password-protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both.
Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer."
Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear.
Log on as usual.
Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool. This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer. Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
%SystemRoot%\system32\restore\rstrui.exe
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
%SystemRoot%\System32\Restore\Rstrui.exe
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page.
Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make.
Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
http://download.cnet.com/lazesoft-recover-my-password/3000-18501_4-10973339.html
Lazesoft Recover My Password Home Edition is a very easy to use Windows password recovery freeware
http://download.cnet.com/password-cracker/3000-2092_4-10226556.html
password cracker free
Posted on May 03, 2013
How can i unlock my aspire hard drive password model ms2346 (key:69011346)
Replace the hdd and when OS is installed restore your backups. The hdd password is a security device that dissables the hdd information and encrypts the firmware - permanently in case it is stolen.
Sep 01, 2014 | Computers & Internet
If you are talking about resetting your windows password please check out one of my previous question that I answered this might help. If you have forgotten your password.
http://www.fixya.com/support/t25071622-need_reset_password_medion_akoya_e1317t
What are the cheats for wwe legends of wrestlemania
  • Enter "TheRoadWarriorAnimal" as a password to unlock Animal\'s alternate costume.
  • Enter "BrutusTheBarberShop!" as a password to unlock Brutus Beefcake\'s alternate costume.
  • Enter "HawkFromLegionOfDoom!" as a password to unlock Hawk\'s alternate costume.
  • Enter "WithManagerJimmyHart" as a password to unlock Jimmy Hart\'s alternate costume.
  • Enter "TheBirdmanKokoBWare!" as a password to unlock Koko B. Ware\'s alternate costume.
  • Enter "CobraClutchSlaughter" as a password to unlock Sgt. Slaughter\'s alternate costume.
  • Enter "ShawnsSweetChinMusic" as a password to unlock Shawn Michaels\' alternate costume.
  • Enter "IronSheikCamelClutch" as a password to unlock The Iron Sheik\'s alternate costume.
  • Enter "UnlockTheRockBottom!" as a password to unlock The Rock\'s alternate costume.
  • Enter "UndertakersTombstone" as a password to unlock The Undertaker\'s alternate costume.
Cheers,
Tom
Aug 28, 2014 | Sony Playstation 3 (PS3) Console
is it windows lock or hdd lock?
Mar 18, 2014 | Intel Computers & Internet
Password reset acer aspire one d250 wont boot
Try these WEB sites for removing hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Mar 14, 2013 | Computers & Internet
Hi my lg ht303su dvd player wont eject its saying locked.
select rating on lock menu then press play input password when asked if you forgot password use 210499 and press enter enter it again and press enter to verify password you can select rating of lock 1 to 8 . one is the most restricting option.. if you select unlock the dvd has no parental control on.
Aug 19, 2010 | LG HT303SU Theater System
Pc "bios"problem
this looks like you have kept the bios password and you forgot it. just do one thing open the cpu case to access the inside of the system and then just remove the battery in it. wait for 5 min and again plug in the battery. thats it your bios memory password will be reset.
2nd solution without removing battery. just reset the bios as shorting the jumper pins. consult your motherboard book to know where to find the bios reset. it will be written as CLEAR CMOS.
Dec 21, 2009 | Intel Computers & Internet
Dvd password accidentally entered How do I reset?
I just had the same problem tonight. My wife figured it out. The system password is 'BOSE', which is 2673 from the telephone keypad. Enter 2673 and this will unlock the default system password. My old 321 system also lost it's FM presets, so I think the original CMOS battery died on it's motherboard.
Dec 21, 2008 | Bose 3·2·1 II System
Tony hawk's proving ground ps3
Have you tried these
Unlock Boneman:
Enter the password CRAZYBONEMAN
Unlock Shayne:
Enter the password Movers
Unlock Spence:
Enter the password Dapper
Unlock Mel:
Enter the password NotADude
Unlock Rube:
Enter the password LooksSmelly
Unlock Bosco:
Enter the password MoreMilk
Unlock Cam:
Enter the password NotACamera
Unlock Cooper:
Enter the password TheCoop
Unlock Eddie X:
Enter the password Sketchy
Unlock El Patinador:
Enter the password Piledriver
Unlock Eric:
Enter the password Flyaway
Unlock Mad Dog:
Enter the password Rabbies
Unlock MCA:
Enter the password INTERGALACTIC
Unlock TV Producer:
Enter the password Shaker
Unlock Mini Skater:
Enter the password TinyTater
Unlock ALL Create-a-Skater-Items:
Enter the password GiveMeStuff
Unlock ALL Decks:
Enter the password LetsGoSkate
Unlock ALL Fun Items:
Enter the password OverTheTop
Unlock ALL Game Movies:
Enter the password WatchThis
Unlock ALL Lounge Bling Items:
Enter the password SweetStuff
Unlock ALL Lounge Themes:
Enter the password LAIDBACKLOUNGE
Unlock ALL Rigger Pieces:
Enter the password IMGONNABUILD
Unlock ALL Specials Available:
Enter the password LOTSOFTRICKS
Unlock ALL Video Editor Effects:
Enter the password Trippy
Unlock ALL Video Editor Overlays:
Enter the password PutEmOnTop
Unlock FDR Level:
Enter the password ThePrezPark
Unlock Lansdowne Level:
Enter the password THELOCALPARK
Unlock Air and Space Mueseum Level:
Enter the password TheIndoorPark
Unlock 100% Branck Completion:
Enter the password FOREVERNAILED
Unlock Perfect Manual:
Enter the password STILLAINTFALLIN
Unlock Perfect Rail:
Enter the password AintFallin
Unlock No Board:
Enter the password MagicMan
Unlock Invisible Skater:
Enter the password TheMissing
Unlock Super Checking:
Enter the password Booyah
Unlock Unlimited Focus:
Enter the password Myopic
Unlock Unlimited Slash Grind:
Enter the password SUPERSLASHIN
Unlock 50 Extra Skill Points:
Enter the password needshelp
Unlock Full Stats:
Enter the password BeefedUp
Apr 27, 2008 | Sony Playstation 3 (PS3) Console
Gateway 504GR PC Desktop Logo
111 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
