Question about 2004 Jeep Grand Cherokee - 4.7L V8 - Catalytic Direct-fit Catalytic Converters - 49-State Legal
Runs rough - how to fix
Code indicates P0171: A lean air/fuel mixture has been indicated by an abnormally rich correction factor.
  • Eastern Master
  • 17,093 Answers
Check for vacuum leaks, Bad intake sensors, worn injectors, Restricted intake air, bad EGR valve.
Posted on May 09, 2013
I have a PO171 code on my 1999 Jeep grand cherakee larado can You tell me how to fix it, Thank You.
  • Dale, code P0171 fuel system too lean
  • Possible causes
  • change fuel filter first, if it has not been done recently
RESTRICTED FUEL SUPPLY LINE
FUEL PUMP INLET STRAINER PLUGGED
FUEL PUMP MODULE
O2 SENSOR
O2 SENSOR SIGNAL CIRCUIT SHORTED TO GROUND
O2 SENSOR HEATER OPERATION
TPS VOLTAGE GREATER THAN 0.92 VOLTS WITH THROTTLE CLOSED
TP SENSOR SWEEP
MAP SENSOR OPERATION
ECT SENSOR OPERATION
ENGINE MECHANICAL PROBLEM
FUEL FILTER/PRESSURE REGULATOR (HIGH)
PCM
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2000 Jeep Grand Cherokee p0171
Possible problems related to Code P0171 Jeep Garage Jeep Forum
P0171 System to Lean Bank 1
Code P0171
Mar 11, 2016 | Cars & Trucks
Po171&po191on audi a4 2007
P0171 indicates the system is running too lean (too much air, not enough fuel). P0191 indicates a problem with the Fuel Rail Pressure Sensor Circuit Range/Performance. Low fuel rail pressure could cause the Lean condition. Replace the fuel rail pressure sensor, and you'll probably correct the lean mixture error. Clear the codes and drive it to see if codes re-occur. Good luck.
Sep 29, 2013 | Cars & Trucks
I get code 51 on 1996 dodge caravan....fuel system lean---a lean air/fuel mixture has been indicated by an abnormally rich correction factor. The van runs fine when engine is cold but will sputter and...
the code is telling you where the problem is. Try replacing the HO2S sensors as the cpu is having trouble keeping the air /fuel mixture within limits. Check the cat converter for cracks or blockages . Have a pressure test done on the fuel manifold to check for pump/filter and pressure regulator problems. Check the ambient air temp sensor and coolant temp sensor as they also affect the air/fuel mixture.
Sep 23, 2013 | 1996 Dodge Caravan
Running rough - how do I fix it?
For any codes you get use Google
OBD Code PO171
May 03, 2013 | 2004 Jeep Grand Cherokee - 4.7L V8 -...
Cod of 51 on grand cherokee 5,2 which o2 sensor is out of order
Well, code 51 means the O2 sensor is telling the computer the fuel mixture is lean. So the computer tries to make the mixture rich by opening the injectors longer. I doubt the sensor has failed, but rather your fuel pressure is low.
If the sensor has failed and pressure is normal, you should have black smoke coming out the exhaust pipe.
Dec 10, 2012 | Cars & Trucks
I got a 2003 ford f150 4.2 liter. the check engine light and the fuel cap light is on. it run really rough and feels like its misfireing. i changed the fuel cap, but it didnt work. i put it on a code...
P0171 - System to Lean (Bank 1)
P0174 - System to Lean (Bank 2) Lack of fuel or too much air - unmetered air after the mass air flow sensor ! vacuumn leak . Not enough fuel - low fuel pressure , clogged injectors .
P0171 - System to Lean (Bank 1) The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit. Refer to Section 1 , Powertrain Control Software, Fuel Trim for more information. Air Measurement System
  • MAF sensor (contaminated, damaged, malfunctioning, etc.)
Fuel System
  • Fuel pressure regulator (leaking, malfunctioning, etc.).
  • Fuel filter plugged, dirty.
  • Fuel pump (weak, check valve leaking, etc.).
  • Leaking/contaminated fuel injectors.
  • Low fuel pressure or running out of fuel.
  • EVAP canister purge valve leaking (when canister is "clean").
  • Fuel supply line restricted.
  • Fuel rail pressure sensor (incorrect reading).
Air Induction System
  • Air leaks after the MAF.
  • Vacuum Leaks.
  • PCV system (leak, valve stuck open, etc.)
  • Improperly seated engine oil dipstick.
Exhaust System
  • Exhaust leaks before or near the HO2Ss (exhaust manifold gasket, mating gaskets, etc.)..
EGR System
  • EGR valve tube/gasket leak
  • EVR solenoid vacuum leak
Secondary Air Injection
  • Damaged/malfunctioning secondary air injection system (mechanically stuck valve).
View Freeze Frame Data to determine operating conditions when DTC was set. Observe LONGFT1 and 2 PID(s). Refer to Section 2 , Adaptive Fuel DTCs Diagnostic Techniques for more information.
P0457 - EVAP Control System Leak Detected (Fuel Filler Cap Loose/Off) A fuel tank pressure change less than a minus (-) 7 inches of H 2 0 in 30 seconds has occurred after refueling; or there is excessive purge (fuel vapor) flow greater than 0.06 pounds per minute.
  • Fuel filler cap not installed on refueling (storing continuous memory DTC) and "Check Fuel Cap" light may also be illuminated.
  • Fuel filler cap missing, loose or cross-threaded.
Check for missing fuel filler cap or integrity of the cap. If OK, clear continuous memory DTCs and re-initiate EVAP Emission Running Loss Monitor Drive Cycle.
Stuck open evap purge valve , maybe. Take your vehicle to a qualified repair shop an have the evap system smoke tested .
P1151 - Lack of HO2S-21 Switch, Sensor Indicates Lean A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130
Feb 17, 2018 | Ford F-150 Cars & Trucks
I have code p0507 & p2187 on my 2004 Saab 93 the idle is rough
Combustion engines operate by burning an air/fuel mixture of about 14.7 to 1-14.7 parts air to 1 part fuel. When the air ratio goes below 14.7 parts, this is called a "rich" mixture. If the air rises above 14.7 parts, it is called a "lean" mixture.
Rich Mixture = Too much fuel, not enough air
Lean Mixture = Too much air, not enough fuel
To keep the engine running properly, the Engine Control Module measures the oxygen content in the exhaust with oxygen sensors and makes adjustments to the mixture by injecting more or less fuel.
P0507 Idle Control System RPM Higher Than Expected
P2187 System too lean at idle
Things to check:
1. MAF
2. Fuel pressure, fuel pump flow rate
Do you have cold air intake?
Run a fuel system cleaner first and reset software. Long Term Fuel Trim Additive. Max Value, Air/Fuel too Lean.
Fault symptom
Malfunction Indicator
Lamp
The engine may stop after starting, run unevenly and misfire or run
at high rpm.
On-board diagnosis
Type of
diagnosis:
Continuous
Enable criteria:
The engine has started and lambda control is active.An additive adaptation is
carried out.Cooling and intake air temperature 60°C.Fuel level at least
12%.
Fault criteria:
The additive adaptation factor is greater than 5.25%.
Diagnostic help
Diagnosis
regards:
Checking air/fuel ratio. With this DTC, the engine will be getting too much air or too little fuel.IMPORTANTA crankcase ventilation leak may be one reason as to why a DTC is set. Check crankcase ventilation function before starting regular troubleshooting.
Functions in the diagnostic
tool related to the fault:
Test value:
•O2S1 lambda
•Additive
Adaptation
•Short Term Fuel Trim
•Purge Adaptation
•Airmass Deviation
from Calculated
•Total Fuel Trim Here's a helpful link for you: http://repairpal.com/OBD-II-Code-P0171-and-P0174
You most likely have a vac leak. Hope this helps Fix Ya! Show some love with positive feedback if this brings you to a solution. Thanks Happy Hanna-kwanz-mas
Oct 26, 2010 | 2004 Saab 9-3
Need tofind out code 51 for 1997 jeep grand cherokee 4x4
Code 51 is ( Right Rear Fuel System Lean ) A lean air/fuel mixture has been indicated by an abnormally rich correction factor. Did you get this code by the flashing check engine light?
Sep 04, 2010 | 1997 Jeep Grand Cherokee
Check Engine Light
Your diagnostic about this CODE is:
Generic P-Code DRB Scan Tool Display Brief Description of DTC
P0171 (M) 1/1 Fuel System Lean A lean air/fuel mixture has been indicated by an abnormally rich correction factor.
P0320 (M) No Crank Reference Signal at PCM No reference signal (crankshaft position sensor) detected during engine cranking. P0320 (M) No RPM Signal to PCM (Crankshaft Position Sensor Signal to JTEC) A CKP signal has not been detected at th
For more details, you can visit the obd_dtc_jeep
Good luck, and rated this help.
Aug 11, 2009 | 1997 Jeep Grand Cherokee
2004 Jeep Grand Cherokee - 4.7L V8 - Catalytic Direct-fit Catalytic Converters - 49-State Legal Logo
94 people viewed this question
Top Eastern Vehicle Parts & Accessories Experts
baire
David Burbee
David Burbee
Are you an Eastern Vehicle Part and Accessory Expert? Answer questions, earn points and help others
