Champion paper cutter
Cannot reset cuuter according to manual. Lost power and cannot get the cutter to reset.
  • 7,627 Answers
Is there a reset button?
Posted on May 04, 2013
We have a fellowes shredder. It got full and jammed. After cleaning and emptying it will not turn on. Is there a reset button? Thanks. Betn
We've found that when the container is overfilled with shredded paper, it will begin pulling shredded paper back into the cutters and jamming the machine. Sometimes reversing the machine will spit the paper back up, but if it is thoroughly jammed, only way to unjam it is to UNPLUG it first, then manually remove the paper from the cutters. Then, be sure to dump the container BEFORE it is filled with paper.
Jan 12, 2017 | Fellowes Office Equipment & Supplies
1600mx wont run in forward over load light comes on
Most common reason is that there is paper would around the cutters, imposing an additional load on the machine. You will need to access the cutter assembly (disconnect all power) and manually remove all of the paper that has impinged between the cutters.
If you have run any labels or paper with gummed strips through the cutters, you may wish to consider throwing this one away and buying new. (In all fairness, it "can" be cleaned, but it is going to be a real dickens of a job to do).
If you decide to keep your shredder and clean the cutter assembly, remember to oil it on a regular basis per the instruction manual.
As for me, I use Fellows shredder oil
Fellowes Shredder Oil 12 oz Bottle with Extension Nozzle 35250
and oil my machine every time I dump the cuttings. I run a bead of oil in a serpentine pattern over a sheet of paper and then just shred it. (If you have never oiled the cutters, it may be too late to do so now. Something you need to do on an on-going basis).
Jan 23, 2015 | Royal 150MX Cross-Cut Shredder
Problems dismantling champion juicer
It's like a suction is created. I have had this happen. I managed to get mine off with a blunt knife to give a bit of leverage (not ideal I know to put a knife near an expensive piece of equipment but it worked for me) Once you have the blade cutter off I suggest oiling the metal prong that it sits on with something like vegetable oil or olive fairly regularly to avoid this happening again.
Feb 23, 2014 | Champion Juicers
Can't find cutter. could it have fallen into machine. the clip that holds it is there. This happened after trying to clear a paper jam
Cutter unit having press & release system, by mistake its released, it might be fallen in paper bin.. You can see there is a cut at right side near blur lever,pull cutter bush up to there & load the cutter into cutter bush. Once hearing click sound manually confirm its fixed properly or not.. once its confirmed, push cutter in to park area, power on the printer..
Aug 01, 2012 | HP DesignJet 500 InkJet Printer
The cutter is stuck how can I get the cutter off of the champion juicer?
I have had this happen in the past...couple things you might try.... put it outside or in the freezer to cool it down. next i have dumped olive oil 'around' the end of it that is butted against the unit- some should seeps down and then i used a dull butter knife or steak knife to wedge in there to pry it off.(genlty) in different positions. If it is rusted on, well that's another matter entirely. But if it's just stuck, could be that you haven't oiled it each time? or my other guess is they aren't making the cutters like they did 25 years ago as i have had 3 champtions and more problems with the new ones and cutters jamming (i put a coule drops of olive oil into the hole in the cutter each time). and as a last resort a big burly man with gloves and feet to hang on to it and jimmy it off LOL good luck ;-)
Jan 08, 2011 | Champion G5NG853S Household Juice...
How do I reset the distance ?
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please . .
Apr 20, 2010 | Sportline C9 by Champion Fitness 910 Watch
Cutter is stuck onto shaft, how can I remove it?
First, check to see if there is a set screw in the side of the cutter which screws against the shaft.
If no set screw, a gear puller would probably do the trick. There are many types -- you might luck out and find one which will fit on your first shopping trip.
Apr 29, 2009 | Champion 2000+ Household Juice Extractor
Cleaning inside the cutter
I've been using my Champion for about 20 years, and have always used a very thin coat of olive oil on the turn shaft before sliding the cutter on. I've also used it before I've used the grain mill, and it has been fine.
If I were you, I think I would get out as much Crisco as I could with a chopstick (or something similar), put in some liquid soap, and some hot water. I would think that would loosen anything that was compressed or stuck. It might take a few times, but that's what I would try....or you could order a new cutter from Champion. I've had to order parts from them in the past, and they have been great.
Hope this helps.....
Jan 30, 2009 | Champion Juicers
Cleaning inside shaft of champion juicer cutter
Soak it in Hydrogen Peroxide or vinegar.
Cutter
This is a response I received from Champion Juicer- I am amazed at how fast they responded. His solution is below- Hello Cathy
To remove the cutter from the Champion Juicer motor shaft, take two small
screwdrivers and place them between the back side of the cutter and the
stainless steel portion of the hub. Apply pressure on the screwdrivers and
the cutter should begin to slide forward. When driving the screwdrivers in,
make sure they are spaced far enough apart so they don't damage the motor
shaft which is located in the center of the cutter. If the cutter does not
come off, leave the screwdrivers in place and insert something under the
rear of the Champion Juicer (like a book) to elevate the rear of the
machine, thus allowing the cutter to tilt forward. Apply penetrating oil
between the screwdrivers. Because the cutter is now angles forward the oil
will run inside the cutter. If this is done for several days the cutter will
come off by applying more pressure to the screwdrivers. By merely pulling on
the screwdrivers you will have to use a plastic hammer and slowly tap on
each of the screwdrivers until the cutter breaks free. Tap one screwdriver,
and when it is snug, tap on the other screwdriver until the cutter breaks
free. When this is done there will always be one screwdriver coming loose
and falling out of the slot. Do not rush the removal process; give the oil a
chance to work. It is possible the hub and cutter will be damaged during the
removal process. Contact us for current replacement prices. Once the cutter
has been removed you should polish the motor shaft to remove any film or
burrs which may have developed. If you contact us with your address we will
mail you a piece of fine emory cloth to polish the motor shaft  at no
charge. You should always apply a slight film of olive oil on the motor
shaft to prevent sticking of the cutter. Do not use other oils, as they tend
to break down from the heat during operation of the juicer. If you wish to
speak to a repair person, please call our company weekdays @ 209-369-2154
between 8:30 a.m. and 4:30 p.m. Pacific Standard Time. We would be happy to
offer any assistance you may need.
Thank you
Carl
Aug 05, 2007 | Champion 2000+ Household Juice Extractor
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
