Question about Chrysler 1999 Sebring JXi
Battery Drain After my battery drained completely to the point where it wouldn't even jump start I fully charged the battery and located two circuits that were draining the battery one was the park lamps and horn circuit and the other was the interior lighting I replaced a faulty door ajar switch which fixed the park lamps and horn circuit but am having a hard time finding the problem in the interior lighting circuit is there a particular component that usually has problems in this circuit?
    New Friend:
    Problem Solver:
  • 8 Answers
Yes the headlight switch and the multifunction switch also check the overhead light fixture wires all have problems on these cars
Posted on Oct 21, 2013
What cause the car want start even if u jump it it just cleick
Start with the basics, here. Check that battery cables are not loose and are CLEAN, on the battery AND the starter. Beyond that, check the battery charge with a volt meter. Fully charged should be 12.5 volts or higher, you will lose starter spin at 10 volts. If the battery is low, hook it up to a charger and charge it up completely. If you don\'t have a voltmeter, go to the store and buy one. If you\'re going to try and fix things like this, you have to have one. If you can\'t do that, remove the battery and take it to someplace like AutoZone. They will charge and test the battery for free. If you can\'t take the battery out, or don\'t have a friend that can, have the car towed to your mechanic.
Here\'s the thing- I can\'t tell you exactly why, but some cars you just can\'t jump start. Happens more on side mount post type batteries. Because you can\'t jump your car doesn\'t mean it won\'t start with a fully charged battery. Now there are other things that could be wrong with you car, that it won\'t crank over and start for you.....but we begin the diagnosis with the battery.
Mar 17, 2014 | 1993 Oldsmobile Eighty Eight
Electrical problem on 1996 Dodge Dakota
It will drain at a rate of 21Watts X 2 = 42Watts at 12Volts = 3.5Amps. If you have an 70 Ah battery that is 20hours to totally flat from fully charged.
May 27, 2017 | 1996 Dodge Dakota
2008 Chevy Equinox would not start, turn key and nothing happened, replaced battery, ran just fine for a week. Tried to start one week later it acted like it wanted to start but wouldn't. Had ju
Usually a sign of something draining the battery.
The machine test probably showed the battery could hold a charge and the alternator was charging the battery.
You may need to have someone check for a power drain.
When the key switch is off, there may be a weak short to ground or a relay or component that is using power.
Jan 22, 2013 | 2008 Chevrolet Equinox
When I try to start my 04 fatboy it clicks but wouldn't start.
This could be your battery, even if it is charged to 12 volts sometimes they go bad and don't have the cranking AMPS needed to fully engage the starter drive. Try another battery you know is good or if you know how to jump it from another battery try that, if the syarter works you know it is the battery
Oct 09, 2011 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
I have a 2003 Chevy Silverado 2500. Once again, it wouldn't start. The battery was completely dead, and it would not even start with a jump. Replaced the battery, started fine. But, now the voltage...
Battery was completely dead ? after how long , over night , or just out of the blue ? These year GM vehicle's 03 to 06 have instrument cluster problems , draining the battery . Do you know what parasitic draw is ? Google it . They used lead free solder constructing the electronics , an after a while it causes silver migration .
Chevrolet Truck Battery Dies Overnight Part
Chevrolet Truck Battery Dies Overnight Part II
Apr 19, 2017 | 2003 Chevrolet Silverado 2500HD
2009 dodge caliber battery draining. Woke up one morning and car wouldn't start. I got a jump ad it started right up. I took the car to advanced auto and they tested alt and starter both were one...
many things could cause this....
something left turned on and plugged in,
weak battery - have it tested
weak/bad alternator - have it tested as well, may not be fully charging battery
could be a bad cable or ground
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 17, 2011 | 2009 Dodge Caliber
I have a 1997 Ford taurus GL. Decided not to start a few days ago so bought a new battery. Ran okay for a couple of days then wouldn't start, but did so with a jump. Now jumping it does nothing and...
It's the alternator...it is not keeping your battery charged. You can remove it and take it to a local parts store and they will test it for free.
Jul 08, 2011 | Ford Taurus Cars & Trucks
My Chevy blazer wouldn't start mad a clicking
this is one of two problems (maybe both) ...
1. The battery has been fully discharged before, preventing it from being able to hold a charge properly. This can be tested at a Sears Automotive Center. If the battery is no good, get a replacement and you should be fine (at least for a while). If you are going to go to Sears, have them run a full electrical diagnostic -- if there is something draining your battery while the car is not in use changing the battery will only hide the problem for a few months until the new battery fully discharges, and the same issue with resurface.
2. Your alternator is not charging the battery. It might be pumping out electricity to the wiring that it is connected to, but the charge may not be getting all the way to the battery. Sears can also check this with their diagnostic tools, and should be able to locate and repair the problem for you. Unfortunately, without a VERY expensive diagnostic machine, it is very hard to tell exactly where the problem is occurring .. so taking it in to a shop is probably your best bet.
May 27, 2011 | 2001 Chevrolet Blazer
Car has a flat battery and won't start even with a
Once the battery is totally shot it acts like a resister Try jumping it with another car. If you left your lights on and drained the battery then of course recharge. If the battrey is no good anymore. you got to replace it. Make sure all terminals are clean and tight. Good luck
Jun 05, 2009 | 1997 Saab 900
LG VX8700 won't stay charged...
I had the same problem with mine... I found that you must let the battery completely drain out; I was continuously jumping to charge my phone when it was down to one bar, and realized that upon doing this, the battery never fully retains its charge for as long as it will if you let it die out (blank screen; completely off).
I did this twice, and have not had a problem since.
Hope that helps!
Christina
Nov 25, 2008 | LG VX-8700 Cellular Phone
Chrysler 1999 Sebring JXi Logo
52 people viewed this question
Top Chrysler Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
ray gallant
Lawrence Oravetz
Are you a Chrysler Heating and Cooling Expert? Answer questions, earn points and help others
