Question about Garden
Bolen bl410 pull rope replacement - Garden
3 Suggested Answers
  • 21 Answers
SOURCE: I have the Bolens BL410 gas cultivator. It won't start. I have changed the gas and the spark plug but it won't start. I don't know what else to try
Spray starter fluid in the air filter. This should work.
Posted on Apr 09, 2012
SOURCE: the pull rope to start
The BL510 has 5 combination torx/flat blade screws that separate the pull starter and shaft from the engine. 2 you should be able to access with the torx bit. The others you will likely need the screw driver.
Separate the housing from the engine. Disconnect the leads for the electrical engine kill. You can do this job with the throttle cable still attached--just be careful to not separate too far.
On the shaft tube there is a metal circular clip. Carefully pry it off evenly with a screw driver and set aside. Remove 4 more torx screws holding a metal plate that keeps 2 plastic pulleys secure (one inside the other--inner is a gear engagement).
There are 2 recoil springs and 2 pulleys. The smaller diameter pulley is inside the larger and has a wider stiffer and shorter recoil spring (this is used to engage the magneto when you pull the string). Pull both pulleys and the small recoil spring out being careful to try and leave the narrow recoil spring inside its metal housing. Note that when you remove the outer pulley that has the rope, there is a keyway that engages with the end of the narrow recoil spring (I have photos, but all are much larger than 150kb--the largest allowed). I suggest you take a photo at this point so if you happen to unseat the very long and narrow rope recoil spring, you will orient it correctly.
If you happen to pull the longer narrower spring out and it springs out like a jack in the box-it is easily put back in after the cussing. Start at the hook end and carefully recoil it back in turning it over itself one revolution at a time within the housing. Within a minute or so, it should be back to normal...
WIth the new rope, tie a knot on one end and insure at least 6 " longer than what you need. You will thread the rope through the outer pulley from the inside leaving about 1/4" on the outer side (just enough to come through the hole. Engage the pulley from the keyway slot back on the spring end. Load the spring by turning it clockwise, being careful to keep pressure on the pulley. Rotate it about 5-6 revolutions. Here's the tricky part. Pull the rope through the eyelet while maintaining force on the pulley (I pulled it through the eyelet separately, they pushed the eyelet back in). A tweezers or needlenose pliers will help pull it through. Once through, pull the rope all the way through to the knot, then allow the pulley to recoil the rope back in. This will relieve some tension on the coil. You should have an idea of the tension on the pulley. Make sure the plastic plug holding the eyelet is back in. Put the metal plate and screws back on. Position the second recoil spring for the magneto back in the pulley and position the eccentric pulley back on. Tie the T-handle on making sure there is enough tension when fully retracted to hole. Push the metal clip back on the shaft.
Reassemble. You likely will have to insure orientation of the square cable and magneto pickup when pushing the halves back together. Remember to put the terminals for the engine kill back on before pushing together, and make sure the throttle cable is positioned like before.
Sorry cannot load the pictures.
Posted on Jun 24, 2012
Pulled starter rope, it's now stuck and won't recoil
Cool!
A Project.
Remove the spark plug lead just so you can't have it accidently fire.
Remove engine cowlings as necessary to get at recoil starter.
Remove recoil starter (that's the bit that the pull rope is attached to.
Dis-mantle it until you can find what is wrong. Fix or replace.
Put it all back together.
or
Take it to a small engine repair shop and pay a bunch.
Mar 06, 2016 | Bolens 31cc 2-Cycle Gas Cultivator BL410
I have a bolens bl410 and when I push on the primer it won't push the fuel onto the carburetor
They are not suppose it....They just suck the air out and fuel into the metering chamber.
Apr 27, 2015 | Garden
Repair and replace power module on bolens culivator 31cc engine
How old is it? Does it show a spark when you remove plug an hold against engine while pulling cord? Did you replace plug? It is the most common problem. Remove the stop wire an try to start, if it does or you see spark the switch is bad. I would check put these things before replacing module.
Mar 16, 2014 | Bolens 31cc 2-Cycle Gas Cultivator BL410
My rope wont recoil on my Bolen BL 160 I have
the round rotating part with the nose is the clutch drum, it has a small torx screw down inside the center retaining it to the crankshaft, remove this screw, block the cylinder and remove the clutch plates. remove the engine from the housing and turn it around to access the spool and a metal plate that has a few screws holding it in. there is a push nut that looks like a serrated ring holding the spool on the housing, sometimes it can be carefully removed but usually it fails and has to be replaced, it presses back into place upon reassembly. Do not remove this ring if you are not replacing the spring or pulley!!! Simply install your new rope and using the spokes on the pulley gather some slack in the rope and wind up the pulley about 5 turns in the direction it rotates as if you were pulling the rope, while holding the tension on the pulley, extend the rope fully and carefully release the pulley while holding the tension with the rope by its handle it should retract normally
May 31, 2010 | Garden
I have a Bolens BL410 cultivator that stops running when it gets hot. The engine starts perfectly every time, but after using is for a couple of minutes the motor speeds ups suddenly and then shuts off. I...
Hi and welcome to Fixya. The symptoms your describing are typical of what happens when the engine experiences fuel starvation.
It can be caused by a clogged fuel filter screen located at inside the attachment point of the fuel line manifold on the carb. Turn off the fuel and remove the mounting bolt for the fuel mainfold. Very carefully remove the plastic screen inside the manifold and clean off the debris that has built up on the screen.
If the screen was visibly clogged you probably have solved your problem. Just make sure you re-install the screen when re-connecting the fuel line manifold.
If the screen was not clogged then check your fuel lines for cracks. Air being introduced into the system will cause the same symptoms you describe.
If the problem persists then there is the possiblility that the needle and seat are partially blocked inside the carb itself on the bottom of the carb body after you remove the bowl. (Usually not the problem) However the bolt that holds the bowl on has 1 or 2 holes in it that can also clog and they must be clear.
And finally there is a BRASS jet that unscrews with a screwdriver in the bottom of the long draft tube (way below the throttle slider / needle) that gets clogged. Unscrew the brass jet and force air from the threaded end to clear the orifice.
By this time you probably figured out the float comes off with the bowl. note which side is UP! Also DO NOT adjust the float level it is preset. u|Unless you bent the float control arms it does not need adjusting.
Turn on the fuel... and start the unit after re-assy and it should run just fine. You should be tilling real soon!
Jan 29, 2010 | Ryobi Cultivator
Replacing starter rope on bolen 150 weed eater how do u do it
take back apart and try to pull freely and if still hard you need to replace
Aug 02, 2009 | Garden
Garden Logo
177 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
