Question about ASUS Computers & Internet
Network Problems Hello,I got a problem with my network adapter,When I connect to the internet,my laptop freeze and stop working,I can't do anything,and I've to turn off directly by pressing the main switch.But,when I log on in Safe Mode,I can connect to the internet and surfing without any problems.So,what are the problem?It's the network adapter problem or my OS/Windows 7? Thank you.
  • ASUS Master
  • 7,627 Answers
Have you tried a System Restore to a date before this issue. Have you run a Full scan with your up-to-date Anti Virus? Also run a Full scan with freeware MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the TRIAL PRO version, you want the freeware version, delete ALL results, reboot. If necessary download and run in Safe Mode with Networking. Use freeware CCLEANER to clean the HDD: http://www.filehippo.com/download_ccleaner/
Posted on May 03, 2013
ritzcheese
  • 65 Answers
SOURCE: Cannot find network 1394 network adapter nor the standard Network Adapter connection
Try having a System Restore on your computer back to the date before you installed the wireless HP printer device and software.
Posted on Sep 13, 2008
HeLpINHaRrY
  • 210 Answers
SOURCE: wireless network not connected
most wireless routers have an option of "do not broadcast ssid"
(you have to already know the name of the router)
so you need to login it to your router and check all the options and mak
let us know how it works out andask if you need help with anything else
Posted on May 20, 2009
  • 71 Answers
SOURCE: Set my Toshiba Satellite Laptop PSA60U-01W015 to it Factory Sett?
some of these systems have the factory restore option on post boot before the OS kicks in. From a cold boot look for the hit DEL or Fx key and do that - you may have to boot a few times to catch it, and possibly hold the defined key down in anticipation of the option to appear on what looks like a DOS screen. You may need the recovery discs that came wit the system if the image is not in a hidden partition of your drive. Good luck.
Posted on Jul 25, 2009
  • 63 Answers
SOURCE: laptop wont connect to wireless network but desktop is fine.
Perhaps, it just needed a new IP address. Simply rebooting the computer and resetting the IP Address of the computer took care of the issue.
or
That sounds like symptoms of Manufacturer & Windows drivers conflicting. Try uninstall the Manufacturer Drivers and let the windows ones do the work, and see how that goes down.
Posted on Apr 21, 2010
SOURCE: My asus n61j won't connect to the Internet using internal adapter
Hi there, I just bought a new Asus NJ series, and all of a sudden my wireless dissapeared! I FOUND THE SULOTION, well, I hope it works for you. Look on the left side of your laptop, right at the front left side is a switch/button. I think I accidentally switched it of, but now everything is working fine!
Posted on Oct 27, 2010
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
How to stop the Wireless Adapter For droping The internet connection Every 1 minute
What are specifications you are using for your wireless network? B, G or N, WEP or WPA-1 or 2 encryption, etc.
If everything was working fine at the beginning and no one has changed any of the network settings then that indicates an issue on the laptop.
You can try to reinstall the driver by downloading it from the Acer website as a Windows Update could have installed an 'updated' driver that doesn't work properly.
Jul 06, 2012 | Acer Computers & Internet
Wireless Connectivity problem
You can check the wireless adapter is working properly in device manager: control panel>hardware and sound, under devices and printers, choose 'device manager'. Expand the network adapters menu and find the wifi adapter. Right click on this and click properties. You can see if the device is working properly under the general tab. You can also try updating the driver; from the drivers tab, choose update driver and then choose to search automatically for updated software.
Also, try clearing browsing history and cookies: Go to start>control panel>network and internet, under the internet options heading, choose 'delete browsing history and cookies' restart the browser.
Apr 03, 2012 | Dell Inspiron Computers & Internet
I hav a Dell inspiron 15 laptop and i have taken wired internet connection. but somehow my lancard has stop working and i am not able to access internet. can you please tell me some alternative to lan...
you can do a quick troubleshooting on the laptop.
1. used another network cable and check that no pins are broken on the laptop.
2. go to device manager and remove the network adapter and reinstall it.
if this don't work. if you have a wireless router, you can connect to the internet over the wireless network adapter on the laptop.
good luck!!
Aug 31, 2011 | Dell Ethernet Card Network Adapter
I have a Toshiba Satellite L305D-S5934 notebook with Windows Vista Home Premium. I use Verizon wireless broadband to access the Internet. I can connect to the internet using their USB modems just fine, but...
You didnt mention via cord(Lan Cable)have you ever used it? is it works?
Ok let assumed the cord can access the internet.
1.Enter your device manager
2.locate Network Adapter >> there should be 2 or 3 network adapter type
3.If you found any question mark with yellow colour >> right click on it >>> update driver
4.toshiba has application built in called zero configuration >>> open it, and try setting something matched with are you looking for ( sometimes the program stuck on something else network adapter eg. LAN cord or built in Wifi
akee_akee@live.com
Aug 17, 2011 | Toshiba Satellite A135-S4487 Notebook
My laptop has had a complete memory boot and i can not get my wireless connection back on. How do i correct this problem/ i am using a ethernet cable at the moment to get connection to internet. Thank you
Improve the Fixya.com experience for everyone by voting!
The first solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this.
? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database.
? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: user.name.xadsl@xtra.co.nz.
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online. However, if it doesn't get you on line, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
All the best
Ben
Jun 18, 2011 | Acer Aspire 5315 Notebook
I have a netgear wnce2001 universal internet adapter. It was previously configured to the wireless internet in home to work with Xbox. Just yesterday the WLAN line went out. Hooked ethernet and USB cable...
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
? Click on 'Tools';
? Click on 'Setup'
? Click on 'Next';
? Clock on 'Next'
? Click on 'No';
? Click on 'Next';
All the best
Ben
Jun 18, 2011 | Computers & Internet
I can't get my wireless to work on my laptop - I honestly cannot even remember when or how it stopped working. I get a message when I try to connect: The network adapter "Intel (R) WiFi Link...
Very first thing to try is check to see if the wireless is turned on!
There may be a small switch on the case that must be turned on. But this doesn't sound like your problem--just thought I'd mention it.
Then go into the device manager and remove the adapter. Don't worry--this won't hurt anything.
Restart the computer and let it find the adapter. It should work after that.
Other than that, I'd have to know the actual settings on the adapter to help you.
Jun 13, 2011 | Acer Aspire 5735-6694 Notebook
I own a regular MacBook and it's about a year and a half old. I recently moved into a new apartment and established a new wireless network through Comcast. They gave us a modem/router combo for our...
Hello Jodu,
Please check the internet settings of the Lan connection in the Mac Book. May be there is IP Address or DNS settings is installed in your Mac Book which are stopping the wireless network services. Please check the IPV4 settings in the Lan or wireless connection properties.
Jun 03, 2011 | Apple MacBook Mac Notebook
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
